[iTowns-dev] Video in repo
Augustin Trancart augustin.trancart at oslandia.com
Mon Jul 3 10:13:24 PDT 2017
To be more precise: a prerequisite for this is to manage to upload our docs to
itowns.github.io. Pepp and I are currently working on this.
Augustin Trancart - Oslandia
On 03/07/2017 19:06, Augustin Trancart wrote:
> Ok so, I intent to drastically reduce the size of the repo by removing from its
> history the branches:
> - gh-pages (only when deploy to itowns.github.io will work)
> - gh-master
> and the files:
> - dist/* (will be partly done by removal of gh-pages)
> - build/*
> - data/*
> - resources/*
> - doc/*
> - src/Core/Commander/Providers/Potree/workers.js (and actually maybe Potree/
> directly)
> - src/ThirdParty
> - examples/gpx/ULTRA2009.gpx
> - API_Doc/ (should be done by removal of gh-pages)
> This implies a force-push on *all* the branches. Therefore, it is advised that
> you *clone the repo back once it's done*. You'll probably need to resubmit your
> PR. I can help for the rebase if necessary.
> I'll keep a copy of the repo just in case :-)
> Schedule: TOMORROW!
> If you see something wrong in this, please raise your hand !
> PS: FYI, when aggressively testing locally, I reduce the repo size from 103Mb to
> 3.9MB.
> On 29/06/2017 15:56, Augustin Trancart wrote:
>> Ok, so I continued my investigation, and apart from this video, the size of the
>> repo is also big because of the dist folder we commit to gh-pages at each
>> merge... I'm pretty sure that does count more than the video itself (which
>> shouldn't take more than it's compressed raw size, as it has not been changed
>> since its appearance). And I don't really know how to workaround that.
>> So I'm not sure it is worthy to rewrite the entire history for gaining just 20mb
>> (max) of our 110mb repo any more. Maybe we should just live with it, as only the
>> first clone is slow.
>> Suggestions?
>> On 29/06/2017 14:26, Thomas Broyer wrote:
>>> 2017-06-29 13:51 GMT+02:00 Augustin Trancart <augustin.trancart at oslandia.com
>>> <mailto:augustin.trancart at oslandia.com>>:
>>>     I basically trust maintainer not to merge big files,
>>> Oh, you mean like for that video file? :troll:
>>>     but yes, if we can automate it, it's even better.
>>> Note that apparently aabc913 didn't went through a pull request, so we couldn't
>>> have prevented it anyway (Travis could have failed, and then a push-force would
>>> have been needed anyway)
>>> Cordialement,
>>> Thomas Broyer
>>> Atol Conseils et Développements
>> iTowns-dev mailing list
>> iTowns-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/itowns-dev
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/itowns-dev/attachments/20170703/957f65a3/attachment.sig>
More information about the iTowns-dev mailing list
