[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Dec 30 21:04:07 EST 2009
changeset b5a542b7f9fd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=b5a542b7f9fd
summary: Updated FindSpatialIndex.cmake macro to determine version of the package and test against required version. Currently, SpatialIndex 1.4.0 or later version is required.
changeset 18b2578d36fd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=18b2578d36fd
diffstat:
 CMakeLists.txt                         |    2 +-
 build/cmake/FindSpatialIndex.cmake     |   50 ++++-
 test/unit/lasheader_test.cpp           |   41 ++-
 test/unit/tut/tut_cppunit_reporter.hpp |  201 ++++++++++++++++++
 test/unit/tut/tut_restartable.hpp      |   28 +-
 test/unit/tut/tut_xml_reporter.hpp     |  361 +++++++++++++++++++++++++++++++++
 6 files changed, 647 insertions(+), 36 deletions(-)
diffs (truncated from 837 to 300 lines):
diff -r f3b481d2694b -r 18b2578d36fd CMakeLists.txt
--- a/CMakeLists.txt	Wed Dec 30 23:39:27 2009 +0000
+++ b/CMakeLists.txt	Thu Dec 31 02:03:32 2009 +0000
@@ -179,7 +179,7 @@
 ENDIF()
 # Spatial Index support - optional, default=OFF
-SET(WITH_SPATIALINDEX FALSE CACHE BOOL "Choose if GeoTIFF support should be built")
+SET(WITH_SPATIALINDEX FALSE CACHE BOOL "Choose if SpatialIndex support should be built")
 IF(WITH_SPATIALINDEX)
     FIND_PACKAGE(SpatialIndex 1.4.0)
diff -r f3b481d2694b -r 18b2578d36fd build/cmake/FindSpatialIndex.cmake
--- a/build/cmake/FindSpatialIndex.cmake	Wed Dec 30 23:39:27 2009 +0000
+++ b/build/cmake/FindSpatialIndex.cmake	Thu Dec 31 02:03:32 2009 +0000
@@ -5,6 +5,7 @@
 # SPATIALINDEX_FOUND       = if the library found
 # SPATIALINDEX_LIBRARY     = full path to the library
 # SPATIALINDEX_INCLUDE_DIR = where to find the library headers
+# SPATIALINDEX_VERSION	   = version of library which was found, e.g. "1.4.0"
 # Copyright (c) 2009 Mateusz Loskot <mateusz at loskot.net>
@@ -13,7 +14,6 @@
 MESSAGE(STATUS "Searching for SpatialIndex ${SpatialIndex_FIND_VERSION}+ library")
-MESSAGE(STATUS "   NOTE: Required version is not checked - to be implemented")
 IF(SPATIALINDEX_INCLUDE_DIR)
     # Already in cache, be silent
@@ -32,10 +32,13 @@
 ENDIF()
 FIND_PATH(SPATIALINDEX_INCLUDE_DIR
-    NAMES RTree.h
-    PATH_PREFIXES spatialindex
-    PATHS
-    ${OSGEO4W_ROOT_DIR}/include)
+    NAMES SpatialIndex.h RTree.h
+	HINTS
+	${OSGEO4W_ROOT_DIR}/include
+	PATHS
+	PATH_SUFFIXES spatialindex
+	DOC "Path to include directory of SpatialIndex library")
 SET(SPATIALINDEX_NAMES ${OSGEO4W_IMPORT_LIBRARY} spatialindex)
 FIND_LIBRARY(SPATIALINDEX_LIBRARY
@@ -43,10 +46,45 @@
     PATHS
     ${OSGEO4W_ROOT_DIR}/lib)
+IF (SPATIALINDEX_INCLUDE_DIR)
+	SET(SPATIALINDEX_VERSION 0)
+	SET(SPATIALINDEX_VERSION_H "${SPATIALINDEX_INCLUDE_DIR}/Version.h")
+	FILE(READ ${SPATIALINDEX_VERSION_H} SPATIALINDEX_VERSION_H_CONTENTS)
+	IF (DEFINED SPATIALINDEX_VERSION_H_CONTENTS)
+		STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_MAJOR[ \t]+([0-9]+).*" "\\1" SIDX_VERSION_MAJOR "${SPATIALINDEX_VERSION_H_CONTENTS}")
+		STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_MINOR[ \t]+([0-9]+).*" "\\1" SIDX_VERSION_MINOR "${SPATIALINDEX_VERSION_H_CONTENTS}")
+		STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_REV[ \t]+([0-9]+).*"   "\\1" SIDX_VERSION_REV   "${SPATIALINDEX_VERSION_H_CONTENTS}")
+        IF(NOT ${SIDX_VERSION_MAJOR} MATCHES "[0-9]+")
+            MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_MAJOR!")
