[iTowns-dev] Release: name and version?
Augustin Trancart
augustin.trancart at oslandia.com
Thu Jun 29 06:20:11 PDT 2017
Ok, at the moment it seems there is a consensus for going with 1/.
I propose to do the dull work of renaming repos on the 4th of July, if no
objection until then (or everything including the release on the 5th).
so itowns -> itowns-legacy (+ a link in the README)
itowns2 -> itowns
I guess the released version number would be v2? Or something else?
Augustin Trancart - Oslandia
On 29/06/2017 15:13, Alexandre Devaux wrote:
> Hi,
> I would go for 1) too. "rename itowns repo into itowns-old (for instance), and we rename itowns2 into itowns"
> Alexandre Devaux
> Chargé d'Etudes et de Recherche
> Laboratoire MATIS, IGN
> Tel: 01 43 98 85 73
> ________________________________________
> De : iTowns-dev [itowns-dev-bounces at lists.osgeo.org] de la part de itowns-dev-request at lists.osgeo.org [itowns-dev-request at lists.osgeo.org]
> Date d'envoi : jeudi 29 juin 2017 13:51
> À : itowns-dev at lists.osgeo.org
> Objet : iTowns-dev Digest, Vol 13, Issue 5
> Send iTowns-dev mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/itowns-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> itowns-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of iTowns-dev digest..."
> Today's Topics:
> 1. Re: Video in repo (Augustin Trancart)
> 2. Re: Video in repo (Thomas Broyer)
> 3. Re: Release: name and version? (Vincent Picavet (ml))
> 4. Re: Video in repo (Vincent Picavet (ml))
> 5. Re: Video in repo (Augustin Trancart)
> Message: 1
> Date: Thu, 29 Jun 2017 12:13:06 +0200
> From: Augustin Trancart <augustin.trancart at oslandia.com>
> To: Thomas Broyer <t.broyer at atolcd.com>
> Cc: "itowns-dev at lists.osgeo.org" <itowns-dev at lists.osgeo.org>
> Subject: Re: [iTowns-dev] Video in repo
> Message-ID: <619a829d-7f33-cf9c-58cb-1f4b9ff34c45 at oslandia.com>
> Content-Type: text/plain; charset="utf-8"
> Yes, agree with the idea of removing other big obsolete files as well.
> I'm not too worried about pull/pushes. If we require the files to be removed
> before merge, these commits would become unreachable after the force-push, and
> would eventually be garbage collected (providing we are careful at removing old
> branches).
> On 29/06/2017 12:03, Thomas Broyer wrote:
>> 15 months ago (or so), big files were added to the project and then removed, and
>> I also floated the idea of a history rewrite. I never got the "go" so it hasn't
>> been done. Iff we go that road for the video file, I suggest we also get rid of
>> those old commits.
>> I don't have a strong opinion whether this should be done, but it's clear that
>> it's now or never.
>> I'd suggest we eventually find a way to somehow reject pull requests (we
>> apparently can't reject commits/pushes) with big files (or many smaller files!);
>> possibly an additional check in Travis, I don't know.
>> 2017-06-29 11:32 GMT+02:00 Augustin Trancart <augustin.trancart at oslandia.com
>> <mailto:augustin.trancart at oslandia.com>>:
>> Hi there!
>> Quick question with the release in sight: a video of 24M has been added (in
>> aabc913) and removed later (in b321c01) in the repository. This makes the clone
>> of the repository quite long even though the video is not in master any more.
>> Should we rewrite the history to get rid of it?
>> It's possible, but it implies a force-push on master. It means that everybody
>> will need to use "git rebase --onto master <commit-range>" for all their
>> branches after this push is done and force-push them (and maybe a git reset
>> --hard on their local master, I'm not sure how clever git is nowadays).
>> It's a low risk process (we'll keep a copy of the old master around), but it's a
>> bit of a hassle and requires synchronization between us. I believe it is
>> possible, but if we want to do it, we'd better do it now, before success hits us
>> hard and we have thousands of contributors (yeah, I'm an optimistic kind of guy
>> Thoughts?
