[Liblas-commits] r1207 - trunk/apps
liblas-commits at liblas.org
Tue Apr 14 23:02:30 EDT 2009
Author: hobu
Date: Tue Apr 14 23:02:27 2009
New Revision: 1207
URL: http://liblas.org/changeset/1207
make sure to properly scale the points
trunk/apps/ts2las.cpp
Modified: trunk/apps/ts2las.cpp
--- trunk/apps/ts2las.cpp (original)
+++ trunk/apps/ts2las.cpp Tue Apr 14 23:02:27 2009
@@ -77,7 +77,8 @@
std::cout << "offset x: " << header.GetOffsetX() << " offset y: " << header.GetOffsetY() << " offset z: " <<header.GetOffsetZ() << std::endl;
std::cout << "units: " << hdr->Units << std::endl;
std::cout << "format: " << format << std::endl;
- double scale = 1.0/hdr->Units;
+ double scale = 1.0/(double)hdr->Units;
+ std::cout << "scale: " << scale << std::endl;
header.SetScale(scale, scale, scale);
return header;
@@ -129,7 +130,11 @@
point->Echo = (row->EchoInt >> 14);
LASPoint p;
- p.SetCoordinates(writer->GetHeader(),point->Pnt.x,point->Pnt.y,point->Pnt.z);
+ p.SetCoordinates(
+ (point->Pnt.x-hdr->OrgX)/(double)hdr->Units,
+ (point->Pnt.y-hdr->OrgY)/(double)hdr->Units,
+ (point->Pnt.z-hdr->OrgZ)/(double)hdr->Units);
// std::cout << "x: " << point->Pnt.x << " y: "<< point->Pnt.y << " z: " <<point->Pnt.z<< std::endl;
// std::cout << "x: " << p.GetX() << " y: "<< p.GetY() << " z: " <<p.GetZ()<< std::endl;
// std::cout << "Code: " << point->Code << " Intensity: "<< point->Intensity << std::endl;
More information about the Liblas-commits
