[Liblas-commits] r1073 - in trunk: include/liblas src
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Feb 25 18:51:22 EST 2009
Author: mloskot
Date: Wed Feb 25 18:51:22 2009
New Revision: 1073
URL: http://liblas.org/changeset/1073
Little refactoring of LASRSR class.
   trunk/include/liblas/lassrs.hpp
   trunk/src/lassrs.cpp
Modified: trunk/include/liblas/lassrs.hpp
--- trunk/include/liblas/lassrs.hpp	(original)
+++ trunk/include/liblas/lassrs.hpp	Wed Feb 25 18:51:22 2009
@@ -96,10 +96,20 @@
+    /// Default constructor.
     LASSRS();
+    /// Destructor.
+    /// If libgeotiff is enabled, deallocates libtiff and libgeotiff objects used internally.
     ~LASSRS();
+    /// Constructor creating LASSRS instance from given Variable-Length Record.
     LASSRS(const std::vector<LASVLR>& vlrs);
+    /// Copy constryctor.
     LASSRS(LASSRS const& other);
+    /// Assignment operator.
     LASSRS& operator=(LASSRS const& rhs);
@@ -159,23 +169,17 @@
     /// that it was first instantiated with.  SetWKT and SetProj4 can
     /// be used to change the GTIF*
     void ResetVLRs();
-protected:
 } // namespace liblas
 #ifdef HAVE_GDAL
 LAS_C_START
-char LAS_DLL *  GTIFGetOGISDefn( GTIF *, GTIFDefn * );
-int  LAS_DLL   GTIFSetFromOGISDefn( GTIF *, const char * );
+char LAS_DLL * GTIFGetOGISDefn(GTIF*, GTIFDefn*);
+int  LAS_DLL   GTIFSetFromOGISDefn(GTIF*, const char*);
 void SetLinearUnitCitation(GTIF* psGTIF, char* pszLinearUOMName);
-void SetGeogCSCitation(GTIF * psGTIF, OGRSpatialReference *poSRS, char* angUnitName, int nDatum, short nSpheroid);
+void SetGeogCSCitation(GTIF* psGTIF, OGRSpatialReference* poSRS, char* angUnitName, int nDatum, short nSpheroid);
 LAS_C_END
 #endif
Modified: trunk/src/lassrs.cpp
--- trunk/src/lassrs.cpp	(original)
+++ trunk/src/lassrs.cpp	Wed Feb 25 18:51:22 2009
@@ -43,14 +43,13 @@
 #include <liblas/detail/utility.hpp>
 #include <iostream>
-namespace liblas {
-LASSRS::LASSRS()
+namespace liblas
-    m_tiff = NULL;
-    m_gtiff = NULL;
+LASSRS::LASSRS() :
+    m_gtiff(NULL),
+    m_tiff(NULL)
 LASSRS& LASSRS::operator=(LASSRS const& rhs)
@@ -66,9 +65,7 @@
 LASSRS::~LASSRS()
 #ifdef HAVE_LIBGEOTIFF
     if (m_gtiff)
@@ -81,7 +78,6 @@
         m_tiff = NULL;
 #endif
 LASSRS::LASSRS(LASSRS const& other)
@@ -92,7 +88,7 @@
     GetGTIF();
-LASSRS::LASSRS(const std::vector<LASVLR>& vlrs)
+LASSRS::LASSRS(std::vector<LASVLR> const& vlrs)
     m_tiff = NULL;
     m_gtiff = NULL;
@@ -101,9 +97,8 @@
 /// Keep a copy of the VLRs that are related to GeoTIFF SRS information.
-void LASSRS::SetVLRs(const std::vector<LASVLR>& vlrs)
+void LASSRS::SetVLRs(std::vector<LASVLR> const& vlrs)
-    std::vector<LASVLR>::const_iterator i;
     std::string const uid("LASF_Projection");
@@ -112,11 +107,16 @@
     // We only copy VLR records from the list which are related to GeoTIFF keys.
     // They must have an id of "LASF_Projection" and a record id that's related.
