[Liblas-commits] hg: fix up tests for different library availability
liblas-commits at liblas.org
Tue Dec 29 12:38:36 EST 2009
changeset 27c57fd31ed5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=27c57fd31ed5
summary: fix up tests for different library availability
diffstat:
python/tests/Point.txt | 9 ++-
python/tests/SRS-GDAL.txt | 116 +++++++++++++++++++++++++++++++++++
python/tests/SRS-GeoTIFF.txt | 19 +++++
python/tests/SRS.txt | 136 +-----------------------------------------
python/tests/test_doctests.py | 29 ++++++++-
5 files changed, 170 insertions(+), 139 deletions(-)
diffs (truncated from 366 to 300 lines):
diff -r bff38a2f7907 -r 27c57fd31ed5 python/tests/Point.txt
--- a/python/tests/Point.txt Tue Dec 29 10:59:15 2009 -0600
+++ b/python/tests/Point.txt Tue Dec 29 11:34:27 2009 -0600
@@ -61,13 +61,18 @@
>>> import datetime
>>> import math
+ >>> import time
>>> def get_td():
... now = datetime.datetime.now()
... td = now.utcnow() - now # my timezone is GMT-5, would be GMT-7 for California (buildbot)
- ... return int(math.floor(td.seconds/3600.0))
+ ... isdst = time.localtime().tm_isdst
+ ... if isdst:
+ ... return int(math.floor(td.seconds/3600.0))
+ ... else:
+ ... return int(math.floor(td.seconds/3600.0)) - 1
>>> td = datetime.timedelta(hours=get_td())
>>> p.time = datetime.datetime(2008,3,19,23,45,45,13434)
- >>> delta = p.time - datetime.datetime(2008,3,19,23,45,45,13434)
+ >>> delta = p.time - datetime.datetime(2008,3,19,23,45,45,13434)
>>> int(math.floor(delta.seconds/3600.0)) == get_td() or int(math.floor(delta.seconds/3600.0)) == get_td() + 1
True
>>> p.time.microsecond
diff -r bff38a2f7907 -r 27c57fd31ed5 python/tests/SRS-GDAL.txt
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/python/tests/SRS-GDAL.txt Tue Dec 29 11:34:27 2009 -0600
@@ -0,0 +1,116 @@
+ >>> from liblas import srs
+ >>> from liblas import point
+ >>> from liblas import header
+ >>> import liblas
+ >>> s = srs.SRS()
+ >>> s.proj4
+ >>> s.proj4 = '+proj=utm +zone=15 +ellps=WGS84 +datum=WGS84 +units=m +no_defs'
+ >>> s.proj4 == '+proj=utm +zone=15 +ellps=WGS84 +datum=WGS84 +units=m +no_defs '
+ True
+ >>> s = srs.SRS()
+ >>> s.set_userinput('EPSG:4326')
+ >>> s.proj4 == '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs '
+ True
+ >>> from liblas import file
+ >>> f = file.File('../test/data/1.2_3.las',mode='r')
+ >>> s = f.header.srs
+ >>> s.wkt == """PROJCS["NAD83 / UTM zone 15N",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.2572221010002,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4269"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-93],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","26915"]]"""
+ True
+ >>> s2 = srs.SRS()
+ >>> s2.wkt = """GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]"""
+ >>> p = f.read(0)
+ >>> p.descale(f.header)
+ >>> int(p.x)
+ 47069244
+ >>> f.set_srs(s2)
+ >>> p = f.read(0)
+ >>> s2.vlr_count()
+ 3
+ >>> s2.GetVLR(0).recordlength
+ 64
+ >>> int(round(p.x))
+ -93
+ >>> int(round(p.y))
+ 42
+ >>> del f
+# -93.3515625902 41.5771483954
+ >>> def new_offset(old_scale, new_scale, old_offset, x):
+ ... return (new_scale*(x - old_offset) - old_scale*x)/(-1.0*old_scale)
+ >>> utm_wkt = """PROJCS["NAD83 / UTM zone 15N",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.2572221010002,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4269"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-93],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","26915"]]"""
+ >>> dd_wkt = """GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]"""
+ >>> s_dd = srs.SRS()
+ >>> s_dd.wkt = dd_wkt
+ >>> s_utm = srs.SRS()
+ >>> s_utm.wkt = utm_wkt
+ >>> dd_header = liblas.header.Header(handle=f.header.handle,copy=True)
+ >>> utm_header = liblas.header.Header(handle=f.header.handle,copy=True)
+ >>> del f
+ >>> utm_header.offset
+ [0.0, 0.0, 0.0]
+ >>> utm_header.scale
+ [0.01, 0.01, 0.01]
+# >>> new_offset(0.01, 0.0001, 0.0, 470692.44)
+# >>> utm_header.offset = [offset+1.0/0.000001 for offset in utm_header.offset]
+ [1000000.0, 1000000.0, 1000000.0]
+# >>> utm_header.scale = [0.000001,0.000001,0.000001]
+ >>> utm_header.srs = s_utm
+ >>> dd_header.scale = [0.000001,0.000001,0.000001]
+ >>> dd_header.srs = s_dd
+ >>> f = file.File('../test/data/1.2_3.las',mode='r', header = utm_header)
+ >>> f.header.data_offset
+ 438L
+ >>> f.header.scale
+ >>> p = f.read(0)
+ >>> origx, origy = p.x, p.y
+ >>> origx, origy
+ (470692.44, 4602888.9000000004)
+ >>> f.set_srs(s_dd)
+ True
+ >>> p = f.read(0)
+ >>> p.x, p.y
+ (-93.350000000000009, 41.57)
+ >>> f_project = file.File('junk_srs_project.las',mode='w',header=dd_header)
