[Liblas-commits] r1206 - trunk/apps
liblas-commits at liblas.org
Mon Apr 13 22:41:47 EDT 2009
Author: hobu
Date: Mon Apr 13 22:41:46 2009
New Revision: 1206
URL: http://liblas.org/changeset/1206
more updates. messy, but mostly working
trunk/apps/ts2las.cpp
trunk/apps/ts2las.hpp
Modified: trunk/apps/ts2las.cpp
--- trunk/apps/ts2las.cpp (original)
+++ trunk/apps/ts2las.cpp Mon Apr 13 22:41:46 2009
@@ -72,11 +72,13 @@
header.SetVersionMinor(2);
header.SetDataFormatId(format);
- header.SetPointRecordsCount(hdr->PntCnt);
+ // header.SetPointRecordsCount(hdr->PntCnt);
header.SetOffset(hdr->OrgX, hdr->OrgY, hdr->OrgZ);
std::cout << "offset x: " << header.GetOffsetX() << " offset y: " << header.GetOffsetY() << " offset z: " <<header.GetOffsetZ() << std::endl;
std::cout << "units: " << hdr->Units << std::endl;
std::cout << "format: " << format << std::endl;
+ double scale = 1.0/hdr->Units;
+ header.SetScale(scale, scale, scale);
return header;
bool ReadHeader(ScanHdr* hdr, std::istream* istrm) {
@@ -107,48 +109,101 @@
while (true) {
- if (hdr->HdrVersion == 20020715) {
///std::cout << "We have header version" << std::endl;
ScanPnt* point = new ScanPnt;
+ ScanRow* row = new ScanRow;
try
- std::cout << "stream position is: " << strm->tellg() << std::endl;
- detail::read_n(*point, *strm, sizeof(ScanPnt));
+ // std::cout << "stream position is: " << strm->tellg() << std::endl;
+ if (hdr->HdrVersion == 20020715) {
+ detail::read_n(*point, *strm, sizeof(ScanPnt));
+ } else{
+ detail::read_n(*row, *strm, sizeof(ScanRow));
+ point->Pnt.x = row->x;
+ point->Pnt.y = row->y;
+ point->Pnt.z = row->z;
+ point->Code = row->Code;
+ point->Line = row->Line;
+ point->Intensity = row->EchoInt & 0x3FFF;
+ point->Echo = (row->EchoInt >> 14);
LASPoint p;
p.SetCoordinates(writer->GetHeader(),point->Pnt.x,point->Pnt.y,point->Pnt.z);
- std::cout << "x: " << point->Pnt.x << " y: "<< point->Pnt.y << " z: " <<point->Pnt.z<< std::endl;
- std::cout << "x: " << p.GetX() << " y: "<< p.GetY() << " z: " <<p.GetZ()<< std::endl;
- std::cout << "Code: " << point->Code << " Intensity: "<< point->Intensity << std::endl;
+ // std::cout << "x: " << point->Pnt.x << " y: "<< point->Pnt.y << " z: " <<point->Pnt.z<< std::endl;
+ // std::cout << "x: " << p.GetX() << " y: "<< p.GetY() << " z: " <<p.GetZ()<< std::endl;
+ // std::cout << "Code: " << point->Code << " Intensity: "<< point->Intensity << std::endl;
p.SetClassification(point->Code);
p.SetIntensity(point->Intensity);
- writer->WritePoint(p);
- exit(-1);
- // std::cout << "Wrote point"<< std::endl;
+ if (hdr->Time) {
+ liblas::uint32_t t = 0xFFFFFFFF;
+ detail::read_n(t, *strm, sizeof(t));
+ // Time stamps are assumed to be GPS week seconds. The
+ // storage format is a 32 bit unsigned integer where
+ // each integer step is 0.0002 seconds.
+ p.SetTime(t*0.0002);
+ if (hdr->Color) {
+ liblas::uint8_t r, g, b, a = 0;
+ LASColor color;
+ detail::read_n(r, *strm, sizeof(r));
+ detail::read_n(b, *strm, sizeof(b));
+ detail::read_n(g, *strm, sizeof(g));
+ // TS .bin says to read 4 bytes here for some reason. Maybe
+ // this is an alpha value or something
+ detail::read_n(a, *strm, sizeof(a));
+ color.SetGreen(g);
+ color.SetBlue(b);
+ color.SetRed(r);
+ p.SetColor(color);
+ // Set return number
+ TerraScan uses two bits for storing echo information. The possible values are:
+ 0 Only echo
+ 1 First of many echo
+ 2 Intermediate echo
+ 3 Last of many echo
+ if (point->Echo == 0) {
+ p.SetNumberOfReturns(1);
+ p.SetReturnNumber(1);
+ } else if (point->Echo == 1) {
+ } else if (point->Echo == 3) {
+ p.SetReturnNumber(5);
+ p.SetNumberOfReturns(5);
+ } else {
+ // I don't know what the hell to do here without cumulating
+ // through all of the points. Why wouldn't you store the return
+ // number?!
+ p.SetReturnNumber(3);
+ try {
+ writer->WritePoint(p);
+ } catch (std::exception const& e)
+ std::cout << "Point writing failed!" << std::endl;
catch (std::out_of_range const& e) // we reached the end of the file
std::cout << "catching out of range error!" ;
- break;
+ return true;
+ // break;
catch (std::exception const& e) // we reached the end of the file
std::cout << e.what() << std::endl;
break;
- // Reader::FillPoint(record, point);
- // point.SetCoordinates(header, point.GetX(), point.GetY(), point.GetZ());
- // if (header.GetDataFormatId() == LASHeader::ePointFormat1) {
- // detail::read_n(t, m_ifs, sizeof(double));
- // point.SetTime(t);
return true;
@@ -225,9 +280,12 @@
LASHeader header = CreateHeader(hdr);
LASWriter* writer = new LASWriter(*ostrm, header);
- success = WritePoints(writer, istrm, hdr);
+ success = WritePoints(writer, istrm, hdr);
+ delete writer;
+ delete ostrm;
+ delete istrm;
- std::cout << "Point Count: " << hdr->PntCnt <<std::endl;
+ std::cout << "Point Count: " << header.GetPointRecordsCount() <<std::endl;
std::cout << "success: " << success << std::endl;
return rc;
\ No newline at end of file
Modified: trunk/apps/ts2las.hpp
--- trunk/apps/ts2las.hpp (original)
+++ trunk/apps/ts2las.hpp Mon Apr 13 22:41:46 2009
@@ -146,13 +146,9 @@
if (!src)
throw std::runtime_error("detail::liblas::read_n<ScanPnt> input stream is not readable");
- std::cout << "ScanPnt stream position is: " << src.tellg() << std::endl;
src.read(detail::as_buffer(dest), num);
detail::check_stream_state(src);
// Fix little-endian
LIBLAS_SWAP_BYTES(dest.Pnt.x);
LIBLAS_SWAP_BYTES(dest.Pnt.y);
@@ -164,8 +160,6 @@
LIBLAS_SWAP_BYTES(dest.Line);
LIBLAS_SWAP_BYTES(dest.Intensity);
- std::cout << "x: " << dest.Pnt.x << " y: " << dest.Pnt.y << " z: " << dest.Pnt.z <<std::endl;
template <>
@@ -175,11 +169,7 @@
if (!src)
throw std::runtime_error("detail::liblas::read_n<ScanHdr> input stream is not readable");
- std::cout << "ScanHdr stream position is: " << src.tellg() << std::endl;
More information about the Liblas-commits
