[iTowns-dev] Video in repo
Augustin Trancart
augustin.trancart at oslandia.com
Mon Jul 3 10:06:46 PDT 2017
Ok so, I intent to drastically reduce the size of the repo by removing from its
history the branches:
- gh-pages (only when deploy to itowns.github.io will work)
- gh-master
and the files:
- dist/* (will be partly done by removal of gh-pages)
- build/*
- data/*
- resources/*
- doc/*
- src/Core/Commander/Providers/Potree/workers.js (and actually maybe Potree/
directly)
- src/ThirdParty
- examples/gpx/ULTRA2009.gpx
- API_Doc/ (should be done by removal of gh-pages)
This implies a force-push on *all* the branches. Therefore, it is advised that
you *clone the repo back once it's done*. You'll probably need to resubmit your
PR. I can help for the rebase if necessary.
I'll keep a copy of the repo just in case :-)
Schedule: TOMORROW!
If you see something wrong in this, please raise your hand !
Augustin Trancart - Oslandia
PS: FYI, when aggressively testing locally, I reduce the repo size from 103Mb to
3.9MB.
On 29/06/2017 15:56, Augustin Trancart wrote:
> Ok, so I continued my investigation, and apart from this video, the size of the
> repo is also big because of the dist folder we commit to gh-pages at each
> merge... I'm pretty sure that does count more than the video itself (which
> shouldn't take more than it's compressed raw size, as it has not been changed
> since its appearance). And I don't really know how to workaround that.
> So I'm not sure it is worthy to rewrite the entire history for gaining just 20mb
> (max) of our 110mb repo any more. Maybe we should just live with it, as only the
> first clone is slow.
> Suggestions?
> On 29/06/2017 14:26, Thomas Broyer wrote:
>> 2017-06-29 13:51 GMT+02:00 Augustin Trancart <augustin.trancart at oslandia.com
>> <mailto:augustin.trancart at oslandia.com>>:
>> I basically trust maintainer not to merge big files,
>> Oh, you mean like for that video file? :troll:
>> but yes, if we can automate it, it's even better.
>> Note that apparently aabc913 didn't went through a pull request, so we couldn't
>> have prevented it anyway (Travis could have failed, and then a push-force would
>> have been needed anyway)
>> Cordialement,
>> Thomas Broyer
>> Atol Conseils et Développements
> iTowns-dev mailing list
> iTowns-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/itowns-dev
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/itowns-dev/attachments/20170703/a92d605d/attachment.sig>
More information about the iTowns-dev