-    for (i = vlrs.begin(); i != vlrs.end(); ++i)
+    std::vector<LASVLR>::const_iterator it;
+    for (it = vlrs.begin(); it != vlrs.end(); ++it)
-        if (IsGeoVLR(*i)) {
-            m_vlrs.push_back(*i);
+        LASVLR const& vlr = *it;
+        if (IsGeoVLR(vlr))
+            m_vlrs.push_back(vlr);
+        // TODO:
         // //GTIFF_GEOKEYDIRECTORY == 34735
         // if (uid == (*i).GetUserId(true).c_str() && 34735 == (*i).GetRecordId()) {
         //     m_vlrs.push_back(*i);
@@ -134,28 +134,34 @@
-void LASSRS::AddVLR(const LASVLR& vlr)
+void LASSRS::AddVLR(LASVLR const& vlr)
-    if (IsGeoVLR(vlr)) {
-bool LASSRS::IsGeoVLR(const LASVLR& vlr) const
+bool LASSRS::IsGeoVLR(LASVLR const& vlr) const
-    if (uid == vlr.GetUserId(true).c_str() && 34735 == vlr.GetRecordId()) {
+    if (uid == vlr.GetUserId(true).c_str() && 34735 == vlr.GetRecordId())
         return true;
     // GTIFF_DOUBLEPARAMS == 34736
-    if (uid == vlr.GetUserId(true).c_str() && 34736 == vlr.GetRecordId()) {
+    if (uid == vlr.GetUserId(true).c_str() && 34736 == vlr.GetRecordId())
         return true;
     // GTIFF_ASCIIPARAMS == 34737
-    if (uid == vlr.GetUserId(true).c_str() && 34737 == vlr.GetRecordId()) {
+    if (uid == vlr.GetUserId(true).c_str() && 34737 == vlr.GetRecordId())
         return true;
     return false;
@@ -169,9 +175,7 @@
     m_vlrs.clear();
-#ifndef HAVE_LIBGEOTIFF
-    return;
-#else
+#ifdef HAVE_LIBGEOTIFF
     int ret = 0;
     short* kdata = NULL;
@@ -187,8 +191,11 @@
     int acount = 0;
     int atype =0;
-    if (!m_tiff) throw std::invalid_argument("m_tiff was null, cannot reset VLRs without m_tiff");
-    if (!m_gtiff) throw std::invalid_argument("m_gtiff was null, cannot reset VLRs without m_gtiff");
+    if (!m_tiff)
+        throw std::invalid_argument("m_tiff was null, cannot reset VLRs without m_tiff");
+    if (!m_gtiff)
+        throw std::invalid_argument("m_gtiff was null, cannot reset VLRs without m_gtiff");
     ret = ST_GetKey(m_tiff, 34735, &kcount, &ktype, (void**)&kdata);
@@ -269,16 +276,19 @@
          // didn't calculate the string length for an ASCII geotiff tag.
          // We need to throw an exception in this case because we're
          // screwed, and if we don't we'll end up writing bad GeoTIFF keys.
-         if (!acount) {
+         if (!acount)
              throw std::runtime_error("GeoTIFF ASCII key with no returned size. "
                                       "Upgrade your libgeotiff to a version greater "
                                       "than r1531 (libgeotiff 1.2.6)");
          uint16_t length = acount;
          record.SetRecordLength(length);
          // Copy the data into the data vector
-         for (i=0; i<acount;i++) {
+         for (i=0; i<acount;i++)
              avalue = adata[i];
              uint8_t* v =  reinterpret_cast<uint8_t*>(&avalue);
@@ -296,20 +306,29 @@
          record.SetData(data);
          m_vlrs.push_back(record);
 #endif // ndef HAVE_LIBGEOTIFF
-const GTIF* LASSRS::GetGTIF(){
+const GTIF* LASSRS::GetGTIF()
+#ifndef HAVE_LIBGEOTIFF
+    return 0;
+#else
-#ifdef HAVE_LIBGEOTIFF
     // If we already have m_gtiff and m_tiff, that is because we have
     // already called GetGTIF once before.  VLRs ultimately drive how the
     // LASSRS is defined, not the GeoTIFF keys.
