[Liblas-commits] r1191 - in trunk: . build/cmake src
liblas-commits at liblas.org
Thu Apr 9 09:59:56 EDT 2009
Author: mloskot
Date: Thu Apr 9 09:59:48 2009
New Revision: 1191
URL: http://liblas.org/changeset/1191
Updated CMake build configuration - work in progress.
trunk/CMakeLists.txt
trunk/build/cmake/FindGeoTIFF.cmake
trunk/src/CMakeLists.txt
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt (original)
+++ trunk/CMakeLists.txt Thu Apr 9 09:59:48 2009
@@ -18,7 +18,7 @@
SET( CMAKE_COLOR_MAKEFILE ON )
-# set path to additional CMake modules
+# Path to additional CMake modules
SET(CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/build/cmake ${CMAKE_MODULE_PATH})
@@ -31,9 +31,6 @@
FORCE)
ENDIF(NOT CMAKE_BUILD_TYPE)
-# Enable CTest to run libLas Unit Test Suite
-#ENABLE_TESTING()
# Platform and compiler specific settings
@@ -47,6 +44,7 @@
ADD_DEFINITIONS( /D_CRT_NONSTDC_NO_WARNING )
ENDIF (MSVC80)
ENDIF (MSVC)
ELSE (WIN32)
IF (CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
@@ -63,16 +61,15 @@
# Search for dependencies
-# optinal GeoTIFF support
+# GeoTIFF support (optional)
FIND_PACKAGE(GeoTIFF)
IF (GEOTIFF_FOUND)
#TODO: Use to generate config.h
#SET (HAVE_LIBGEOTIFF TRUE)
ADD_DEFINITIONS( -D HAVE_LIBGEOTIFF )
ENDIF (GEOTIFF_FOUND)
+# GDAL support (optional)
FIND_PACKAGE(GDAL)
IF (GDAL_FOUND)
@@ -93,9 +90,7 @@
+IF (XXX_FOUND)
########## THE HUGE BLOCK BELOW IS TO LEARN CMAKE AND WILL BE REMOVED ###############
# ------------------------- Begin Generic CMake Variable Logging ------------------
@@ -247,3 +242,4 @@
MESSAGE( STATUS "=============== END TEST VARIABLES LOGGING OUTPUT ===============" )
# ------------------------- End of Generic CMake Variable Logging ------------------
+ENDIF (XXX_FOUND)
Modified: trunk/build/cmake/FindGeoTIFF.cmake
--- trunk/build/cmake/FindGeoTIFF.cmake (original)
+++ trunk/build/cmake/FindGeoTIFF.cmake Thu Apr 9 09:59:48 2009
@@ -15,36 +15,39 @@
FIND_PATH(GEOTIFF_INCLUDE_DIR geotiff.h
"$ENV{LIB_DIR}/include"
"$ENV{LIB_DIR}/include/geotiff"
- #mingw
+ # MinGW
c:/msys/local/include
NO_DEFAULT_PATH
FIND_PATH(GEOTIFF_INCLUDE_DIR geotiff.h)
SET(GEOTIFF_NAMES ${GEOTIFF_NAMES} geotiff geotiff_i)
FIND_LIBRARY(GEOTIFF_LIBRARY NAMES ${GEOTIFF_NAMES} PATHS
"$ENV{LIB_DIR}/lib"
- #mingw
+ # MinGW
c:/msys/local/lib
NO_DEFAULT_PATH
FIND_LIBRARY(GEOTIFF_LIBRARY NAMES ${GEOTIFF_NAMES})
IF (GEOTIFF_INCLUDE_DIR AND GEOTIFF_LIBRARY)
- SET(GEOTIFF_FOUND TRUE)
+ SET(GEOTIFF_FOUND TRUE)
ENDIF (GEOTIFF_INCLUDE_DIR AND GEOTIFF_LIBRARY)
IF (GEOTIFF_FOUND)
- IF (NOT GEOTIFF_FIND_QUIETLY)
- MESSAGE(STATUS "Found GeoTIFF: ${GEOTIFF_LIBRARY}")
- ENDIF (NOT GEOTIFF_FIND_QUIETLY)
+ IF (NOT GEOTIFF_FIND_QUIETLY)
+ MESSAGE(STATUS "Found GeoTIFF: ${GEOTIFF_LIBRARY}")
+ ENDIF (NOT GEOTIFF_FIND_QUIETLY)
ELSE (GEOTIFF_FOUND)
- IF (GEOTIFF_FIND_REQUIRED)
- MESSAGE(FATAL_ERROR "Could not find GeoTIFF library")
- ENDIF (GEOTIFF_FIND_REQUIRED)
+ MESSAGE(STATUS "GeoTIFF library not found")
+ IF (GEOTIFF_FIND_REQUIRED)
+ MESSAGE(FATAL_ERROR "GeoTIFF library is required")
+ ENDIF (GEOTIFF_FIND_REQUIRED)
Modified: trunk/src/CMakeLists.txt
--- trunk/src/CMakeLists.txt (original)
+++ trunk/src/CMakeLists.txt Thu Apr 9 09:59:48 2009
@@ -7,18 +7,19 @@
SET( LIBLAS_HPP
../include/liblas/cstdint.hpp
+ ../include/liblas/exception.hpp
../include/liblas/guid.hpp
../include/liblas/iterator.hpp
+ ../include/liblas/lascolor.hpp
../include/liblas/laserror.hpp
../include/liblas/lasfile.hpp
../include/liblas/lasheader.hpp
../include/liblas/laspoint.hpp
- ../include/liblas/lasvariablerecord.hpp
../include/liblas/lasreader.hpp
+ ../include/liblas/lasspatialreference.hpp
../include/liblas/laswriter.hpp
../include/liblas/liblas.hpp
- ../include/liblas/lasspatialreference.hpp
SET( LIBLAS_DETAIL_HPP
@@ -40,17 +41,20 @@
SET( LIBLAS_CPP
+ lascolor.cpp
laserror.cpp
- laspoint.cpp
+ lasfile.cpp
lasheader.cpp
- lasrecordheader.cpp
+ laspoint.cpp
lasreader.cpp
+ lasspatialreference.cpp
+ lasvariablerecord.cpp
laswriter.cpp
- lasfile.cpp
- lasspatialreference.cpp
+# TODO: add IF GDAL_FOUND += gt_wkt_srs.cp
SET( LIBLAS_DETAIL_CPP
+ detail/file.cpp
detail/reader.cpp
detail/reader10.cpp
detail/reader11.cpp
@@ -59,7 +63,6 @@
detail/writer10.cpp
detail/writer11.cpp
detail/writer12.cpp
- detail/file.cpp
SET( LIBLAS_SOURCES
More information about the Liblas-commits
