[iTowns-dev] Codesprint results
Jérémy Gaillard
jeremy.gaillard at liris.cnrs.fr
Fri Feb 5 04:43:46 PST 2016
Most of Vincent Mora's work and mine was focused on enabling a flat earth representation as an alternative to the globe in iTowns V2.
An issue was opened for this task : https://github.com/iTowns/itowns2/issues/34
What we achieved :
- Comprehension of the architecture and data flow
- Identified classes not generic enough in the current implementation to support the flat mode
- Integrated a flat mode (by mirroring the globe mode) that creates a simple flat mesh in a defined extent. We correctly go through the whole iTowns existing data process to achieve this
I think we can have a usable flat mode pretty quickly, once the most troublesome issues are sorted out (camera control, maybe some architecture fixes), we won't even need fully functional DEM/Imagery loading to test importing other data types or using other data structures.
Jérémy
Le 05/02/2016 11:05, Vincent Picavet (ml) a écrit :
> Hello all iTowns devs,
> First of all, I would like to thank you for these two days of code
> sprint. I think it has been a really good event, and we made good progress.
> Thanks to IGN Fab for hosting us, the venue was good too !
> 2 days was a bit short, but I do think we managed to be efficient. One
> thing we did not do is have a feedback meeting at the end.
> I therefore invite you to answer to this mail with a few lines giving
> insight on what you achieved during the codesprint. This will help have
> an overall vision, and prove that these 2 days have been worthwhile !
> Do not hesitate also to add your opinion on the codesprint : what was
> good, what can be improved for next time, etc.
> Vincent
> iTowns-dev mailing list
> iTowns-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/itowns-dev
More information about the iTowns-dev
