[Liblas-commits] r1210 - trunk/apps
liblas-commits at liblas.org
Wed Apr 15 13:17:58 EDT 2009
Author: hobu
Date: Wed Apr 15 13:17:53 2009
New Revision: 1210
URL: http://liblas.org/changeset/1210
try again on scaling
trunk/apps/ts2las.cpp
Modified: trunk/apps/ts2las.cpp
--- trunk/apps/ts2las.cpp (original)
+++ trunk/apps/ts2las.cpp Wed Apr 15 13:17:53 2009
@@ -5,6 +5,8 @@
#include <iostream>
#include <string>
+// from http://cdn.terrasolid.fi/tscan.pdf
using namespace liblas;
@@ -73,13 +75,14 @@
header.SetVersionMinor(2);
header.SetDataFormatId(format);
// header.SetPointRecordsCount(hdr->PntCnt);
- header.SetOffset(hdr->OrgX, hdr->OrgY, hdr->OrgZ);
- std::cout << "offset x: " << header.GetOffsetX() << " offset y: " << header.GetOffsetY() << " offset z: " <<header.GetOffsetZ() << std::endl;
std::cout << "units: " << hdr->Units << std::endl;
std::cout << "format: " << format << std::endl;
double scale = 1.0/(double)hdr->Units;
std::cout << "scale: " << scale << std::endl;
header.SetScale(scale, scale, scale);
+ header.SetOffset(hdr->OrgX*scale, hdr->OrgY*scale, hdr->OrgZ*scale);
+ std::cout << "offset x: " << header.GetOffsetX() << " offset y: " << header.GetOffsetY() << " offset z: " <<header.GetOffsetZ() << std::endl;
return header;
bool ReadHeader(ScanHdr* hdr, std::istream* istrm) {
@@ -130,13 +133,14 @@
point->Echo = (row->EchoInt >> 14);
LASPoint p;
- p.SetCoordinates(
- (point->Pnt.x-hdr->OrgX)/(double)hdr->Units,
- (point->Pnt.y-hdr->OrgY)/(double)hdr->Units,
- (point->Pnt.z-hdr->OrgZ)/(double)hdr->Units);
- // std::cout << "x: " << point->Pnt.x << " y: "<< point->Pnt.y << " z: " <<point->Pnt.z<< std::endl;
- // std::cout << "x: " << p.GetX() << " y: "<< p.GetY() << " z: " <<p.GetZ()<< std::endl;
+ p.SetCoordinates(writer->GetHeader(),
+ point->Pnt.x,
+ point->Pnt.y,
+ point->Pnt.z);
+ // std::cout << "read x: " << point->Pnt.x << " y: "<< point->Pnt.y << " z: " <<point->Pnt.z<< std::endl;
+ // std::cout << "wrote x: " << p.GetX() << " y: "<< p.GetY() << " z: " <<p.GetZ()<< std::endl;
// std::cout << "Code: " << point->Code << " Intensity: "<< point->Intensity << std::endl;
p.SetClassification(point->Code);
p.SetIntensity(point->Intensity);
@@ -189,13 +193,14 @@
// number?!
p.SetReturnNumber(3);
try {
writer->WritePoint(p);
} catch (std::exception const& e)
std::cout << "Point writing failed!" << std::endl;
catch (std::out_of_range const& e) // we reached the end of the file
@@ -281,7 +286,7 @@
std::cout<<"header was not read! exiting" << std::cout; exit(1);
- std::cout << "stream position is: " << istrm->tellg() << std::endl;
+ // std::cout << "stream position is: " << istrm->tellg() << std::endl;
LASHeader header = CreateHeader(hdr);
LASWriter* writer = new LASWriter(*ostrm, header);
More information about the Liblas-commits
