[Liblas-commits] r1205 - trunk/apps
liblas-commits at liblas.org
Mon Apr 13 12:11:42 EDT 2009
Author: hobu
Date: Mon Apr 13 12:11:41 2009
New Revision: 1205
URL: http://liblas.org/changeset/1205
add ts2las
Added:
trunk/apps/ts2las.cpp
trunk/apps/ts2las.hpp
trunk/apps/Makefile.am
Modified: trunk/apps/Makefile.am
--- trunk/apps/Makefile.am (original)
+++ trunk/apps/Makefile.am Mon Apr 13 12:11:41 2009
@@ -13,9 +13,10 @@
lasmerge_SOURCES = lasmerge.c lascommon.c
las2txt_SOURCES = las2txt.c lascommon.c
txt2las_SOURCES = txt2las.c
+ts2las_SOURCES = ts2las.cpp
-bin_PROGRAMS = lasinfo las2las lasmerge las2txt txt2las
+bin_PROGRAMS = lasinfo las2las lasmerge las2txt txt2las ts2las
bin_SCRIPTS = liblas-config
Added: trunk/apps/ts2las.cpp
--- (empty file)
+++ trunk/apps/ts2las.cpp Mon Apr 13 12:11:41 2009
@@ -0,0 +1,233 @@
+#include "ts2las.hpp"
+#include <fstream>
+#include <iostream>
+#include <string>
+using namespace liblas;
+std::istream* OpenInput(std::string filename)
+ std::ios::openmode const mode = std::ios::in | std::ios::binary;
+ std::istream* istrm;
+ if (compare_no_case(filename.c_str(),"STDIN",5) == 0)
+ istrm = &std::cin;
+ else
+ istrm = new std::ifstream(filename.c_str(), mode);
+ if (!istrm->good())
+ delete istrm;
+ throw std::runtime_error("Reading stream was not able to be created");
+ return istrm;
+std::ostream* OpenOutput(std::string filename)
+ std::ostream* ostrm;
+ std::ios::openmode m;
+ m = std::ios::out | std::ios::binary | std::ios::ate;
+ if (compare_no_case(filename.c_str(),"STOUT",5) == 0)
+ ostrm = &std::cout;
+ else
+ ostrm = new std::ofstream(filename.c_str(), m);
+ if (!ostrm->good())
+ delete ostrm;
+ throw std::runtime_error("Writing stream was not able to be created");
+ return ostrm;
+LASHeader CreateHeader(ScanHdr* hdr)
+ LASHeader header;
+ // Checks for time and color values
+ liblas::LASHeader::PointFormat format = liblas::LASHeader::ePointFormat0;
+ if (hdr->Time) {
+ if (hdr->Color) {
+ format = liblas::LASHeader::ePointFormat3;
+ } else {
+ format = liblas::LASHeader::ePointFormat1;
+ } else if (hdr->Color) {
+ format = liblas::LASHeader::ePointFormat2;
+ header.SetVersionMinor(2);
+ header.SetDataFormatId(format);
+ header.SetPointRecordsCount(hdr->PntCnt);
+ header.SetOffset(hdr->OrgX, hdr->OrgY, hdr->OrgZ);
+ std::cout << "offset x: " << header.GetOffsetX() << " offset y: " << header.GetOffsetY() << " offset z: " <<header.GetOffsetZ() << std::endl;
+ std::cout << "units: " << hdr->Units << std::endl;
+ std::cout << "format: " << format << std::endl;
+ return header;
+bool ReadHeader(ScanHdr* hdr, std::istream* istrm) {
+ try {
+ liblas::detail::read_n(*hdr, *istrm, sizeof(ScanHdr));
+ if (hdr->Tunniste != 970401) return false;
+ if (memcmp(hdr->Magic,"CXYZ",4)) return false;
+ int version = hdr->HdrVersion;
+ if (version == 970404) return true;
+ if (version == 20010129) return true;
+ if (version == 20010712) return true;
+ if (version == 20020715) return true;
+ if (( version > 20020715) && (version < 20051231)) return true;
+ return false;
+ catch (std::exception const& e)
+ return false;
+ return true;
