[Liblas-commits] r1012 - trunk/apps
liblas-commits at liblas.org
Tue Feb 10 23:34:06 EST 2009
Author: hobu
Date: Tue Feb 10 23:34:06 2009
New Revision: 1012
URL: http://liblas.org/changeset/1012
allow las2las to write 1.2 format
trunk/apps/las2las.c
Modified: trunk/apps/las2las.c
--- trunk/apps/las2las.c (original)
+++ trunk/apps/las2las.c Tue Feb 10 23:34:06 2009
@@ -27,6 +27,7 @@
#define LAS_FORMAT_10 0
#define LAS_FORMAT_11 1
+#define LAS_FORMAT_12 2
void usage()
@@ -202,8 +203,11 @@
else if (strcmp(argv[i], "1.1") == 0) {
format = LAS_FORMAT_11;
+ else if (strcmp(argv[i], "1.2") == 0) {
+ format = LAS_FORMAT_12;
else {
- LASError_Print("Format must be specified as 1.0 or 1.1");
+ LASError_Print("Format must be specified as 1.0, 1.1, or 1.2");
@@ -624,9 +628,12 @@
if (format == LAS_FORMAT_10) {
LASHeader_SetVersionMinor(surviving_header, 0);
- } else {
+ } else if (format == LAS_FORMAT_11){
LASHeader_SetVersionMinor(surviving_header, 1);
+ } else if (format == LAS_FORMAT_12) {
+ LASHeader_SetVersionMinor(surviving_header, 2);
/* if (remove_extra_header) surviving_header.offset_to_point_data = surviving_header.header_size;
More information about the Liblas-commits
