[Landsat-pds] Upcoming updates to Landsat on AWS data
Sundwall, Jed jed at amazon.com
Mon Sep 28 15:38:34 PDT 2015
I’ve reached out to USGS to ask if we can increase the limit.
Thanks for the update, Amit!
On Sep 28, 2015, at 12:16 PM, Amit Kapadia <amit at planet.com<mailto:amit at planet.com>> wrote:
Another update on the reingestion of these ~53,000 scenes. We've moving along faster than the initial few weeks. Currently we have ~28,500 scenes left to reprocess. This is taking a bit of time, mostly because USGS rate limits the number of scenes that can be simultaneously downloaded.
Jed - we often hit an error of this sort:
DOWNLOAD_RATE_LIMIT: User currently has more than 10 downloads that have not been attempted in the past 10 minutes.
If there's a way we can work with USGS on getting this type of rate-limiting lifted, I'll be able to spin up additional workers, breaking through this 10 scene limit. No big deal if that's not possible.
Cheers,
Amit
On Tue, Sep 15, 2015 at 10:58 AM, Amit Kapadia <amit at planet.com<mailto:amit at planet.com>> wrote:
We're ingesting about 1.35 scenes per minute (~2000 scenes per day). With 44,200 scenes remaining, this work should be complete in 22 - 23 days.
The additional worker has kicked up the rate. I'm learning more about the rate-limiting that USGS imposes, and it seems that a single machine is limited to 2 concurrent downloads (we already knew this). However, we have 3 machines running, so the rate-limiting appears to be a combination between IP address and EROS account.
Cheers,
Amit
On Mon, Sep 14, 2015 at 3:58 PM, Sundwall, Jed <jed at amazon.com<mailto:jed at amazon.com>> wrote:
Thanks for the update, Amit. Could you please let us know if you see that the extra workers have upped our rate? Also, if you can estimate when this would be done?
Thank you very much for your work on this!
Jed.
On Sep 14, 2015, at 2:16 PM, Amit Kapadia <amit at planet.com<mailto:amit at planet.com>> wrote:
Hi all - an update to the ingestion of these reprocessed Landsat scenes. Using the additional bandwidth that Jed locked down, we've ingested ~8,000 of the 52,877 scenes. This has been moving a little slow, so I've bumped up the number of workers.
In the past we've been restricted to 2 concurrent downloads from USGS servers, but it now seems that we're able to get 4 concurrent downloads. I'll try our luck with one more worker (2 more downloads) to see if we're allowed this luxury.
Ingestion of new Landsat scenes continues as normal.
Cheers,
Amit
On Wed, Aug 26, 2015 at 12:08 PM, Sundwall, Jed <jed at amazon.com<mailto:jed at amazon.com>> wrote:
Quick update:
We have been granted additional bandwidth to acquire Landsat data from EROS and will use it to reacquire 53,206 scenes that have been reprocessed with updated TIRS data as described at http://landsat.usgs.gov/calibration_notices.php
We will also use this opportunity to check for any scenes that we may have failed to acquire throughout 2015. Another user of the data recently pointed out that "USGS states that there are 149307 scenes so far in 2015, but AWS claims to host only 145746 of them. As a percentage, that is 97.6% - IOW 2.4% are missing.” These scenes may be missing from the bucket or they may merely be missing from the scene_list.gz file.
I’ll update the list once the reacquisition is complete.
Thanks,
Jed Sundwall – Open Data – Amazon Web Services
cell: 801-949-1482<tel:801-949-1482>
office: 206-435-3104<tel:206-435-3104>
https://aws.amazon.com/opendata/
Landsat-pds mailing list
Landsat-pds at lists.osgeo.org<mailto:Landsat-pds at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/landsat-pds
URL: <http://lists.osgeo.org/pipermail/landsat-pds/attachments/20150928/de3da7d5/attachment-0001.html>
More information about the Landsat-pds mailing list
