[Liblas-commits] r1192 - in trunk: . src test/unit
liblas-commits at liblas.org
Thu Apr 9 10:32:34 EDT 2009
Author: mloskot
Date: Thu Apr 9 10:32:33 2009
New Revision: 1192
URL: http://liblas.org/changeset/1192
Updated CMake build configuration, so it is now possible to build libLAS using CMake with and without GeoTIFF support. Unit tests suite builds too.
trunk/CMakeLists.txt
trunk/src/CMakeLists.txt
trunk/test/unit/CMakeLists.txt
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt (original)
+++ trunk/CMakeLists.txt Thu Apr 9 10:32:33 2009
@@ -8,8 +8,8 @@
PROJECT( libLAS )
-SET( LIBLAS_LIB_NAME liblas )
-SET( LIBLAS_C_LIB_NAME liblas_c )
+SET( LIBLAS_LIB_NAME las )
+SET( LIBLAS_C_LIB_NAME las_c )
# CMake settings
@@ -35,7 +35,6 @@
# Platform and compiler specific settings
IF (WIN32)
ADD_DEFINITIONS( /W4 )
IF (MSVC)
@@ -44,17 +43,14 @@
ADD_DEFINITIONS( /D_CRT_NONSTDC_NO_WARNING )
ENDIF (MSVC80)
ENDIF (MSVC)
ELSE (WIN32)
IF (CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
ADD_DEFINITIONS( -Wall -Wno-long-long -pedantic -ansi )
IF (CMAKE_COMPILER_IS_GNUCXX)
SET( CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++98" )
ENDIF (CMAKE_COMPILER_IS_GNUCXX)
ENDIF (CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
ENDIF (WIN32)
Modified: trunk/src/CMakeLists.txt
--- trunk/src/CMakeLists.txt (original)
+++ trunk/src/CMakeLists.txt Thu Apr 9 10:32:33 2009
@@ -88,9 +88,15 @@
ADD_DEFINITIONS( /Za )
ENDIF (WIN32)
+# Configure GeoTIFF support (optional)
+IF (GEOTIFF_FOUND)
+ INCLUDE_DIRECTORIES( ${GEOTIFF_INCLUDE_DIR} )
+ELSE (GEOTIFF_FOUND)
+ SET(GEOTIFF_LIBRARY "")
+ENDIF (GEOTIFF_FOUND)
../include
- ${GEOTIFF_INCLUDE_DIR}
# Static library with libLAS C++ core
@@ -102,3 +108,4 @@
${LIBLAS_LIB_NAME}
${GEOTIFF_LIBRARY}
Modified: trunk/test/unit/CMakeLists.txt
--- trunk/test/unit/CMakeLists.txt (original)
+++ trunk/test/unit/CMakeLists.txt Thu Apr 9 10:32:33 2009
@@ -13,6 +13,7 @@
laspoint_test.cpp
lasreader_iterator_test.cpp
lasreader_test.cpp
+ lasspatialreference_test.cpp
lasvariablerecord_test.cpp
laswriter_test.cpp
liblas_test_suite.cpp
@@ -25,7 +26,10 @@
ADD_EXECUTABLE( ${LIBLAS_TEST} ${LIBLAS_TEST_SRC} )
-TARGET_LINK_LIBRARIES( ${LIBLAS_TEST} ${LIBLAS_LIB_NAME} )
+TARGET_LINK_LIBRARIES( ${LIBLAS_TEST}
+ ${LIBLAS_LIB_NAME}
+ ${GEOTIFF_LIBRARY}
# TODO: Needs to tweak the executable path
ADD_TEST(liblas_test ${EXECUTABLE_OUTPUT_PATH}/liblas_test)
More information about the Liblas-commits
