[Liblas-commits] r1038 - trunk/test/data
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Feb 17 13:48:54 EST 2009
Author: hobu
Date: Tue Feb 17 13:48:53 2009
New Revision: 1038
URL: http://liblas.org/changeset/1038
add make_data script
Added:
   trunk/test/data/make_data.py
Added: trunk/test/data/make_data.py
--- (empty file)
+++ trunk/test/data/make_data.py	Tue Feb 17 13:48:53 2009
@@ -0,0 +1,44 @@
+from liblas import file
+from liblas import header
+from liblas import point
+from liblas import color
+import datetime
+h = header.Header()
+h.date = datetime.datetime.now()
+h.dataformat_id = 1
+h.proj4 = '+proj=utm +zone=17 +ellps=WGS84 +datum=WGS84 +units=m +no_defs '
+p = point.Point()
+p.flightline_edge = 0
+p.return_number = 1
+p.classification = 0
+p.scan_angle = -13
+p.x = 42.0000
+p.y = -93.00
+p.z = 16.0
+p.color.red=255
+p.color.green=12
+p.color.blue=234
+p.time = datetime.datetime.now()
+print p.time
+def write_file(version, format):
+    h = header.Header()
+    h.date = datetime.datetime.now()
+    h.dataformat_id = format
+    h.major_version = 1
+    h.minor_version = version
+    f = file.File('test_1.%d_pointformat%d.las'%(version,format), mode='w', header=h)
+    f.write(p)
+    f.close()
+write_file(0,0)
+write_file(0,1)
+write_file(1,0)
+write_file(1,1)
+write_file(2,0)
+write_file(2,1)
+write_file(2,2)
+write_file(2,3)
\ No newline at end of file
More information about the Liblas-commits mailing list