+        ENDIF()
+        IF(NOT ${SIDX_VERSION_MINOR} MATCHES "[0-9]+")
+            MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_MINOR!")
+        ENDIF()
+        IF(NOT ${SIDX_VERSION_REV} MATCHES "[0-9]+")
+            MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_REV!")
+        ENDIF()
+		SET(SPATIALINDEX_VERSION "${SIDX_VERSION_MAJOR}.${SIDX_VERSION_MINOR}.${SIDX_VERSION_REV}"
+			CACHE INTERNAL "The version string for SpatialIndex library")
+		IF (SPATIALINDEX_VERSION VERSION_EQUAL SpatialIndex_FIND_VERSION OR
+			SPATIALINDEX_VERSION VERSION_GREATER SpatialIndex_FIND_VERSION)
+			MESSAGE(STATUS "Found SpatialIndex version: ${SPATIALINDEX_VERSION}")
+		ELSE()
+			MESSAGE(FATAL_ERROR "SpatialIndex version check failed. Version ${SPATIALINDEX_VERSION} was found, at least version ${SpatialIndex_FIND_VERSION} is required")
+		ENDIF()
+	ELSE()
+		MESSAGE(FATAL_ERROR "Failed to open ${SPATIALINDEX_VERSION_H} file")
+	ENDIF()
+ENDIF()
 # Handle the QUIETLY and REQUIRED arguments and set SPATIALINDEX_FOUND to TRUE
 # if all listed variables are TRUE
 INCLUDE(FindPackageHandleStandardArgs)
-FIND_PACKAGE_HANDLE_STANDARD_ARGS(SPATIALINDEX DEFAULT_MSG SPATIALINDEX_LIBRARY SPATIALINDEX_INCLUDE_DIR)
+FIND_PACKAGE_HANDLE_STANDARD_ARGS(SpatialIndex DEFAULT_MSG SPATIALINDEX_LIBRARY SPATIALINDEX_INCLUDE_DIR)
 # TODO: Do we want to mark these as advanced? --mloskot
 # http://www.cmake.org/cmake/help/cmake2.6docs.html#command:mark_as_advanced
diff -r f3b481d2694b -r 18b2578d36fd test/unit/lasheader_test.cpp
--- a/test/unit/lasheader_test.cpp	Wed Dec 30 23:39:27 2009 +0000
+++ b/test/unit/lasheader_test.cpp	Thu Dec 31 02:03:32 2009 +0000
@@ -50,13 +50,13 @@
         h1.SetFileSignature(sig);
         ensure_not(h1.GetFileSignature() == sig);
-        ensure_equals(h1.GetFileSignature().size(), 4);
+        ensure_equals(h1.GetFileSignature().size(), std::string::size_type(4));
         ensure_equals(h1.GetFileSignature(), LASHeader::FileSignature);
         LASHeader h2(h1);
         ensure_not(h2.GetFileSignature() == sig);
-        ensure_equals(h2.GetFileSignature().size(), 4);
+        ensure_equals(h2.GetFileSignature().size(), std::string::size_type(4));
         ensure_equals(h2.GetFileSignature(), LASHeader::FileSignature);
@@ -87,14 +87,14 @@
         LASHeader h2;
         h2 = h1;
@@ -210,12 +210,12 @@
         h.SetSystemId(sysid1);
         ensure_equals(h.GetSystemId(), sysid1);
         ensure_equals(h.GetSystemId().size(), len1);
-        ensure_equals(h.GetSystemId(true).size(), 32);
+        ensure_equals(h.GetSystemId(true).size(), std::string::size_type(32));
         h.SetSystemId(sysid2);
         ensure_equals(h.GetSystemId(), sysid2);
         ensure_equals(h.GetSystemId().size(), len2);
     // Test Get/SetSoftwareId
@@ -234,12 +234,12 @@
         h.SetSoftwareId(softid1);
         ensure_equals(h.GetSoftwareId(), softid1);
         ensure_equals(h.GetSoftwareId().size(), len1);
-        ensure_equals(h.GetSoftwareId(true).size(), 32);
+        ensure_equals(h.GetSoftwareId(true).size(), std::string::size_type(32));
         h.SetSoftwareId(softid2);
         ensure_equals(h.GetSoftwareId(), softid2);
         ensure_equals(h.GetSoftwareId().size(), len2);
     // Test GetPointRecordsByReturnCount
@@ -247,28 +247,31 @@
     template<>
     void to::test<11>()
+        typedef ::liblas::LASHeader::RecordsByReturnArray::size_type size_type;