>> augustin.trancart at oslandia.com <mailto:augustin.trancart at oslandia.com>
>> iTowns-dev at lists.osgeo.org <mailto:iTowns-dev at lists.osgeo.org>
>> <https://lists.osgeo.org/mailman/listinfo/itowns-dev>
>> Cordialement,
>> Thomas Broyer
>> Atol Conseils et Développements
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Type: application/pgp-signature
> Desc: OpenPGP digital signature
> URL: <http://lists.osgeo.org/pipermail/itowns-dev/attachments/20170629/674fd290/attachment-0001.sig>
> Message: 2
> Date: Thu, 29 Jun 2017 12:34:13 +0200
> From: Thomas Broyer <t.broyer at atolcd.com>
> To: augustin.trancart at oslandia.com
> Message-ID:
> <CA+9O_-QNmXJX2rs9SFr-h+KrVN7ZRSbSAYoqLq5CLZfbOvy87g at mail.gmail.com>
> 2017-06-29 12:13 GMT+02:00 Augustin Trancart <augustin.trancart at oslandia.com
>> removed
>> and
>> removing old
>> branches).
> Not sure I understand that last paragraph.
> My remark wrt rejecting pull requests (or pushes) with big files was to
> prevent this situation from happening again (in other words, as you said,
> "require the files to be removed before merge", but automate it).
> Note also that GitHub will keep the files anyway in their special
> refs/pull/ references [1], you'll just never sync them (unless you want it)
> because (by default) Git only syncs refs/heads/ and refs/tags/
> [1] https://help.github.com/articles/checking-out-pull-requests-locally/
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/itowns-dev/attachments/20170629/74f11c2d/attachment-0001.html>
> Message: 3
> Date: Thu, 29 Jun 2017 12:58:19 +0200
> From: "Vincent Picavet (ml)" <vincent.ml at oslandia.com>
> To: Thomas Broyer <t.broyer at atolcd.com>,
> Subject: Re: [iTowns-dev] Release: name and version?
> Message-ID: <5e667061-9c34-12cd-662f-f0ccb151d0ac at oslandia.com>
> Content-Type: text/plain; charset=utf-8
> Hi,
> On 29/06/2017 12:14, Thomas Broyer wrote:
>> FWIW, my vote would go to 1/ (particularly if we *also* rewrite the Git
>> history)
>> Rename itowns/itowns to itowns/itowns1 and itowns/itowns2 to
>> itowns/itowns, add a note to the README that iTowns 1 can be found at
>> itowns/itowns1, and release a v2 (if it makes no guarantee about API
>> stability, then label it as alpha or beta, or release candidate
>> depending on the [lack of] confidence in API [in]stability).
>> Either that or finding a new name…
> Agree with this. Renaming itowns to itowns1 or itowns-legacy seems best
> to avoid confusion, and keep itowns name for current version.
> As for the name change, it could be an option, but a lot of
> communication has been made around itowns already, especially at IGN, so
> I think it would be difficult.
> Vincent
>> 2017-06-29 11:42 GMT+02:00 Augustin Trancart
>> <augustin.trancart at oslandia.com <mailto:augustin.trancart at oslandia.com>>:
>> Hi there!
>> Our first release approaching, I have some questions about it about
>> the package
>> name and its version.
>> The current situation: our repo is currently called itowns2. We have
>> the old
>> repo called itowns. The npm package (a 0.0.0-alpha published for testing
>> purpose) is currently called itowns[1]. I see several possibilities:
>> 1/ we stick with the "itowns" name. We rename itowns repo into
>> itowns-old (for
>> instance), and we rename itowns2 into itowns. We release v2.0.0 on
>> 5th of July
>> (imho we can't release another number to avoid confusion with itowns1)
>> 2/ we stick with the current situation: "itowns" for the npm package
>> only, and
>> "itowns2" for the repo. After all, the repo is linked in the npm
>> package page.
