[Liblas-commits] r1209 - trunk/src/detail
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Apr 15 10:27:05 EDT 2009
Author: mloskot
Date: Wed Apr 15 10:27:05 2009
New Revision: 1209
URL: http://liblas.org/changeset/1209
* Initialize objects of LASColor using new constructor (#130).
* Tighten variables to as local scope as possible, to gain better optimization. A little refactoring.
* TODO:
** mloskot, you really need to move your arse and removing redundant and repeated code!
** Also, exception ticket (#12) has been waiting for too long. Don't forget to send what() messages somewhere like std::log to give users a chance to generate log files.
   trunk/src/detail/reader10.cpp
   trunk/src/detail/reader11.cpp
   trunk/src/detail/reader12.cpp
Modified: trunk/src/detail/reader10.cpp
--- trunk/src/detail/reader10.cpp	(original)
+++ trunk/src/detail/reader10.cpp	Wed Apr 15 10:27:05 2009
@@ -146,19 +146,24 @@
     // 16. Point Data Format ID
     read_n(n1, m_ifs, sizeof(n1));
-    if (n1 == LASHeader::ePointFormat0) {
+    if (n1 == LASHeader::ePointFormat0)
         header.SetDataFormatId(LASHeader::ePointFormat0);
-    else if (n1 == LASHeader::ePointFormat1) {
+    else if (n1 == LASHeader::ePointFormat1)
         header.SetDataFormatId(LASHeader::ePointFormat1);
-    else if (n1 == LASHeader::ePointFormat2) {
+    else if (n1 == LASHeader::ePointFormat2)
         header.SetDataFormatId(LASHeader::ePointFormat2);
-    else if (n1 == LASHeader::ePointFormat3) {
+    else if (n1 == LASHeader::ePointFormat3)
         header.SetDataFormatId(LASHeader::ePointFormat3);
-    else {
+    else
         throw std::domain_error("invalid point data format");
@@ -212,58 +217,48 @@
     // a fucking mess -- hobu.
     m_has_pad_bytes = false;
-    try {
+    try
         SkipPointDataSignature();
         m_has_pad_bytes = true;
-    catch (std::out_of_range const& e)
+    catch (std::out_of_range const&)
         // Ignore the out_of_range here for the case of a
         // file with just a header and no pad
-    catch (std::runtime_error const& e)
+    catch (std::runtime_error const&)
         // Ignore the runtime_error here for the case of a
         // This is what is thrown when we compile *without* debug
-    catch (std::domain_error const& e)
+    catch (std::domain_error const&)
         // TODO: We'll want to put this error on the validation errors stack
         // but for now, we'll just move back to the offset
     Reset(header);
     return true;
 bool ReaderImpl::ReadNextPoint(LASPoint& point, const LASHeader& header)
-    // Read point data record format 0
-    // TODO: Replace with compile-time assert
-    detail::PointRecord record;
-    double t=0;
-    assert(LASHeader::ePointSize0 == sizeof(record));
     if (0 == m_current)
         m_ifs.clear();
         m_ifs.seekg(m_offset, std::ios::beg);
         // The 1.0 version *requires* the pad bytes, but in
         // many instances, there are files without them.  What
-        try {
+        try
@@ -273,6 +268,10 @@
     if (m_current < m_size)
+        detail::PointRecord record;
+        // TODO: Replace with compile-time assert
+        assert(LASHeader::ePointSize0 == sizeof(record));
         try
             detail::read_n(record, m_ifs, sizeof(PointRecord));
@@ -286,10 +285,13 @@
         Reader::FillPoint(record, point);
         point.SetCoordinates(header, point.GetX(), point.GetY(), point.GetZ());
-        if (header.GetDataFormatId() == LASHeader::ePointFormat1) {
-            detail::read_n(t, m_ifs, sizeof(double));
-            point.SetTime(t);
