[Liblas-commits] r976 - in branches/1.0: . apps
liblas-commits at liblas.org
Fri Dec 26 00:16:44 EST 2008
Author: hobu
Date: Fri Dec 26 00:16:44 2008
New Revision: 976
URL: http://liblas.org/changeset/976
backport r975, add liblas-config script for #88
Added:
branches/1.0/apps/liblas-config.in
- copied unchanged from r975, /trunk/apps/liblas-config.in
branches/1.0/apps/Makefile.am
branches/1.0/configure.ac
Modified: branches/1.0/apps/Makefile.am
--- branches/1.0/apps/Makefile.am (original)
+++ branches/1.0/apps/Makefile.am Fri Dec 26 00:16:44 2008
@@ -10,8 +10,11 @@
las2txt_SOURCES = las2txt.c lascommon.c
txt2las_SOURCES = txt2las.c
bin_PROGRAMS = lasinfo las2las lasmerge las2txt txt2las
+bin_SCRIPTS = liblas-config
if GDAL_IS_CONFIG
las2ogr_SOURCES = las2ogr.cpp
bin_PROGRAMS += las2ogr
Modified: branches/1.0/configure.ac
--- branches/1.0/configure.ac (original)
+++ branches/1.0/configure.ac Fri Dec 26 00:16:44 2008
@@ -13,6 +13,7 @@
AC_CANONICAL_BUILD
RELEASE_VERSION=liblas_version
+AC_SUBST([RELEASE_VERSION])
dnl #########################################################################
dnl Default compilation flags
@@ -200,6 +201,7 @@
include/Makefile
src/Makefile
apps/Makefile
+ apps/liblas-config
test/Makefile
test/unit/Makefile
More information about the Liblas-commits
