[Liblas-commits] r1273 - in trunk: apps include/liblas src
liblas-commits at liblas.org
Mon Jun 8 21:52:13 EDT 2009
Author: hobu
Date: Wed May 20 12:56:45 2009
New Revision: 1273
URL: http://liblas.org/changeset/1273
more refactoring
trunk/apps/lasindex.cpp
trunk/include/liblas/lasindex.hpp
trunk/src/lasindex.cpp
Modified: trunk/apps/lasindex.cpp
--- trunk/apps/lasindex.cpp (original)
+++ trunk/apps/lasindex.cpp Wed May 20 12:56:45 2009
@@ -111,9 +111,10 @@
LASReader* reader = new LASReader(*istrm);
- LASDataStream* idxstrm = new LASDataStream(reader);
+ LASIndexDataStream* idxstrm = new LASIndexDataStream(reader);
- LASIndex* index = new LASIndex(*idxstrm, input);
+ LASIndex* index = new LASIndex( input);
+ index->Initialize(*idxstrm);
delete idxstrm;
delete index;
@@ -121,6 +122,7 @@
LASIndex* idx = new LASIndex(input);
+ idx->Initialize();
std::vector<liblas::uint32_t>* ids = 0;
try{
@@ -141,32 +143,34 @@
- std::cout << "Vec length" << ids->size() << std::endl;
- delete idx;
- LASIndex* index = new LASIndex(*idxstrm, "MEMORY");
- //doing it in memory
- std::vector<liblas::uint32_t>* ids = 0;
- try{
-// ids = idx->intersects(289815.12,4320979.06, 289818.01,4320982.59,46.83,170.65);
-// _zoom
-// ids = idx->intersects(630355.0,4834609.0,630395.0,4834641.0,0.0,200.0);
-// _clip
-// 630346.830000,4834500.000000,55.260000
- ids = index->intersects(630262.300000,4834500.000000,630346.830000,4834500.000000,50.900000,55.260000);
-// ids = idx->intersects(630297.0,4834497.0,630302.0,4834501.0,0.0,200.0);
- } catch (Tools::Exception& e) {
- std::string s = e.what();
- std::cout << "error querying index value" << s <<std::endl; exit(1);
+// std::cout << "Vec length" << ids->size() << std::endl;
+// delete idx;
+// LASIndexDataStream* idstrm = new LASIndexDataStream(reader);
+// LASIndex* index = new LASIndex("MEMORY");
+// in
+// //doing it in memory
+// std::vector<liblas::uint32_t>* ids = 0;
+// try{
+// // ids = idx->intersects(289815.12,4320979.06, 289818.01,4320982.59,46.83,170.65);
+// // _zoom
+// // ids = idx->intersects(630355.0,4834609.0,630395.0,4834641.0,0.0,200.0);
+// // _clip
+// // 630346.830000,4834500.000000,55.260000
+// ids = index->intersects(630262.300000,4834500.000000,630346.830000,4834500.000000,50.900000,55.260000);
+// // ids = idx->intersects(630297.0,4834497.0,630302.0,4834501.0,0.0,200.0);
+// } catch (Tools::Exception& e) {
+// std::string s = e.what();
+// std::cout << "error querying index value" << s <<std::endl; exit(1);
// LASPoint* p
Modified: trunk/include/liblas/lasindex.hpp
--- trunk/include/liblas/lasindex.hpp (original)
+++ trunk/include/liblas/lasindex.hpp Wed May 20 12:56:45 2009
@@ -56,7 +56,7 @@
namespace liblas {
-class LASDataStream;
+class LASIndexDataStream;
class LASIndex
@@ -70,12 +70,14 @@
LASIndex();
- LASIndex(LASDataStream& strm, std::string& filename);
LASIndex(std::string& filename);
/// Copy constructor.
LASIndex(LASIndex const& other);
~LASIndex();
+ void Initialize(LASIndexDataStream& strm);
+ void Initialize();
/// Assignment operator.
LASIndex& operator=(LASIndex const& rhs);
@@ -83,7 +85,20 @@
bool operator==(const LASIndex& other) const;
+ /// Inserts a LASPoint into the index with a given id
+ /// \param p the LASPoint to insert
+ /// \param id the id to associate with the point
void insert(LASPoint& p, int64_t id);
+ /// Intersects the index with the given cube and returns a
+ /// std::vector of ids. Caller has ownership of the vector.
+ /// \param minx minimum X value of the cube
+ /// \param maxx maximum X value of the cube
+ /// \param miny minimum Y value of the cube
+ /// \param maxy maximum Y value of the cube
+ /// \param minz minimum Z value of the cube
+ /// \param maxz maximum Z value of the cube
+ /// \return std::vector<uint32_t> that the caller owns containing the ids that intersect the query.
std::vector<uint32_t>* intersects(double minx, double miny, double maxx, double maxy, double minz, double maxz);
/// Sets the page size for the index when stored externally
@@ -95,7 +110,7 @@
uint32_t GetPageSize() { return m_Pagesize; }
/// Sets the index type
- /// \param v - index type.
