[Java-collab] Re: Data for FOSS4G geometry code sprint, modules,
	and factories
    Ben Caradoc-Davies
    Ben.Caradoc-Davies at csiro.au
    Tue Oct 27 22:47:19 EDT 2009
I have attached a photo of the whiteboard. I got a WKTReader working for
one type (LINESTRING). Support for other types is close.
Thanks a lot, Markus, for your help. The API looks pretty sweet.
Kind regards,
Ben.
On 25/10/09 15:48, Jody Garnett wrote:
> On 25/10/2009, at 10:06 AM, Markus Schneider wrote:
>> If anybody is listening: I am on #geometry-collab right now.
> Thanks to Markus for joining the geometry code sprint remotely. Here
> are some notes; too sleepy for discussion / explanation... hopefully
> Ben can fill in the blanks.
> Our List on the board was....
> 1. interface
> - we went with what was there
> - noticed a few things that we talked about on email that were not
> there yet (naming of nested Enums for example)
> - adjusted Points to have CRS; and to separate out number of
> significant axis from the number of ordinates used (ie if there are
> measures)
> - the name "Points" messes me up when I try to talk to humans -
> example sentence from today that confused Ben: The "Point"s from the
> Points need to be copied into an ArrayList of "Point"s prior to
> calling the factory method
> 2. implementation
> - used deegree code as a start
> - placeholder UOM, Angle, Length and CRS will work for compiling but
> they really will not last us a very long time
> - CRS<T>  looks like an okay way to offer a wrapper around geotools
> CoordianteReferenceSystem; need to try code example to see if it is
> terrible to program with or not -P
> 3. factory - done (revised through some use)
> - removed the method create as in code example:   factory.point( null,
> crs, coordinates ) is obvious; "create" and "factory" communicate the
> same information
> - removed helper methods in order to have minimal method exposure
> (hopefully we can remove more)
> - added method to create points
> - handling of Points may require separate factory? At the very least
> we need two create methods to capture the general (List<Point>) and
> fast (double[]) case
> 3. builder
> - SimpleGeometryBuilder is method compatible for deegree
> SimpleGeometryFactory to ease transition
> - GeometryBuilder is method compatible for deegree GeometryBuilder to
> ease transition
> - working on a jts method compatible builder now (ie method compatible
> with JTS GeometryFactory )
> 4. extras
> - wktreader - ported from jts w/ curve from geotools; accepts a
> GeometryFactory and a CRS and gets to work
> - DuplicateGeometry used to copy a geometry using a provided factory
> --------geotools branch ------
> 5. PropertyDataStore
> - forked geotools in order to try out the interfaces / factories
> - converters added to allow PropertyDataStore to read in a Geometry
> 6. Render
> - need to add converter to JTS Geometry in order to get to a Shape to
> render (we can go directly to Shape later when we get a decimate going)
> Jody
> Java-collab mailing list
> Java-collab at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/java-collab
Ben Caradoc-Davies <Ben.Caradoc-Davies at csiro.au>
Software Engineer, CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/java-collab/attachments/20091028/b00df0bc/img_0978-0001.jpg
More information about the Java-collab