+ >>> dd_header.srs.proj4
+ '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs '
+ >>> f_project.write(p);f_project.write(p);f_project.write(p)
+ >>> f_project.close()
+ >>> del f_project
+ >>> f3 = file.File('junk_srs_project.las')
+ >>> f3.header.data_offset
+ 476L
+ >>> p3 = f3.read(1)
+ >>> int(round(p3.x)), int(round(p3.y))
+ (-93, 42)
+ >>> p3 = f3.read(0)
+ (-93, 42)
+ >>> import os
+ >>> os.remove('junk_srs_project.las')
\ No newline at end of file
diff -r bff38a2f7907 -r 27c57fd31ed5 python/tests/SRS-GeoTIFF.txt
+++ b/python/tests/SRS-GeoTIFF.txt Tue Dec 29 11:34:27 2009 -0600
@@ -0,0 +1,19 @@
+ >>> import liblas
+ >>> s = srs.SRS()
+ >>> s.proj4
+ >>> s.proj4
+ '+proj=tmerc +lat_0=0.000000000 +lon_0=-93.000000000 +k=0.999600 +x_0=500000.000 +y_0=0.000 +ellps=WGS84 +units=m '
+ >>> s.proj4
+ '+proj=utm +zone=15 +ellps=GRS80 +units=m '
diff -r bff38a2f7907 -r 27c57fd31ed5 python/tests/SRS.txt
--- a/python/tests/SRS.txt Tue Dec 29 10:59:15 2009 -0600
+++ b/python/tests/SRS.txt Tue Dec 29 11:34:27 2009 -0600
@@ -3,151 +3,19 @@
>>> import liblas
- >>> s = srs.SRS()
- >>> s.proj4
- >>> s.proj4 = '+proj=utm +zone=15 +ellps=WGS84 +datum=WGS84 +units=m +no_defs'
- >>> def test_srs():
- ... if not liblas.HAVE_LIBGEOTIFF:
- ... return True
- ... if not liblas.HAVE_GDAL:
- ... return s.proj4 == '+proj=tmerc +lat_0=0.000000000 +lon_0=-93.000000000 +k=0.999600 +x_0=500000.000 +y_0=0.000 +ellps=WGS84 +units=m '
- ... if liblas.HAVE_GDAL:
- ... return s.proj4 == '+proj=utm +zone=15 +ellps=WGS84 +datum=WGS84 +units=m +no_defs '
- ... return False
- >>> test_srs()
- True
- >>> s = srs.SRS()
- >>> def test_userinput():
- ... return True
- ... return s.proj4 == ''
- ... s.set_userinput('EPSG:4326')
- ... return s.proj4 == '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs '
- ... return False
- >>> test_userinput()
- True
>>> s = f.header.srs
- ... return True
- ... return s.wkt == ''
- ... return s.wkt == """PROJCS["NAD83 / UTM zone 15N",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.2572221010002,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4269"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-93],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","26915"]]"""
- ... return False
- >>> test_srs()
- True
-# ... s2.wkt = """GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]"""
-# ... s2.wkt = """PROJCS["NAD83 / UTM zone 16N",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-87],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],AUTHORITY["EPSG","26916"],AXIS["Easting",EAST],AXIS["Northing",NORTH]]"""
- >>> def test_srs_2():
- ... return True
- ... return True
- ... s2 = srs.SRS()
- ... s2.wkt = """GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]"""
- ... p = f.read(0)
- ... p.descale(f.header)
- ... if int(p.x) != 47069244: return False
- ... f.set_srs(s2)
- ... p = f.read(0)
- ... if not s2.vlr_count() == 3: return False
- ... if not s2.GetVLR(0).recordlength == 64: return False
- ... return int(round(p.x)) == -93 and int(round(p.y)) == 42
- ... return False
- >>> test_srs_2()
- True
+ >>> s.proj4
>>> del f
-# -93.3515625902 41.5771483954
- >>> utm_wkt = """PROJCS["NAD83 / UTM zone 15N",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.2572221010002,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4269"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-93],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","26915"]]"""
- >>> dd_wkt = """GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]"""
- >>> s_dd = srs.SRS()
- >>> s_dd.wkt = dd_wkt
- >>> s_utm = srs.SRS()
- >>> s_utm.wkt = utm_wkt
- >>> f = file.File('../test/data/1.2_3.las',mode='r')
- >>> dd_header = liblas.header.Header(handle=f.header.handle,copy=True)
- >>> utm_header = liblas.header.Header(handle=f.header.handle,copy=True)
- >>> del f
- >>> utm_header.offset
- [0.0, 0.0, 0.0]
- >>> utm_header.scale
- [0.01, 0.01, 0.01]
-# >>> new_offset(0.01, 0.0001, 0.0, 470692.44)
-# >>> utm_header.offset = [offset+1.0/0.000001 for offset in utm_header.offset]
- [1000000.0, 1000000.0, 1000000.0]
-# >>> utm_header.scale = [0.000001,0.000001,0.000001]
- >>> utm_header.srs = s_utm
- >>> dd_header.scale = [0.000001,0.000001,0.000001]
- >>> dd_header.srs = s_dd
- >>> f = file.File('../test/data/1.2_3.las',mode='r', header = utm_header)
- >>> f.header.data_offset
- 438L
- >>> f.header.scale
- >>> p = f.read(0)
- >>> origx, origy = p.x, p.y
- >>> origx, origy
- (470692.44, 4602888.9000000004)
- >>> f.set_srs(s_dd)
- True
- >>> p = f.read(0)
- >>> p.x, p.y
- (-93.350000000000009, 41.57)
More information about the Liblas-commits
