[Java-collab] Re: Data for FOSS4G geometry code sprint, modules,
	and factories
    Jody Garnett
    jody.garnett at gmail.com
    Sun Oct 25 03:48:40 EDT 2009
On 25/10/2009, at 10:06 AM, Markus Schneider wrote:
> If anybody is listening: I am on #geometry-collab right now.
Thanks to Markus for joining the geometry code sprint remotely. Here
are some notes; too sleepy for discussion / explanation... hopefully
Ben can fill in the blanks.
Our List on the board was....
1. interface
- we went with what was there
- noticed a few things that we talked about on email that were not
there yet (naming of nested Enums for example)
- adjusted Points to have CRS; and to separate out number of
significant axis from the number of ordinates used (ie if there are
measures)
- the name "Points" messes me up when I try to talk to humans -
example sentence from today that confused Ben: The "Point"s from the
Points need to be copied into an ArrayList of "Point"s prior to
calling the factory method
2. implementation
- used deegree code as a start
- placeholder UOM, Angle, Length and CRS will work for compiling but
they really will not last us a very long time
- CRS<T> looks like an okay way to offer a wrapper around geotools
CoordianteReferenceSystem; need to try code example to see if it is
terrible to program with or not -P
3. factory - done (revised through some use)
- removed the method create as in code example:   factory.point( null,
crs, coordinates ) is obvious; "create" and "factory" communicate the
same information
- removed helper methods in order to have minimal method exposure
(hopefully we can remove more)
- added method to create points
- handling of Points may require separate factory? At the very least
we need two create methods to capture the general (List<Point>) and
fast (double[]) case
3. builder
- SimpleGeometryBuilder is method compatible for deegree
SimpleGeometryFactory to ease transition
- GeometryBuilder is method compatible for deegree GeometryBuilder to
ease transition
- working on a jts method compatible builder now (ie method compatible
with JTS GeometryFactory )
4. extras
- wktreader - ported from jts w/ curve from geotools; accepts a
GeometryFactory and a CRS and gets to work
- DuplicateGeometry used to copy a geometry using a provided factory
--------geotools branch ------
5. PropertyDataStore
- forked geotools in order to try out the interfaces / factories
- converters added to allow PropertyDataStore to read in a Geometry
6. Render
- need to add converter to JTS Geometry in order to get to a Shape to
render (we can go directly to Shape later when we get a decimate going)
Jody
More information about the Java-collab
