[Liblas-commits] r1072 - in trunk: build/msvc90/liblas_lib src
src/detail
liblas-commits at liblas.org
Wed Feb 25 08:02:22 EST 2009
Author: mloskot
Date: Wed Feb 25 08:02:21 2009
New Revision: 1072
URL: http://liblas.org/changeset/1072
* Updated project files for Visual C++ 2008.
* Cleaned up some warnings.
trunk/build/msvc90/liblas_lib/liblas_lib.vcproj
trunk/src/detail/reader.cpp
trunk/src/detail/writer.cpp
trunk/src/lasheader.cpp
trunk/src/lassrs.cpp
Modified: trunk/build/msvc90/liblas_lib/liblas_lib.vcproj
--- trunk/build/msvc90/liblas_lib/liblas_lib.vcproj (original)
+++ trunk/build/msvc90/liblas_lib/liblas_lib.vcproj Wed Feb 25 08:02:21 2009
@@ -169,6 +169,10 @@
</File>
<File
+ RelativePath="..\..\..\include\liblas\lascolor.hpp"
+ </File>
+ <File
RelativePath="..\..\..\include\liblas\laserror.hpp"
</File>
@@ -193,6 +197,10 @@
</File>
<File
+ RelativePath="..\..\..\include\liblas\lassrs.hpp"
+ </File>
+ <File
RelativePath="..\..\..\include\liblas\laswriter.hpp"
</File>
@@ -228,6 +236,10 @@
</File>
<File
+ RelativePath="..\..\..\include\liblas\detail\reader12.hpp"
+ </File>
+ <File
RelativePath="..\..\..\include\liblas\detail\sha1.hpp"
</File>
@@ -255,6 +267,10 @@
RelativePath="..\..\..\include\liblas\detail\writer11.hpp"
</File>
+ <File
+ RelativePath="..\..\..\include\liblas\detail\writer12.hpp"
+ </File>
</Filter>
</Filter>
</Filter>
@@ -262,6 +278,14 @@
Name="src"
<File
+ RelativePath="..\..\..\src\las_c_api.cpp"
+ </File>
+ <File
+ RelativePath="..\..\..\src\lascolor.cpp"
+ </File>
+ <File
RelativePath="..\..\..\src\laserror.cpp"
</File>
@@ -286,6 +310,10 @@
</File>
<File
+ RelativePath="..\..\..\src\lassrs.cpp"
+ </File>
+ <File
RelativePath="..\..\..\src\laswriter.cpp"
</File>
@@ -309,6 +337,10 @@
</File>
<File
+ RelativePath="..\..\..\src\detail\reader12.cpp"
+ </File>
+ <File
RelativePath="..\..\..\src\detail\writer.cpp"
</File>
@@ -320,6 +352,10 @@
RelativePath="..\..\..\src\detail\writer11.cpp"
</File>
+ <File
+ RelativePath="..\..\..\src\detail\writer12.cpp"
+ </File>
</Filter>
</Filter>
</Files>
Modified: trunk/src/detail/reader.cpp
--- trunk/src/detail/reader.cpp (original)
+++ trunk/src/detail/reader.cpp Wed Feb 25 08:02:21 2009
@@ -200,7 +200,8 @@
point.SetX(x);
point.SetY(y);
point.SetZ(z);
+#else
+ UNREFERENCED_PARAMETER(point);
#endif
Modified: trunk/src/detail/writer.cpp
--- trunk/src/detail/writer.cpp (original)
+++ trunk/src/detail/writer.cpp Wed Feb 25 08:02:21 2009
@@ -157,7 +157,8 @@
point.x = x;
point.y = y;
point.z = z;
+#else
#endif
Writer* WriterFactory::Create(std::ostream& ofs, LASHeader const& header)
Modified: trunk/src/lasheader.cpp
--- trunk/src/lasheader.cpp (original)
+++ trunk/src/lasheader.cpp Wed Feb 25 08:02:21 2009
@@ -404,7 +404,7 @@
void LASHeader::SetDataFormatId(LASHeader::PointFormat v)
- m_dataFormatId = v;
+ m_dataFormatId = static_cast<uint8_t>(v);
if (ePointFormat0 == m_dataFormatId)
m_dataRecordLen = ePointSize0;
Modified: trunk/src/lassrs.cpp
--- trunk/src/lassrs.cpp (original)
+++ trunk/src/lassrs.cpp Wed Feb 25 08:02:21 2009
@@ -387,7 +387,7 @@
ResetVLRs();
#else
+ UNREFERENCED_PARAMETER(v);
throw std::runtime_error("GDAL is not available, LASSRS could not be set from WKT");
#endif
@@ -443,7 +443,6 @@
void LASSRS::SetProj4(std::string const& v)
if (! m_gtiff ) GetGTIF(); ResetVLRs();
#ifdef HAVE_GDAL
@@ -481,7 +480,8 @@
std::string tmp(proj4def);
std::free(proj4def);
+#else
#endif
// if we have libgeotiff but not GDAL, we'll use the
More information about the Liblas-commits
