[Liblas-commits] hg: more test cleanup
liblas-commits at liblas.org
Tue Dec 29 14:00:45 EST 2009
changeset 2ff9a45f4843 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2ff9a45f4843
summary: more test cleanup
diffstat:
python/tests/SRS-GDAL.txt | 2 ++
python/tests/test_doctests.py | 33 ++++++++++++++++-----------------
2 files changed, 18 insertions(+), 17 deletions(-)
diffs (74 lines):
diff -r 27c57fd31ed5 -r 2ff9a45f4843 python/tests/SRS-GDAL.txt
--- a/python/tests/SRS-GDAL.txt Tue Dec 29 11:34:27 2009 -0600
+++ b/python/tests/SRS-GDAL.txt Tue Dec 29 12:56:41 2009 -0600
@@ -12,6 +12,7 @@
>>> s = srs.SRS()
>>> s.set_userinput('EPSG:4326')
+ True
>>> s.proj4 == '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs '
True
@@ -28,6 +29,7 @@
>>> int(p.x)
47069244
>>> f.set_srs(s2)
+ True
>>> p = f.read(0)
>>> s2.vlr_count()
3
diff -r 27c57fd31ed5 -r 2ff9a45f4843 python/tests/test_doctests.py
--- a/python/tests/test_doctests.py Tue Dec 29 11:34:27 2009 -0600
+++ b/python/tests/test_doctests.py Tue Dec 29 12:56:41 2009 -0600
@@ -44,6 +44,7 @@
import unittest
import glob
import os
+import copy
optionflags = (doctest.REPORT_ONLY_FIRST_FAILURE |
doctest.NORMALIZE_WHITESPACE |
@@ -52,28 +53,26 @@
def list_doctests():
files = glob.glob(os.path.join(os.path.dirname(__file__), '*.txt'))
+ import liblas
- import liblas
- if not liblas.HAVE_LIBGEOTIFF:
- for f in files:
+ for f in copy.copy(files):
+ if liblas.HAVE_LIBGEOTIFF and liblas.HAVE_GDAL:
+ # run GDAL's tests only
if 'GeoTIFF' in f:
files.remove(f)
- else:
- for f in files:
- if 'GDAL' or 'SRS.txt' in f:
- files.remove(f)
- if not liblas.HAVE_GDAL:
- for f in files:
+ if 'SRS.txt' in f:
+ files.remove(f)
+ if liblas.HAVE_LIBGEOTIFF and not liblas.HAVE_GDAL:
if 'GDAL' in f:
files.remove(f)
- else:
- # use GDAL's tests instead of geotiff's if we
- # have GDAL
- # don't run the generic test if we have gdal
- for f in files:
- if 'GeoTIFF' or 'SRS.txt' in f:
+ files.remove(f)
+ if not liblas.HAVE_LIBGEOTIFF and not liblas.HAVE_GDAL:
+ if 'GDAL' in f:
+ files.remove(f)
+ if 'GeoTIFF' in f:
files.remove(f)
return files
More information about the Liblas-commits