>> We release a v2.0.0 for the same reason as 1/
>> 3/ We keep the name itowns2 for this release everywhere. Therefore,
>> we keep the
>> github repo as it is and we create a new npm package named itowns2
>> (and delete
>> package itowns, because it is really itowns2 inside). We can release
>> whatever
>> version number we want.
>> 4/ another combination of the above/solution?
>> I don't really like current situation (aka 2/), because I think it's
>> the most
>> confusing setup (different name for the package and the repo, and an
>> old itowns
>> repo with same name as package name still in existence).
>> 1/ has the advantage of reducing the confusion between itowns and
>> itowns2
>> (because there would be only itowns) and be clear about which one is
>> the current
>> one, but it forces us to rename some repos (never ideal) and release
>> a v2
>> (instead of a v0 or v1 for instance).
>> 3/ has the advantage of being the least disruptive and the more
>> respectful of
>> the history of the project. If we choose this solution, we must be
>> clear in
>> itowns old repo that new development should be done in itowns2 repo.
>> If we
>> choose this, I would advocate to release a v0.something, because in
>> semver[2],
>> 0.x.x versions do not need to have a stable API. Then we can release
>> a v1 some
>> weeks/months before the geoportail itowns release. It's my preferred
>> choice.
>> For a more general thought about version numbers, I would like to follow
>> semantic versioning[2]. I think it's a great way to convey
>> incompatible change
>> informations to our users. For this a prerequisite would be to
>> define our Public
>> API. I propose a simple criterion : everything that's currently
>> documented in
>> our jsdoc page is our current API. Everything else is not, and we
>> make it clear so.
>> What do you think about all that?
>> [1] https://www.npmjs.com/package/itowns
>> <https://www.npmjs.com/package/itowns>
>> [2] http://semver.org/
>> PS: We can examine crazier ideas too, like another name entirely? eg
>> Barium
>> (Cesium is elem n°55, Barium is 56, so Cesium++ ;-) )?
>> Cordialement,
>> Thomas Broyer
> Message: 4
> Date: Thu, 29 Jun 2017 13:00:55 +0200
> To: Pierre-Eric Pelloux-Prayer
> <pierre-eric.pelloux-prayer at oslandia.com>, itowns-dev at lists.osgeo.org
> Message-ID: <2cef31e3-b12c-cef0-3592-eea29b19c76d at oslandia.com>
> Hello,
> +1 also on history rewrite.
> Try to gather all big files, not just the video.
> Doing this just before the release would probably minimize the number of
> branches concerned by this change ( aka : "merge now or expect trouble"
> Vincent
> On 29/06/2017 11:53, Pierre-Eric Pelloux-Prayer wrote:
>> +1 let's do this before the first release.
>> Le 29/06/2017 à 11:32, Augustin Trancart a écrit :
>>> Hi there!
>>> Thoughts?
> Message: 5
> Date: Thu, 29 Jun 2017 13:51:40 +0200
> Message-ID: <dc82d15c-3207-1390-3971-d16edfd62d7e at oslandia.com>
> I basically trust maintainer not to merge big files, but yes, if we can automate
> it, it's even better.
>> branches).
>> My remark wrt rejecting pull requests (or pushes) with big files was to prevent
>> this situation from happening again (in other words, as you said, "require the
>> Note also that GitHub will keep the files anyway in their special refs/pull/
>> references [1], you'll just never sync them (unless you want it) because (by
> URL: <http://lists.osgeo.org/pipermail/itowns-dev/attachments/20170629/02a1cc9b/attachment.sig>
> Subject: Digest Footer
> End of iTowns-dev Digest, Vol 13, Issue 5
URL: <http://lists.osgeo.org/pipermail/itowns-dev/attachments/20170629/00b7f3e0/attachment-0001.sig>
More information about the iTowns-dev
