[Liblas-commits] r1013 - in trunk: include/liblas/detail src/detail
liblas-commits at liblas.org
Wed Feb 11 10:49:17 EST 2009
Author: hobu
Date: Wed Feb 11 10:49:17 2009
New Revision: 1013
URL: http://liblas.org/changeset/1013
remove redundant GetStream and move ostream into abstract Writer:: class
trunk/include/liblas/detail/writer.hpp
trunk/include/liblas/detail/writer10.hpp
trunk/include/liblas/detail/writer11.hpp
trunk/include/liblas/detail/writer12.hpp
trunk/src/detail/writer.cpp
trunk/src/detail/writer10.cpp
trunk/src/detail/writer11.cpp
trunk/src/detail/writer12.cpp
Modified: trunk/include/liblas/detail/writer.hpp
--- trunk/include/liblas/detail/writer.hpp (original)
+++ trunk/include/liblas/detail/writer.hpp Wed Feb 11 10:49:17 2009
@@ -54,24 +54,30 @@
public:
- Writer();
+ Writer(std::ostream& ofs);
virtual ~Writer();
virtual std::size_t GetVersion() const = 0;
virtual void WriteHeader(LASHeader& header) = 0;
virtual void UpdateHeader(LASHeader const& header) = 0;
virtual void WritePointRecord(LASPoint const& point, const LASHeader& header) = 0;
virtual void WriteVLR(LASHeader const& header) = 0;
- virtual std::ostream& GetStream() const = 0;
+ std::ostream& GetStream() const;
+ void SetStream(std::ostream& stream);
protected:
PointRecord m_record;
+ std::ostream& m_ofs;
void FillPointRecord(PointRecord& record, const LASPoint& point, const LASHeader& header);
private:
// Blocked copying operations, declared but not defined.
Writer(Writer const& other);
Writer& operator=(Writer const& rhs);
class WriterFactory
Modified: trunk/include/liblas/detail/writer10.hpp
--- trunk/include/liblas/detail/writer10.hpp (original)
+++ trunk/include/liblas/detail/writer10.hpp Wed Feb 11 10:49:17 2009
@@ -61,13 +61,10 @@
void WriteHeader(LASHeader& header);
void UpdateHeader(LASHeader const& header);
void WritePointRecord(LASPoint const& record, const LASHeader& header);
-// void WritePointRecord(PointRecord const& record, double const& time);
void WriteVLR(LASHeader const& header);
- std::ostream& GetStream() const;
private:
- std::ostream& m_ofs;
liblas::uint32_t m_pointCount;
Modified: trunk/include/liblas/detail/writer11.hpp
--- trunk/include/liblas/detail/writer11.hpp (original)
+++ trunk/include/liblas/detail/writer11.hpp Wed Feb 11 10:49:17 2009
@@ -62,11 +62,9 @@
private:
Modified: trunk/include/liblas/detail/writer12.hpp
--- trunk/include/liblas/detail/writer12.hpp (original)
+++ trunk/include/liblas/detail/writer12.hpp Wed Feb 11 10:49:17 2009
@@ -62,11 +62,9 @@
private:
Modified: trunk/src/detail/writer.cpp
--- trunk/src/detail/writer.cpp (original)
+++ trunk/src/detail/writer.cpp Wed Feb 11 10:49:17 2009
@@ -53,7 +53,7 @@
namespace liblas { namespace detail {
-Writer::Writer()
+Writer::Writer(std::ostream& ofs) : m_ofs(ofs)
@@ -61,11 +61,16 @@
+std::ostream& Writer::GetStream() const
+ return m_ofs;
void Writer::FillPointRecord(PointRecord& record, const LASPoint& point, const LASHeader& header)
- record.x = static_cast<uint32_t>((point.GetX() - header.GetOffsetX()) / header.GetScaleX());
- record.y = static_cast<uint32_t>((point.GetY() - header.GetOffsetY()) / header.GetScaleY());
- record.z = static_cast<uint32_t>((point.GetZ() - header.GetOffsetZ()) / header.GetScaleZ());
+ record.x = static_cast<int32_t>((point.GetX() - header.GetOffsetX()) / header.GetScaleX());
+ record.y = static_cast<int32_t>((point.GetY() - header.GetOffsetY()) / header.GetScaleY());
+ record.z = static_cast<int32_t>((point.GetZ() - header.GetOffsetZ()) / header.GetScaleZ());
record.intensity = point.GetIntensity();
record.flags = point.GetScanFlags();
record.classification = point.GetClassification();
@@ -73,6 +78,26 @@
record.user_data = point.GetUserData();
record.point_source_id = point.GetPointSourceID();
+void Writer::WriteVLR(LASHeader const& header)
+ m_ofs.seekp(header.GetHeaderSize(), std::ios::beg);
+ for (uint32_t i = 0; i < header.GetRecordsCount(); ++i)
+ LASVLR vlr = header.GetVLR(i);
+ detail::write_n(m_ofs, vlr.GetReserved(), sizeof(uint16_t));
+ detail::write_n(m_ofs, vlr.GetUserId(true).c_str(), 16);
+ detail::write_n(m_ofs, vlr.GetRecordId(), sizeof(uint16_t));
+ detail::write_n(m_ofs, vlr.GetRecordLength(), sizeof(uint16_t));
+ detail::write_n(m_ofs, vlr.GetDescription(true).c_str(), 32);
+ std::vector<uint8_t> const& data = vlr.GetData();
+ std::streamsize const size = static_cast<std::streamsize>(data.size());
+ detail::write_n(m_ofs, data.front(), size);
Writer* WriterFactory::Create(std::ostream& ofs, LASHeader const& header)
if (!ofs)
Modified: trunk/src/detail/writer10.cpp
--- trunk/src/detail/writer10.cpp (original)
+++ trunk/src/detail/writer10.cpp Wed Feb 11 10:49:17 2009
@@ -54,7 +54,7 @@
namespace liblas { namespace detail { namespace v10 {
WriterImpl::WriterImpl(std::ostream& ofs) :
- Base(), m_ofs(ofs), m_pointCount(0)
+ Base(ofs), m_pointCount(0)
@@ -243,17 +243,6 @@
++m_pointCount;
-// void WriterImpl::WritePointRecord(detail::PointRecord const& record, double const& time)
-// // TODO: Static assert would be better
-// assert(28 == sizeof(record) + sizeof(time));
-// // Write point data record format 1
-// WritePointRecord(record);
-// detail::write_n(m_ofs, time, sizeof(double));
void WriterImpl::WriteVLR(LASHeader const& header)
@@ -273,9 +262,5 @@
-std::ostream& WriterImpl::GetStream() const
- return m_ofs;
}}} // namespace liblas::detail::v10
Modified: trunk/src/detail/writer11.cpp
--- trunk/src/detail/writer11.cpp (original)
+++ trunk/src/detail/writer11.cpp Wed Feb 11 10:49:17 2009
@@ -54,7 +54,7 @@
namespace liblas { namespace detail { namespace v11 {
@@ -244,16 +244,6 @@
++m_pointCount;
@@ -274,10 +264,5 @@
- return m_ofs;
}}} // namespace liblas::detail::v11
Modified: trunk/src/detail/writer12.cpp
--- trunk/src/detail/writer12.cpp (original)
+++ trunk/src/detail/writer12.cpp Wed Feb 11 10:49:17 2009
@@ -54,7 +54,7 @@
namespace liblas { namespace detail { namespace v12 {
@@ -269,18 +269,6 @@
++m_pointCount;
@@ -300,10 +288,6 @@
- return m_ofs;
}}} // namespace liblas::detail::v12
More information about the Liblas-commits
