[Liblas-commits] r1037 - trunk/include/liblas
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Feb 17 12:57:42 EST 2009
Author: hobu
Date: Tue Feb 17 12:57:41 2009
New Revision: 1037
URL: http://liblas.org/changeset/1037
docs for LASSRS
   trunk/include/liblas/lassrs.hpp
Modified: trunk/include/liblas/lassrs.hpp
--- trunk/include/liblas/lassrs.hpp	(original)
+++ trunk/include/liblas/lassrs.hpp	Tue Feb 17 12:57:41 2009
@@ -95,17 +95,53 @@
     LASSRS(LASSRS const& other);
     LASSRS& operator=(LASSRS const& rhs);
+#ifdef HAVE_LIBGEOTIFF
+    /// Returns a pointer to the internal GTIF*.  Only available if
+    /// you have libgeotiff linked in.
     const GTIF* GetGTIF();
-    void SetGTIF(const GTIF* gtiff);
+#endif
+    /// Reset the VLRs of the LASSRS using the existing GTIF* and ST_TIF*
+    /// Until this method is called,
+    /// the LASSRS will only contain a SRS description using the VLRs
+    /// that it was first instantiated with.  SetWKT and SetProj4 can
+    /// be used to change the GTIF*
     void ResetVLRs();
+    /// Returns the OGC WKT describing Spatial Reference System.
+    /// If GDAL is linked, it uses GDAL's operations and methods to determine
+    /// the WKT.  If GDAL is not linked, no WKT is returned.
     std::string GetWKT() const;
+    /// Sets the SRS using GDAL's OGC WKT. If GDAL is not linked, this
+    /// operation has no effect.
+    /// \param v - a string containing the WKT string.
     void SetWKT(std::string const& v);
+    /// Returns the Proj.4 string describing the Spatial Reference System.
+    /// the Proj.4 string -- otherwise, if libgeotiff is linked, it uses
+    /// that.  Note that GDAL's operations are much more mature and
+    /// support more coordinate systems and descriptions.
     std::string GetProj4() const;
+    /// Sets the Proj.4 string describing the Spatial Reference System.
+    /// \param v - a string containing the Proj.4 string.
     void SetProj4(std::string const& v);
+    /// Set the LASVLRs for the LASSRS.  SetVLRs will only copy
+    /// VLR records that pertain to the GeoTIFF keys, and extraneous
+    /// VLR records will not be copied.
+    /// \param vlrs - A list of VLRs that contains VLRs describing GeoTIFF keys
     void SetVLRs(const std::vector<LASVLR>& vlrs);
+    /// Return a copy of the LASVLRs that LASSRS maintains
     std::vector<LASVLR> GetVLRs() const;
More information about the Liblas-commits mailing list
