[Liblas-commits] hg: Fixed EOL to LF in CMake macros.
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Dec 30 21:12:31 EST 2009
changeset 3e2aa2eb7cb4 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=3e2aa2eb7cb4
summary: Fixed EOL to LF in CMake macros.
diffstat:
 build/cmake/FindGeoTIFF.cmake      |  118 ++++++++++++++++++------------------
 build/cmake/FindSpatialIndex.cmake |   18 ++--
 2 files changed, 68 insertions(+), 68 deletions(-)
diffs (156 lines):
diff -r 18b2578d36fd -r 3e2aa2eb7cb4 build/cmake/FindGeoTIFF.cmake
--- a/build/cmake/FindGeoTIFF.cmake	Thu Dec 31 02:03:32 2009 +0000
+++ b/build/cmake/FindGeoTIFF.cmake	Thu Dec 31 02:12:19 2009 +0000
@@ -1,59 +1,59 @@
-# CMake module to search for GeoTIFF library
-# On success, the macro sets the following variables:
-# GEOTIFF_FOUND       = if the library found
-# GEOTIFF_LIBRARIES   = full path to the library
-# GEOTIFF_INCLUDE_DIR = where to find the library headers
-# also defined, but not for general use are
-# GEOTIFF_LIBRARY, where to find the PROJ.4 library.
-# Copyright (c) 2009 Mateusz Loskot <mateusz at loskot.net>
-# Module source: http://github.com/mloskot/workshop/tree/master/cmake/
-# Redistribution and use is allowed according to the terms of the BSD license.
-# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
-MESSAGE(STATUS "Searching for GeoTIFF ${GeoTIFF_FIND_VERSION}+ library")
-MESSAGE(STATUS "   NOTE: Required version is not checked - to be implemented")
-IF(GEOTIFF_INCLUDE_DIR)
-    # Already in cache, be silent
-    SET(GEOTIFF_FIND_QUIETLY TRUE)
-ENDIF()
-IF(WIN32)
-    SET(OSGEO4W_IMPORT_LIBRARY geotiff_i)
-    IF(DEFINED ENV{OSGEO4W_ROOT})
-        SET(OSGEO4W_ROOT_DIR $ENV{OSGEO4W_ROOT})
-        MESSAGE(STATUS "Trying OSGeo4W using environment variable OSGEO4W_ROOT=$ENV{OSGEO4W_ROOT}")
-    ELSE()
-        SET(OSGEO4W_ROOT_DIR c:/OSGeo4W)
-        MESSAGE(STATUS "Trying OSGeo4W using default location OSGEO4W_ROOT=${OSGEO4W_ROOT_DIR}")
-    ENDIF()
-ENDIF()
-FIND_PATH(GEOTIFF_INCLUDE_DIR
-    geotiff.h
-    PATH_PREFIXES geotiff
-    PATHS
-    ${OSGEO4W_ROOT_DIR}/include)
-SET(GEOTIFF_NAMES ${OSGEO4W_IMPORT_LIBRARY} geotiff)
-FIND_LIBRARY(GEOTIFF_LIBRARY
-    NAMES ${GEOTIFF_NAMES}
-    PATHS
-    ${OSGEO4W_ROOT_DIR}/lib)
-IF(GEOTIFF_FOUND)
-  SET(GEOTIFF_LIBRARIES ${GEOTIFF_LIBRARY})
-ENDIF()
-# Handle the QUIETLY and REQUIRED arguments and set GEOTIFF_FOUND to TRUE
-# if all listed variables are TRUE
-INCLUDE(FindPackageHandleStandardArgs)
-FIND_PACKAGE_HANDLE_STANDARD_ARGS(GEOTIFF DEFAULT_MSG GEOTIFF_LIBRARY GEOTIFF_INCLUDE_DIR)
+# CMake module to search for GeoTIFF library
+# On success, the macro sets the following variables:
+# GEOTIFF_FOUND       = if the library found
+# GEOTIFF_LIBRARIES   = full path to the library
+# GEOTIFF_INCLUDE_DIR = where to find the library headers
+# also defined, but not for general use are
+# GEOTIFF_LIBRARY, where to find the PROJ.4 library.
+# Copyright (c) 2009 Mateusz Loskot <mateusz at loskot.net>
+# Module source: http://github.com/mloskot/workshop/tree/master/cmake/
+# Redistribution and use is allowed according to the terms of the BSD license.
+# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
+MESSAGE(STATUS "Searching for GeoTIFF ${GeoTIFF_FIND_VERSION}+ library")
+MESSAGE(STATUS "   NOTE: Required version is not checked - to be implemented")
+IF(GEOTIFF_INCLUDE_DIR)
+    # Already in cache, be silent
+    SET(GEOTIFF_FIND_QUIETLY TRUE)
+ENDIF()
+IF(WIN32)
+    SET(OSGEO4W_IMPORT_LIBRARY geotiff_i)
+    IF(DEFINED ENV{OSGEO4W_ROOT})
+        SET(OSGEO4W_ROOT_DIR $ENV{OSGEO4W_ROOT})
+        MESSAGE(STATUS "Trying OSGeo4W using environment variable OSGEO4W_ROOT=$ENV{OSGEO4W_ROOT}")
+    ELSE()
+        SET(OSGEO4W_ROOT_DIR c:/OSGeo4W)
+        MESSAGE(STATUS "Trying OSGeo4W using default location OSGEO4W_ROOT=${OSGEO4W_ROOT_DIR}")
+    ENDIF()
+ENDIF()
+FIND_PATH(GEOTIFF_INCLUDE_DIR
+    geotiff.h
+    PATH_PREFIXES geotiff
+    PATHS
+    ${OSGEO4W_ROOT_DIR}/include)
+SET(GEOTIFF_NAMES ${OSGEO4W_IMPORT_LIBRARY} geotiff)
+FIND_LIBRARY(GEOTIFF_LIBRARY
+    NAMES ${GEOTIFF_NAMES}
+    PATHS
+    ${OSGEO4W_ROOT_DIR}/lib)
+IF(GEOTIFF_FOUND)
+  SET(GEOTIFF_LIBRARIES ${GEOTIFF_LIBRARY})
+ENDIF()
+# Handle the QUIETLY and REQUIRED arguments and set GEOTIFF_FOUND to TRUE
+# if all listed variables are TRUE
+INCLUDE(FindPackageHandleStandardArgs)
+FIND_PACKAGE_HANDLE_STANDARD_ARGS(GEOTIFF DEFAULT_MSG GEOTIFF_LIBRARY GEOTIFF_INCLUDE_DIR)
diff -r 18b2578d36fd -r 3e2aa2eb7cb4 build/cmake/FindSpatialIndex.cmake
--- a/build/cmake/FindSpatialIndex.cmake	Thu Dec 31 02:03:32 2009 +0000
+++ b/build/cmake/FindSpatialIndex.cmake	Thu Dec 31 02:12:19 2009 +0000
@@ -56,21 +56,21 @@
 		STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_MAJOR[ \t]+([0-9]+).*" "\\1" SIDX_VERSION_MAJOR "${SPATIALINDEX_VERSION_H_CONTENTS}")
 		STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_MINOR[ \t]+([0-9]+).*" "\\1" SIDX_VERSION_MINOR "${SPATIALINDEX_VERSION_H_CONTENTS}")
 		STRING(REGEX REPLACE ".*#define[ \t]SIDX_VERSION_REV[ \t]+([0-9]+).*"   "\\1" SIDX_VERSION_REV   "${SPATIALINDEX_VERSION_H_CONTENTS}")
-        IF(NOT ${SIDX_VERSION_MAJOR} MATCHES "[0-9]+")
-            MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_MAJOR!")
-        ENDIF()
-        IF(NOT ${SIDX_VERSION_MINOR} MATCHES "[0-9]+")
-            MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_MINOR!")
+        IF(NOT ${SIDX_VERSION_MAJOR} MATCHES "[0-9]+")
+            MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_MAJOR!")
         ENDIF()
-        IF(NOT ${SIDX_VERSION_REV} MATCHES "[0-9]+")
-            MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_REV!")
+        IF(NOT ${SIDX_VERSION_MINOR} MATCHES "[0-9]+")
+            MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_MINOR!")
+        ENDIF()
+        IF(NOT ${SIDX_VERSION_REV} MATCHES "[0-9]+")
+            MESSAGE(FATAL_ERROR "SpatialIndex version parsing failed for SIDX_VERSION_REV!")
         ENDIF()
 		SET(SPATIALINDEX_VERSION "${SIDX_VERSION_MAJOR}.${SIDX_VERSION_MINOR}.${SIDX_VERSION_REV}"
 			CACHE INTERNAL "The version string for SpatialIndex library")
-		IF (SPATIALINDEX_VERSION VERSION_EQUAL SpatialIndex_FIND_VERSION OR
+		IF (SPATIALINDEX_VERSION VERSION_EQUAL SpatialIndex_FIND_VERSION OR
 			SPATIALINDEX_VERSION VERSION_GREATER SpatialIndex_FIND_VERSION)
 			MESSAGE(STATUS "Found SpatialIndex version: ${SPATIALINDEX_VERSION}")
 		ELSE()
More information about the Liblas-commits mailing list
