[Java-collab] geometry factory vs interface
Jody Garnett jody.garnett at gmail.com
Wed Aug 12 09:58:31 EDT 2009
> I think that one of the main goals of this project has to be to define
> an API for geometries and the usage of Interfaces is normally more
> flexible that the usage of abstract classes. I always prefer to
> define a
> Interface and a default implementation for this Interface.
> In the proposal of interfaces that Markus did I've seen methods like:
> - public boolean isBeyond( Geometry geometry, Measure distance );
> - public boolean isWithin( Geometry geometry );
> - public boolean overlaps( Geometry geometry );
> that are not refered to the geometry structure. They are operations!
> We
> have to separate structure of functionality and I suggest that all
> these
> methods have not to be here.
> In gvSIG we have replaced all these methods by just one:
> - public Object invokeOperation(int index, GeometryOperationContext
> ctx)
> Details can be found here [1]. Yes, we know that we are losing
> performance with this option but we are winning in other issues:
I like it Jorge - now you are playing with fire :-)
I would actually like a compromise for usability here ... I would like
something like the following (don't pick on the example too much since
I am thinking as I type :D ).
  * Test if we are a set distance beyond another geometry.
  * <p>
  * This is a connivence method for the following call:<pre><code>
  * return invokeOperation( BeyondOperationContext( this, geom,
distance ));</code></pre>
  * <p>
  * @geom Geometry to check against; care should be taken that it is
in the same CRS
* @geom distance distance to check from geom
  * @returns true if distance beyond the indicated geom.
public boolean isBeyond( Geometry geom, Measure distance );
public boolean invokeOperation(  BooleanOperationContext );
public Geometry union( Geometry geom );
public Geometry invokeOperation( GeometryOperationContext );
Indeed I would rather *not* have the "invokeOperation" as part of the
Geometry; since I expect to have a switch board of operations to
choose from based on the geometry involved; CRS being used and so on.
Jorge are you familiar with the operation split in JTS? The recent
operation for  PrepairedGeometry construct? It is used to hold onto
intermediate results (edge graphs and so on).  This is what I envision
for a GeometryOperationContext ...
> - The Geometry Interface is always the same (we don't have the problem
> that has been commented above).
> - Using this system is possible to provide a new implementation of one
> concrete operation associated to a GeometryType and it is not
> necessary
> to update the GeometryType (separation between structure and
> functionality).
>>> Especially, for Point and Envelope I would also like to have
>>> constructors alternatively to a factory:
>>> Point p = new Point (0,1);
>>> is just nicer to write than
>>> GeometryFactory.getInstance().createPoint (0,1);
>> You have highlighted one place where I was sure I would need an
>> interface :-) Indeed when a Points data structure provides access
>> to a single Point it often would use a light weight implementation
>> of Point that would delegate onto the backing double[] for example.
>> Or another implementation could make use of a List<PointImpl>
>> etc... I see later in this email you talk about recycling a Point
>> object when iterating; to accomplish this you will need to define
>> Point as a data object and add equals and hashcode to the interface.
> Point has to be always an Interface. We can have the classes Point2D,
> Point3D.... and we can not make a "new" of any of them. We can maybe
> use
> the Builder pattern to provide different sets of geometries.
> In gvSIG it is possible to add your own implementation of GeometryType
> separately and we have a "GeometryManager" to create them:
> Point point = geometryManager.createPoint(2);
> 2 is the dimension of the geometry. We have a faster way to create a
> point in 2 dimensions using the method:
> Point point = geometryManager.createPoint(0,1, 2);
> It works because a "point in 2 dimensions" has been previously
> registered on our manager and everyone can register its own
> implementation of a Point2D.
Interesting; we have selection of geometry factory implementations.
And a GeometryBuilder that will hunt down the correct factory for the
CRS you are building against (so we don;t say 2 - we let that part
come from the CRS definition). In anycase that is neither here nor
there .. we have come up with a similar design.
One thing I found *bad* about this design in geotools is that we had
too many small factories; indeed a GeometryBuilder was kind of needed
since it was a pain to hunt down the correct AggregateFactory,
PositionFactory, PrecisionFactory, ComplexFactory and
GeometryFactory :-)
So some kind of balance would be good; I imagine this is something we
can sort out with live code examples when the time comes?
Just to bury my original point:
- we *could* make use of classes for Geometry; as long as we have the
invokeOperation stuff isolated behind interfaces.
- it is probably only useful as an extreme to force us to think about
what we are doing
- please consider the geotools implementation of many little factories
as the other extreme
With that in mind Jorge - how are you actually getting along with your
approach? Is there anything that "boiler plate" or hard to do? I could
see making a bunch of calls to register stuff with your
geometryManager - and just cutting and pasting that code against and
again; just so I did not have to *think* when creating points.
> It looks that I want to use the same geometry management system that
> we
> are using on gvSIG: this is not true! One of our goals has been to
> have
> a configurable and extensible geometry management system and I only
> comment our examples to give you other vision on our common goal.
Thanks for the input Jorge.
Please don't apologize about drawing on the experience of gvSig. We
all have different implementations and experience and the idea with
collaboration is to ... collaborate :-D
Jody
More information about the Java-collab mailing list