+        if (header.GetDataFormatId() == LASHeader::ePointFormat1)
+            double gpst(0);
+            detail::read_n(gpst, m_ifs, sizeof(double));
+            point.SetTime(gpst);
         return true;
@@ -299,28 +301,29 @@
 bool ReaderImpl::ReadPointAt(std::size_t n, LASPoint& point, const LASHeader& header)
-    double t=0;
     if (m_size <= n)
         return false;
-    std::streamsize pos = (static_cast<std::streamsize>(n) * m_recordlength) + m_offset;
+    std::streamsize pos = (static_cast<std::streamsize>(n) * m_recordlength) + m_offset;
     m_ifs.clear();
     m_ifs.seekg(pos, std::ios::beg);
     detail::read_n(record, m_ifs, sizeof(record));
-        point.SetTime(t);
+        double gpst(0);
     return true;
Modified: trunk/src/detail/reader11.cpp
--- trunk/src/detail/reader11.cpp	(original)
+++ trunk/src/detail/reader11.cpp	Wed Apr 15 10:27:05 2009
@@ -150,19 +150,24 @@
     // 17. Point Data Format ID
-    else {
+    else
@@ -214,56 +219,50 @@
     m_ifs.seekg(header.GetDataOffset(), std::ios::beg);
-    try {
+    try
         // If this call succeeds, we'll want to put this on the
         // validation errors stack.  1.1 files shouldn't have
         // pad bytes.
+        // TODO: We'll want to put this error on the validation errors stack
+        // but for now, we'll just move back to the offset
     Reset(header);
     return true;
-    double t = 0;
     if (0 == m_current)
         m_ifs.clear();
-        try {
+        try
-            // validation errors stack.  1.1 files shouldn't have
-            // pad bytes.
+            // validation errors stack.  1.1 files shouldn't have pad bytes.
@@ -271,6 +270,10 @@
         try
@@ -285,9 +288,11 @@
-            point.SetTime(t);
+            double gpst = 0;
         return true;
@@ -298,35 +303,38 @@
-    double t = 0;
     if (m_size <= n)
         return false;
-    if (m_has_pad_bytes) pos += 2;
+    if (m_has_pad_bytes)
+        pos += 2;
     m_ifs.clear();
-        point.SetTime(t);
+        double gpst = 0;
     return true;
 }}} // namespace liblas::detail::v11
Modified: trunk/src/detail/reader12.cpp
--- trunk/src/detail/reader12.cpp	(original)
+++ trunk/src/detail/reader12.cpp	Wed Apr 15 10:27:05 2009
@@ -220,62 +220,51 @@
-    try {
+    try
-        // validation errors stack.  1.2 files shouldn't have
-        // pad bytes.
+        // validation errors stack.  1.2 files shouldn't have pad bytes.
         // This is what is thrown when we compile *with* debug
     Reset(header);
     return true;
 bool ReaderImpl::ReadNextPoint(LASPoint& point, LASHeader const& header)
-    double t = 0;
-    uint16_t red = 0;
-    uint16_t blue = 0;
-    uint16_t green = 0;
-    LASColor color;
     if (0 == m_current)
         m_ifs.clear();
-        try {
+        try
             // pad bytes.
@@ -283,6 +272,10 @@
         try
@@ -297,31 +290,35 @@
+        double gpst = 0;
+        uint16_t red = 0;
+        uint16_t blue = 0;
+        uint16_t green = 0;
-            point.SetTime(t);
         else if (header.GetDataFormatId() == LASHeader::ePointFormat2)
             detail::read_n(red, m_ifs, sizeof(uint16_t));
             detail::read_n(green, m_ifs, sizeof(uint16_t));
             detail::read_n(blue, m_ifs, sizeof(uint16_t));
-            color.SetRed(red);
-            color.SetBlue(blue);
-            color.SetGreen(green);
+            LASColor color(red, green, blue);
             point.SetColor(color);
         else if (header.GetDataFormatId() == LASHeader::ePointFormat3)
-            point.SetTime(t);
More information about the Liblas-commits mailing list