+bool WritePoints(LASWriter* writer, std::istream* strm, ScanHdr* hdr)
+ while (true) {
+ if (hdr->HdrVersion == 20020715) {
+///std::cout << "We have header version" << std::endl;
+ ScanPnt* point = new ScanPnt;
+ try
+ std::cout << "stream position is: " << strm->tellg() << std::endl;
+ detail::read_n(*point, *strm, sizeof(ScanPnt));
+ LASPoint p;
+ p.SetCoordinates(writer->GetHeader(),point->Pnt.x,point->Pnt.y,point->Pnt.z);
+ std::cout << "x: " << point->Pnt.x << " y: "<< point->Pnt.y << " z: " <<point->Pnt.z<< std::endl;
+ std::cout << "x: " << p.GetX() << " y: "<< p.GetY() << " z: " <<p.GetZ()<< std::endl;
+ std::cout << "Code: " << point->Code << " Intensity: "<< point->Intensity << std::endl;
+ p.SetClassification(point->Code);
+ p.SetIntensity(point->Intensity);
+ writer->WritePoint(p);
+ exit(-1);
+ // std::cout << "Wrote point"<< std::endl;
+ catch (std::out_of_range const& e) // we reached the end of the file
+ std::cout << "catching out of range error!" ;
+ break;
+ catch (std::exception const& e) // we reached the end of the file
+ std::cout << e.what() << std::endl;
+ break;
+ // Reader::FillPoint(record, point);
+ // point.SetCoordinates(header, point.GetX(), point.GetY(), point.GetZ());
+ // if (header.GetDataFormatId() == LASHeader::ePointFormat1) {
+ // detail::read_n(t, m_ifs, sizeof(double));
+ // point.SetTime(t);
+ return true;
+void usage() {}
+int main(int argc, char* argv[])
+ int rc = 0;
+ std::string input;
+ std::string output;
+ for (int i = 1; i < argc; i++) {
+ if ( strcmp(argv[i],"-h") == 0 ||
+ strcmp(argv[i],"--help") == 0
+ usage();
+ exit(0);
+ else if ( strcmp(argv[i],"--input") == 0 ||
+ strcmp(argv[i],"-input") == 0 ||
+ strcmp(argv[i],"-i") == 0 ||
+ strcmp(argv[i],"-in") == 0
+ i++;
+ input = std::string(argv[i]);
+ else if ( strcmp(argv[i],"--output") == 0 ||
+ strcmp(argv[i],"--out") == 0 ||
+ strcmp(argv[i],"-out") == 0 ||
+ strcmp(argv[i],"-o") == 0
+ i++;
+ output = std::string(argv[i]);
+ else if (i == argc - 2 && output.empty() && input.empty())
+ else if (i == argc - 1 && output.empty() && input.empty())
+ else
+ usage();
+ exit(1);
+ std::cout << "input: " << input<< " output: " <<output<<std::endl;
+ ScanHdr* hdr = new ScanHdr;
+ std::istream* istrm = OpenInput(input);
+ std::ostream* ostrm = OpenOutput(output);
+ bool success;
+ success = ReadHeader(hdr, istrm);
+ if (!success)
+ std::cout<<"header was not read! exiting" << std::cout; exit(1);
+ std::cout << "stream position is: " << istrm->tellg() << std::endl;
+ LASHeader header = CreateHeader(hdr);
+ LASWriter* writer = new LASWriter(*ostrm, header);
+ success = WritePoints(writer, istrm, hdr);
+ std::cout << "Point Count: " << hdr->PntCnt <<std::endl;
+ std::cout << "success: " << success << std::endl;
+ return rc;
\ No newline at end of file
Added: trunk/apps/ts2las.hpp
--- (empty file)
+++ trunk/apps/ts2las.hpp Mon Apr 13 12:11:41 2009
@@ -0,0 +1,199 @@
+#ifndef TS2LAS_HPP_INCLUDED
+#include <liblas/cstdint.hpp>
+#include <liblas/detail/utility.hpp>
+#include <liblas/laswriter.hpp>
+#include <liblas/laspoint.hpp>
+#include <liblas/lascolor.hpp>
+#ifdef _WIN32
