[Liblas-commits] r975 - in trunk: . apps
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Dec 26 00:16:04 EST 2008
Author: hobu
Date: Fri Dec 26 00:16:04 2008
New Revision: 975
URL: http://liblas.org/changeset/975
add a liblas-config script #88
Added:
   trunk/apps/liblas-config.in
   trunk/apps/Makefile.am
   trunk/configure.ac
Modified: trunk/apps/Makefile.am
--- trunk/apps/Makefile.am	(original)
+++ trunk/apps/Makefile.am	Fri Dec 26 00:16:04 2008
@@ -10,8 +10,11 @@
 las2txt_SOURCES = las2txt.c lascommon.c
 txt2las_SOURCES = txt2las.c
 bin_PROGRAMS = lasinfo las2las lasmerge las2txt txt2las
+bin_SCRIPTS = liblas-config
 if GDAL_IS_CONFIG
 las2ogr_SOURCES = las2ogr.cpp
 bin_PROGRAMS += las2ogr
Added: trunk/apps/liblas-config.in
--- (empty file)
+++ trunk/apps/liblas-config.in	Fri Dec 26 00:16:04 2008
@@ -0,0 +1,53 @@
+#!/bin/sh
+usage()
+	cat <<EOF
+Usage: liblas-config [OPTIONS]
+Options:
+	[--libs]
+	[--cflags]
+	[--cxxflags]
+	[--defines]
+	[--includes]
+	[--version]
+EOF
+	exit $1
+if test $# -eq 0; then
+	usage 1 1>&2
+fi
+case $1 in
+  --libs)
+    echo @LIBS@
+  --defines)
+    echo @DEFS@
+  --includes)
+    echo @GEOTIFF_INC@ @GDAL_INC@
+  --cflags)
+    echo @CFLAGS@
+  --cxxflags)
+    echo @CXXFLAGS@
+  --version)
+    echo @RELEASE_VERSION@
+    usage 1 1>&2
+esac
Modified: trunk/configure.ac
--- trunk/configure.ac	(original)
+++ trunk/configure.ac	Fri Dec 26 00:16:04 2008
@@ -13,6 +13,7 @@
 AC_CANONICAL_BUILD
 RELEASE_VERSION=liblas_version
+AC_SUBST([RELEASE_VERSION])
 dnl #########################################################################
 dnl Default compilation flags
@@ -200,6 +201,7 @@
     include/Makefile
     src/Makefile
     apps/Makefile
+    apps/liblas-config
     test/Makefile
     test/unit/Makefile
More information about the Liblas-commits mailing list
