[iTowns-dev] Label "good first issue"
Vincent Picavet (ml)
vincent.ml at oslandia.com
Fri Oct 13 06:34:34 PDT 2017
On 13/10/2017 09:38, Augustin Trancart wrote:
> Hi everyone,
> As Github rolled a new feature related to the "good first issue" and "help
> wanted" labels, I took the liberty to rename "beginner" label to "good first
> issue". (apparently issues labeled with these will be more discoverable for new
> contributors)
> Don't hesitate to roll back if I misunderstood the purpose of this label.
> Also, we previously used the "help wanted" label more like a "question" label,
> but on other OSS projects, usually "help wanted" means more "Does someone want
> to code this?" than "I need help here". I suggest to adopt this convention too.
> WDYT?
Good suggestions, +1 to this.
Vincent
> Cheers !
> iTowns-dev mailing list
> iTowns-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/itowns-dev
More information about the iTowns-dev
