[Java-collab] Re: geometry next steps
Markus Schneider
schneider at lat-lon.de
Mon Oct 5 12:44:24 EDT 2009
Hi Jody,
Jody Garnett wrote:
> One thing I would like to clarify is the creation of factories... you
> mention the desire for two factories (one for SFS and one for ISO).
> I am actually feeling pretty strongly about having *one* factory (ie
> where you have all the new methods) and two "builders" (one for SFS and
> one for ISO). Would you mind if I take this technical direction - I have
> found it to be a good separation of concerns that prevents duplication.
If I understand correctly, then the benefits are that each geometry implementation would require only a single factory
class. The builders can be identical for all implementations and delegate the work to the selected factory.
Sounds very reasonable to me. Or am I missing the point?
Best regards,
Markus
Markus Schneider
l a t / l o n GmbH
Aennchenstrasse 19 53177 Bonn, Germany
phone ++49 +228 184960 fax ++49 +228 1849629
http://www.lat-lon.de http://www.deegree.org
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/java-collab/attachments/20091005/163cd284/signature.bin
More information about the Java-collab