+#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
+#else
+#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
+#endif
+struct ScanRow
+ ScanRow() :
+ Code(0),
+ Line(0),
+ EchoInt(0),
+ x(0),
+ y(0),
+ z(0)
+ liblas::uint8_t Code;
+ liblas::uint8_t Line;
+ liblas::uint16_t EchoInt;
+ liblas::int32_t x;
+ liblas::int32_t y;
+ liblas::int32_t z;
+struct Point3d
+ Point3d() :
+ x(0),
+ y(0),
+ z(0)
+struct ScanPnt
+ ScanPnt() :
+ Code(0),
+ Echo(0),
+ Flag(0),
+ Mark(0),
+ Line(0),
+ Intensity(0)
+ Point3d Pnt;
+ liblas::uint8_t Echo;
+ liblas::uint8_t Flag;
+ liblas::uint8_t Mark;
+ liblas::uint16_t Line;
+ liblas::uint16_t Intensity;
+struct ScanHdr
+ ScanHdr() :
+ HdrSize(0),
+ HdrVersion(0),
+ Tunniste(0),
+ PntCnt(0),
+ Units(0),
+ OrgX(0),
+ OrgY(0),
+ OrgZ(0),
+ Time(0),
+ Color(0)
+ liblas::int32_t HdrSize;
+ liblas::int32_t HdrVersion;
+ liblas::int32_t Tunniste;
+ char Magic[4];
+ liblas::int32_t PntCnt;
+ liblas::int32_t Units;
+ double OrgX;
+ double OrgY;
+ double OrgZ;
+ liblas::int32_t Time;
+ liblas::int32_t Color;
+ // int HdrSize;
+ // int HdrVersion;
+ // int Tunniste;
+ // char Magic[4];
+ // int PntCnt;
+ // int Units;
+ // double OrgX;
+ // double OrgY;
+ // double OrgZ;
+ // int Time;
+ // int Color;
+namespace liblas { namespace detail {
+template <>
+inline void read_n <ScanRow>(ScanRow& dest, std::istream& src, std::streamsize const& num)
+ // TODO: Review and redesign errors handling logic if necessary
+ if (!src)
+ throw std::runtime_error("detail::liblas::read_n<ScanRow> input stream is not readable");
+ src.read(detail::as_buffer(dest), num);
+ detail::check_stream_state(src);
+ // Fix little-endian
+ LIBLAS_SWAP_BYTES(dest.x);
+ LIBLAS_SWAP_BYTES(dest.y);
+ LIBLAS_SWAP_BYTES(dest.z);
+ LIBLAS_SWAP_BYTES(dest.Code);
+ LIBLAS_SWAP_BYTES(dest.Line);
+ LIBLAS_SWAP_BYTES(dest.EchoInt);
+template <>
+inline void read_n <ScanPnt>(ScanPnt& dest, std::istream& src, std::streamsize const& num)
+ if (!src)
+ throw std::runtime_error("detail::liblas::read_n<ScanPnt> input stream is not readable");
+ std::cout << "ScanPnt stream position is: " << src.tellg() << std::endl;
+ LIBLAS_SWAP_BYTES(dest.Pnt.x);
+ LIBLAS_SWAP_BYTES(dest.Pnt.y);
+ LIBLAS_SWAP_BYTES(dest.Pnt.z);
+ LIBLAS_SWAP_BYTES(dest.Echo);
+ LIBLAS_SWAP_BYTES(dest.Flag);
+ LIBLAS_SWAP_BYTES(dest.Mark);
+ LIBLAS_SWAP_BYTES(dest.Intensity);
+ std::cout << "x: " << dest.Pnt.x << " y: " << dest.Pnt.y << " z: " << dest.Pnt.z <<std::endl;
+template <>
+inline void read_n <ScanHdr>(ScanHdr& dest, std::istream& src, std::streamsize const& num)
+ if (!src)
+ throw std::runtime_error("detail::liblas::read_n<ScanHdr> input stream is not readable");
+ std::cout << "ScanHdr stream position is: " << src.tellg() << std::endl;
+ LIBLAS_SWAP_BYTES(dest.HdrSize);
+ LIBLAS_SWAP_BYTES(dest.HdrVersion);
+ LIBLAS_SWAP_BYTES(dest.Tunniste);
+ LIBLAS_SWAP_BYTES(dest.Magic);
+ LIBLAS_SWAP_BYTES(dest.PntCnt);
+ LIBLAS_SWAP_BYTES(dest.Units);
+ LIBLAS_SWAP_BYTES(dest.Time);
+ LIBLAS_SWAP_BYTES(dest.Color);
+}} // namespace liblas::detail
+#endif // TS2LAS_HPP_INCLUDED
More information about the Liblas-commits
