[Java-collab] geometry factory vs interface
    Jorge Piera
    jorge.piera at iver.es
    Thu Aug 13 02:01:22 EDT 2009
Jody Garnett wrote:
>> I think that one of the main goals of this project has to be to define
>> an API for geometries and the usage of Interfaces is normally more
>> flexible that the usage of abstract classes. I always prefer to define a
>> Interface and a default implementation for this Interface.
>> In the proposal of interfaces that Markus did I've seen methods like:
>> - public boolean isBeyond( Geometry geometry, Measure distance );
>> - public boolean isWithin( Geometry geometry );
>> - public boolean overlaps( Geometry geometry );
>> that are not refered to the geometry structure. They are operations! We
>> have to separate structure of functionality and I suggest that all these
>> methods have not to be here.
>> In gvSIG we have replaced all these methods by just one:
>> - public Object invokeOperation(int index, GeometryOperationContext ctx)
>> Details can be found here [1]. Yes, we know that we are losing
>> performance with this option but we are winning in other issues:
> I like it Jorge - now you are playing with fire :-)
> I would actually like a compromise for usability here ... I would like
> something like the following (don't pick on the example too much since
> I am thinking as I type :D ).
>  * Test if we are a set distance beyond another geometry.
>  * <p>
>  * This is a connivence method for the following call:<pre><code>
>  * return invokeOperation( BeyondOperationContext( this, geom,
> distance ));</code></pre>
>  * <p>
>  * @geom Geometry to check against; care should be taken that it is in
> the same CRS
> * @geom distance distance to check from geom
>  * @returns true if distance beyond the indicated geom.
> public boolean isBeyond( Geometry geom, Measure distance );
> public boolean invokeOperation(  BooleanOperationContext );
> public Geometry union( Geometry geom );
> public Geometry invokeOperation( GeometryOperationContext );
> Indeed I would rather *not* have the "invokeOperation" as part of the
> Geometry; since I expect to have a switch board of operations to
> choose from based on the geometry involved; CRS being used and so on.
> Jorge are you familiar with the operation split in JTS? The recent
> operation for  PrepairedGeometry construct? It is used to hold onto
> intermediate results (edge graphs and so on).  This is what I envision
> for a GeometryOperationContext ...
No, I'm not familiar but I'm going to have a look.
>> - The Geometry Interface is always the same (we don't have the problem
>> that has been commented above).
>> - Using this system is possible to provide a new implementation of one
>> concrete operation associated to a GeometryType and it is not necessary
>> to update the GeometryType (separation between structure and
>> functionality).
>>>> Especially, for Point and Envelope I would also like to have
>>>> constructors alternatively to a factory:
>>>> Point p = new Point (0,1);
>>>> is just nicer to write than
>>>> GeometryFactory.getInstance().createPoint (0,1);
>>> You have highlighted one place where I was sure I would need an
>>> interface :-) Indeed when a Points data structure provides access to
>>> a single Point it often would use a light weight implementation of
>>> Point that would delegate onto the backing double[] for example. Or
>>> another implementation could make use of a List<PointImpl> etc... I
>>> see later in this email you talk about recycling a Point object when
>>> iterating; to accomplish this you will need to define Point as a
>>> data object and add equals and hashcode to the interface.
>> Point has to be always an Interface. We can have the classes Point2D,
>> Point3D.... and we can not make a "new" of any of them. We can maybe use
>> the Builder pattern to provide different sets of geometries.
>> In gvSIG it is possible to add your own implementation of GeometryType
>> separately and we have a "GeometryManager" to create them:
>> Point point = geometryManager.createPoint(2);
>> 2 is the dimension of the geometry. We have a faster way to create a
>> point in 2 dimensions using the method:
>> Point point = geometryManager.createPoint(0,1, 2);
>> It works because a "point in 2 dimensions" has been previously
>> registered on our manager and everyone can register its own
>> implementation of a Point2D.
> Interesting; we have selection of geometry factory implementations.
> And a GeometryBuilder that will hunt down the correct factory for the
> CRS you are building against (so we don;t say 2 - we let that part
> come from the CRS definition). In anycase that is neither here nor
> there .. we have come up with a similar design.
It looks an interesting approach the usage of the CRS. But there is a
small detail that I hid in my last email to simplify the example. Really
we don't use "2" to define the dimension. We use a set on constants in
our application to classify our geometries:
- GEOM2D
- GEOM2DZ
- GEOM2M
- GEOM3D
- GEOM3DM
"M" means the "M coordinate". In a future we also can add geometries
with Time or other classes of geometries. If you only uses the CRS is
not possible to specify if you want a geometry with support for the M
coordinate.
> One thing I found *bad* about this design in geotools is that we had
> too many small factories; indeed a GeometryBuilder was kind of needed
> since it was a pain to hunt down the correct AggregateFactory,
> PositionFactory, PrecisionFactory, ComplexFactory and GeometryFactory :-)
> So some kind of balance would be good; I imagine this is something we
> can sort out with live code examples when the time comes?
> Just to bury my original point:
> - we *could* make use of classes for Geometry; as long as we have the
> invokeOperation stuff isolated behind interfaces.
> - it is probably only useful as an extreme to force us to think about
> what we are doing
> - please consider the geotools implementation of many little factories
> as the other extreme
> With that in mind Jorge - how are you actually getting along with your
> approach? Is there anything that "boiler plate" or hard to do? I could
> see making a bunch of calls to register stuff with your
> geometryManager - and just cutting and pasting that code against and
> again; just so I did not have to *think* when creating points.
I suppose that with Geotools I can register my own set of factories to
create my own geometries. Cool! The difference is that we can register
single geometries: e.g: I can register my own implementation for a Point
with 2 dimensions, and I only have to register the class that implements it.
It is true that you have to do a bunch of calls to register all the
geometries in the GeometryManager, but I think that it is not any
problem: this code is written just one time and in the 99% of the times
is not necessary to update it. Only if you want to add your own geometry
you have to register it.
It is just other approach.
Best regards,
Jorge.
Jorge Piera Llodrá
Especialista en Servicios OGC
Equipo de desarrollo gvSIG
IVER TI S.A.
C/ Lérida, 20
46009-Valencia (Spain)
Tlf.+34902252540
www.iver.es
www.gvsig.com
More information about the Java-collab
