[iTowns-dev] Release: name and version?
Vincent Picavet (ml)
vincent.ml at oslandia.com
Thu Jun 29 03:58:19 PDT 2017
On 29/06/2017 12:14, Thomas Broyer wrote:
> FWIW, my vote would go to 1/ (particularly if we *also* rewrite the Git
> history)
> Rename itowns/itowns to itowns/itowns1 and itowns/itowns2 to
> itowns/itowns, add a note to the README that iTowns 1 can be found at
> itowns/itowns1, and release a v2 (if it makes no guarantee about API
> stability, then label it as alpha or beta, or release candidate
> depending on the [lack of] confidence in API [in]stability).
> Either that or finding a new name…
Agree with this. Renaming itowns to itowns1 or itowns-legacy seems best
to avoid confusion, and keep itowns name for current version.
As for the name change, it could be an option, but a lot of
communication has been made around itowns already, especially at IGN, so
I think it would be difficult.
Vincent
> 2017-06-29 11:42 GMT+02:00 Augustin Trancart
> <augustin.trancart at oslandia.com <mailto:augustin.trancart at oslandia.com>>:
> Hi there!
> Our first release approaching, I have some questions about it about
> the package
> name and its version.
> The current situation: our repo is currently called itowns2. We have
> the old
> repo called itowns. The npm package (a 0.0.0-alpha published for testing
> purpose) is currently called itowns[1]. I see several possibilities:
> 1/ we stick with the "itowns" name. We rename itowns repo into
> itowns-old (for
> instance), and we rename itowns2 into itowns. We release v2.0.0 on
> 5th of July
> (imho we can't release another number to avoid confusion with itowns1)
> 2/ we stick with the current situation: "itowns" for the npm package
> only, and
> "itowns2" for the repo. After all, the repo is linked in the npm
> package page.
> We release a v2.0.0 for the same reason as 1/
> 3/ We keep the name itowns2 for this release everywhere. Therefore,
> we keep the
> github repo as it is and we create a new npm package named itowns2
> (and delete
> package itowns, because it is really itowns2 inside). We can release
> whatever
> version number we want.
> 4/ another combination of the above/solution?
> I don't really like current situation (aka 2/), because I think it's
> the most
> confusing setup (different name for the package and the repo, and an
> old itowns
> repo with same name as package name still in existence).
> 1/ has the advantage of reducing the confusion between itowns and
> itowns2
> (because there would be only itowns) and be clear about which one is
> the current
> one, but it forces us to rename some repos (never ideal) and release
> a v2
> (instead of a v0 or v1 for instance).
> 3/ has the advantage of being the least disruptive and the more
> respectful of
> the history of the project. If we choose this solution, we must be
> clear in
> itowns old repo that new development should be done in itowns2 repo.
> If we
> choose this, I would advocate to release a v0.something, because in
> semver[2],
> 0.x.x versions do not need to have a stable API. Then we can release
> a v1 some
> weeks/months before the geoportail itowns release. It's my preferred
> choice.
> For a more general thought about version numbers, I would like to follow
> semantic versioning[2]. I think it's a great way to convey
> incompatible change
> informations to our users. For this a prerequisite would be to
> define our Public
> API. I propose a simple criterion : everything that's currently
> documented in
> our jsdoc page is our current API. Everything else is not, and we
> make it clear so.
> What do you think about all that?
> [1] https://www.npmjs.com/package/itowns
> <https://www.npmjs.com/package/itowns>
> [2] http://semver.org/
> Augustin Trancart - Oslandia
> PS: We can examine crazier ideas too, like another name entirely? eg
> Barium
> (Cesium is elem n°55, Barium is 56, so Cesium++ ;-) )?
> iTowns-dev mailing list
> iTowns-dev at lists.osgeo.org <mailto:iTowns-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/itowns-dev
> <https://lists.osgeo.org/mailman/listinfo/itowns-dev>
> Cordialement,
> Thomas Broyer
> Atol Conseils et Développements
More information about the iTowns-dev
