[iTowns-user] Elevation Layers and supported formats
Dalton, Charlie
Charlie.Dalton at parsons.com
Mon Jan 27 11:18:52 PST 2020
I'm using iTowns, 2.15.0. I try to stay latest but three.js doesn't always get their typings updated which results in compilation errors in our typescript application.
?I'm attempting to expose an elevation layer in a Geoserver and so far my efforts produce a WMS endpoint (I have tried a single large GeoTiff, ImageMosaic with many geotiffs or Shapefile layer). The example packaged in iTowns uses a WMTS endpoint that serves x-bil images. Based on my searching in the code, xbil seems to be the one and only expected format based on:
ElevationLayer#update(...)
LayeredMaterialNodeProcessing#updateLayeredMaterialNodeElevation(...)
XbilParser#computeMinMaxElevation(...)
First, can I create an elevation layer using WMS with iTowns or does it need to be a WMTS endpoint?
Second, will elevation only work with x-bil format and if not, what other formats may I use?
Charlie Dalton
NOTICE: This email message and all attachments transmitted with it may contain privileged and confidential information, and information that is protected by, and proprietary to, Parsons Corporation, and is intended solely for the use of the addressee for the specific purpose set forth in this communication. If the reader of this message is not the intended recipient, you are hereby notified that any reading, dissemination, distribution, copying, or other use of this message or its attachments is strictly prohibited, and you should delete this message and all copies and backups thereof. The recipient may not further distribute or use any of the information contained herein without the express written authorization of the sender. If you have received this message in error, or if you have any questions regarding the use of the proprietary information contained therein, please contact the sender of this message immediately, and the sender will provide you with further instructions.
URL: <http://lists.osgeo.org/pipermail/itowns-user/attachments/20200127/b98f1e16/attachment.html>
More information about the ITowns-user
