[Java-collab] Data for FOSS4G geometry code sprint, modules,
and factories
Ben Caradoc-Davies
Ben.Caradoc-Davies at csiro.au
Fri Oct 9 03:28:49 EDT 2009
Jody,
what is the sample data that you were planning to use in the geometry
code sprint? Can I get it? Can we use it in unit tests?
The current module seems to contain only interfaces. Should we split it
into a public-interface module and an implementation module? Or keep it
together for simplicity?
I am not sure where you would like to lead us. Do we need the whole SPI
FactoryFactoryFactory pattern, or are we going to exercise restraint and
just have a few static factory methods?
http://discuss.joelonsoftware.com/default.asp?joel.3.219431.12
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies at csiro.au>
Software Engineer, CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
More information about the Java-collab