+        typedef ::liblas::uint32_t count_type;
         liblas::LASHeader h;
-        ensure_equals(h.GetPointRecordsByReturnCount().size(), 5);
+        ensure_equals(h.GetPointRecordsByReturnCount().size(), size_type(5));
         h.SetPointRecordsByReturnCount(0, 100);
-        ensure_equals(h.GetPointRecordsByReturnCount().at(0), 100);
+        ensure_equals(h.GetPointRecordsByReturnCount().at(0), count_type(100));
         h.SetPointRecordsByReturnCount(1, 101);
-        ensure_equals(h.GetPointRecordsByReturnCount().at(1), 101);
+        ensure_equals(h.GetPointRecordsByReturnCount().at(1), count_type(101));
         h.SetPointRecordsByReturnCount(2, 102);
-        ensure_equals(h.GetPointRecordsByReturnCount().at(2), 102);
+        ensure_equals(h.GetPointRecordsByReturnCount().at(2), count_type(102));
         h.SetPointRecordsByReturnCount(3, 103);
-        ensure_equals(h.GetPointRecordsByReturnCount().at(3), 103);
+        ensure_equals(h.GetPointRecordsByReturnCount().at(3), count_type(103));
         h.SetPointRecordsByReturnCount(4, 104);
-        ensure_equals(h.GetPointRecordsByReturnCount().at(4), 104);
+        ensure_equals(h.GetPointRecordsByReturnCount().at(4), count_type(104));
         try
diff -r f3b481d2694b -r 18b2578d36fd test/unit/tut/tut_cppunit_reporter.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/test/unit/tut/tut_cppunit_reporter.hpp	Thu Dec 31 02:03:32 2009 +0000
@@ -0,0 +1,201 @@
+#ifndef TUT_CPPUNIT_REPORTER
+#define TUT_CPPUNIT_REPORTER
+#include <tut/tut.hpp>
+#include <string>
+#include <fstream>
+#include <vector>
+#include <stdexcept>
+namespace tut
+ * CppUnit TUT reporter
+class cppunit_reporter : public tut::callback
+    private:
+        std::vector<tut::test_result> failed_tests;
+        std::vector<tut::test_result> passed_tests;
+        std::string filename;
+        std::string encode(const std::string & text)
+            std::string out;
+            for (unsigned int i=0; i<text.length(); ++i) {
+                char c = text[i];
+                switch (c) {
+                    case '<':
+                        out += "&lt;";
+                        break;
+                    case '>':
+                        out += "&gt;";
+                        break;
+                    case '&':
+                        out += "&amp;";
+                        break;
+                    case '\'':
+                        out += "&apos;";
+                        break;
+                    case '"':
+                        out += "&quot;";
+                        break;
+                    default:
+                        out += c;
+            return out;
+public:
+    cppunit_reporter(const std::string & _filename = "")
+        setFilename(_filename);
+    void setFilename(const std::string & _filename)
+        if (_filename == "")
+            filename = "testResult.xml";
+        else
+            filename = _filename;
+    void run_started()
+        failed_tests.clear();
+        passed_tests.clear();
+    void test_completed(const tut::test_result& tr)
+        if (tr.result == test_result::ok) {
+            passed_tests.push_back(tr);
+        } else {
+            failed_tests.push_back(tr);
+    void run_completed()
+        int errors = 0;
+        int failures = 0;
More information about the Liblas-commits mailing list