-    if (m_tiff) {ST_Destroy(m_tiff); m_tiff = NULL;}
-    if (m_gtiff) {GTIFFree(m_gtiff); m_gtiff = NULL; }
+    if (m_tiff)
+        ST_Destroy(m_tiff);
+        m_tiff = NULL;
+    if (m_gtiff)
+        GTIFFree(m_gtiff);
+        m_gtiff = NULL;
     m_tiff = ST_Create();
@@ -342,82 +361,88 @@
     m_gtiff = GTIFNewSimpleTags(m_tiff);
     if (!m_gtiff)
         throw std::runtime_error("The geotiff keys could not read from VLR records");
     return m_gtiff;
 #endif
-    return NULL;
 /// Fetch the SRS as WKT
 std::string LASSRS::GetWKT() const
-#ifdef HAVE_GDAL
+#ifndef HAVE_GDAL
+    return std::string();
+#else
     GTIFDefn sGTIFDefn;
     char* pszWKT = NULL;
-    if (!m_gtiff) return std::string("");
-    if( GTIFGetDefn( m_gtiff, &sGTIFDefn ) ) {
+    if (!m_gtiff)
+    if (GTIFGetDefn(m_gtiff, &sGTIFDefn))
         pszWKT = GTIFGetOGISDefn( m_gtiff, &sGTIFDefn );
-        if (pszWKT) {
+        if (pszWKT)
             std::string tmp(pszWKT);
             std::free(pszWKT);
             return tmp;
 #endif
-    return std::string("");
 void LASSRS::SetWKT(std::string const& v)
-    if (! m_gtiff ) GetGTIF();
+    if (!m_gtiff)
+        GetGTIF();
 #ifdef HAVE_GDAL
     int ret = 0;
     ret = GTIFSetFromOGISDefn( m_gtiff, v.c_str() );
     if (!ret)
         throw std::invalid_argument("could not set m_gtiff from WKT");
     ret = GTIFWriteKeys(m_gtiff);
     if (!ret)
         throw std::runtime_error("The geotiff keys could not be written");
     ResetVLRs();
 #else
     UNREFERENCED_PARAMETER(v);
     throw std::runtime_error("GDAL is not available, LASSRS could not be set from WKT");
 #endif
 std::string LASSRS::GetProj4() const
 #ifdef HAVE_GDAL
     std::string wkt = GetWKT();
     const char* poWKT = wkt.c_str();
     OGRSpatialReference* poSRS = new OGRSpatialReference();
-    if( poSRS->importFromWkt((char **) &poWKT) != OGRERR_NONE )
+    if (OGRERR_NONE != poSRS->importFromWkt((char **) &poWKT))
         delete poSRS;
-    char* proj4;
+    char* proj4 = 0;
     poSRS->exportToProj4(&proj4);
     std::string tmp(proj4);
     std::free(proj4);
     delete poSRS;
-    return tmp;
+    return tmp;
 #endif
 // if we have libgeotiff but not GDAL, we'll use the
@@ -437,20 +462,23 @@
 #endif
 #endif
-// If we have neither GDAL nor proj.4, we can't do squat
+    // If we have neither GDAL nor proj.4, we can't do squat
 void LASSRS::SetProj4(std::string const& v)
-    if (! m_gtiff ) GetGTIF(); ResetVLRs();
+    if (!m_gtiff)
+        GetGTIF();
+        ResetVLRs();
 #ifdef HAVE_GDAL
-    char* poWKT = NULL;
+    char* poWKT = 0;
     const char* poProj4 = v.c_str();
-    if( poSRS->importFromProj4((char *) poProj4) != OGRERR_NONE )
+    if (OGRERR_NONE != poSRS->importFromProj4((char *) poProj4))
         delete poSRS;
         throw std::invalid_argument("could not import proj4 into OSRSpatialReference SetProj4");
@@ -464,7 +492,10 @@
     int ret = 0;
     ret = GTIFSetFromOGISDefn( m_gtiff, tmp.c_str() );
-    if (!ret) throw std::invalid_argument("could not set m_gtiff from Proj4");
+    if (!ret)
+        throw std::invalid_argument("could not set m_gtiff from Proj4");
     if (!ret)
@@ -495,6 +526,7 @@
         throw std::invalid_argument("PROJ.4 string is invalid or unsupported");
     if (!ret)
@@ -503,9 +535,7 @@
 #endif
 #endif
     ResetVLRs();
More information about the Liblas-commits mailing list
