[Landsat-pds] MTL.json files now available
Mon Jun 15 14:49:34 PDT 2015
Jeff,
Is this implementation available somewhere for review?  I'm surprised
by your statement that "sometimes the number of files that came in
were too many to process in 4 hours with the current tool.".  I would
have thought you were only reading the _MTL.txt and writing a .json.
This should - hopefully - only take a second or two per scene.
Best regards,
Frank
On Mon, Jun 15, 2015 at 1:25 PM, Layton, Jeff <jefflay at amazon.com> wrote:
> I had to back off the 4 hour window because sometimes the number of files
> that came in were too many to process in 4 hours with the current tool.
> I’m doing it every 6 hours.
> Sorry about the inconvenience.
> Thanks!
> Jeff
> From: landsat-pds-bounces at lists.osgeo.org
> [mailto:landsat-pds-bounces at lists.osgeo.org] On Behalf Of Sundwall, Jed
> Sent: Tuesday, June 09, 2015 8:52 PM
> To: landsat-pds at lists.osgeo.org
> Subject: [Landsat-pds] MTL.json files now available
> We have started converting all Landsat MTL text files into json. Jeff
> Layton, an AWS solutions architect, wrote a script to convert the text
> files, and we have run them on all files in s3://landsat-pds. We run the
> script on new MTL files about every four hours.
> We are currently researching using AWS Lambda to convert MTL files
> immediately as they're added to the bucket.
> Please let me know if you have any questions about this.
> You can see an example of one of the json files at
> http://landsat-pds.s3.amazonaws.com/L8/010/020/LC80100202015018LGN00/LC80100202015018LGN00_MTL.json
> — Jed.
> Landsat-pds mailing list
> Landsat-pds at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/landsat-pds
and watch the world go round - Rush    | Geospatial Software Developer
More information about the Landsat-pds mailing list