+ /// \param v - index type. Defaults to eExternalIndex.
void SetIndexType(IndexType v) { m_idxType = v; }
/// Gets the index type
@@ -117,14 +132,18 @@
double m_idxFillFactor;
bool m_idxExists;
+ std::string m_idxFilename;
uint16_t m_bufferCapacity;
bool m_bufferWriteThrough;
- void Init();
+ bool m_Initialized;
+ void Setup();
SpatialIndex::IStorageManager* CreateStorage(std::string& filename);
SpatialIndex::StorageManager::IBuffer* CreateIndexBuffer(SpatialIndex::IStorageManager& storage);
- SpatialIndex::ISpatialIndex* CreateIndex(LASDataStream& strm);
+ SpatialIndex::ISpatialIndex* CreateIndex(LASIndexDataStream& strm);
SpatialIndex::ISpatialIndex* LoadIndex();
bool ExternalIndexExists(std::string& filename);
@@ -146,15 +165,11 @@
void visitData(std::vector<const SpatialIndex::IData*>& v);
-class LASDataStream : public SpatialIndex::IDataStream
+class LASIndexDataStream : public SpatialIndex::IDataStream
public:
- LASDataStream(LASReader* reader);
- ~LASDataStream()
- if (m_pNext != 0) delete m_pNext;
+ LASIndexDataStream(LASReader* reader);
+ ~LASIndexDataStream();
SpatialIndex::IData* getNext();
bool hasNext() throw (Tools::NotSupportedException);
Modified: trunk/src/lasindex.cpp
--- trunk/src/lasindex.cpp (original)
+++ trunk/src/lasindex.cpp Wed May 20 12:56:45 2009
@@ -54,8 +54,12 @@
namespace liblas
-void LASIndex::Init()
+void LASIndex::Setup()
+ // set default values for member variables
+ // actual initialization of the index must happen externally with
+ // Initialize. This allows the changing of the member variables
+ // with the setters/getters.
m_Pagesize = 4096;
m_idxType = eExternalIndex;
@@ -71,15 +75,83 @@
m_bufferWriteThrough = false;
m_idxExists = false;
+ m_idxFilename = std::string("");
+ m_Initialized = false;
LASIndex::LASIndex()
std::cout << "Blank Index Constructor called!" << std::endl;
- Init();
+ Setup();
+LASIndex::LASIndex(std::string& filename)
+ Setup();
+ m_idxFilename = filename;
+LASIndex::LASIndex(LASIndex const& other)
+ std::cout << "Index copy called" << std::endl;
+LASIndex::~LASIndex()
+ std::cout << "~LASIndex called" << std::endl;
+ if (m_rtree != 0)
+ delete m_rtree;
+ if (m_buffer != 0)
+ delete m_buffer;
+ if (m_storage != 0)
+ delete m_storage;
+void LASIndex::Initialize()
+ m_storage = CreateStorage(m_idxFilename);
+ m_buffer = CreateIndexBuffer(*m_storage);
+ if (m_idxExists == true) {
+ std::cout << "loading existing index from file " << std::endl;
+ m_rtree = LoadIndex();
+ else
+ throw std::runtime_error("can't create index with only a filename, must have LASDatastream");
+ m_Initialized = true;
-SpatialIndex::ISpatialIndex* LASIndex::CreateIndex(LASDataStream& strm)
+void LASIndex::Initialize(LASIndexDataStream& strm)
+ std::cout << "loading existing index from LASIndexDataStream " << std::endl;
+ else
+ std::cout << "Creating new index from LASIndexDataStream ... " << std::endl;
+ m_rtree = CreateIndex(strm);
+SpatialIndex::ISpatialIndex* LASIndex::CreateIndex(LASIndexDataStream& strm)
using namespace SpatialIndex;
@@ -97,8 +169,8 @@
m_idxId);
bool ret = index->isIndexValid();
if (ret == false)
- throw std::runtime_error( "Spatial index error: index is not"
- " valid after createAndBulkLoadNewRTree");
+ throw std::runtime_error( "Spatial index error: index is not "
+ "valid after createAndBulkLoadNewRTree");
return index;
@@ -128,26 +200,6 @@
throw std::runtime_error(os.str());
-LASIndex::LASIndex(LASDataStream& strm, std::string& filename)
- using namespace SpatialIndex;
- Init();
- m_storage = CreateStorage(filename);
- m_buffer = CreateIndexBuffer(*m_storage);
- if (m_idxExists == true) {
- std::cout << "loading existing index from LASDataStream " << std::endl;
- m_rtree = LoadIndex();
- else
- std::cout << "Creating new index from LASDataStream ... " << std::endl;
- m_rtree = CreateIndex(strm);
SpatialIndex::IStorageManager* LASIndex::CreateStorage(std::string& filename)
@@ -233,44 +285,6 @@
return output;
-LASIndex::LASIndex(std::string& filename)
- Init();
- std::cout << "loading existing index from file " << std::endl;
- else
- throw std::runtime_error("can't create index with only a filename, must have LASDatastream");
-LASIndex::LASIndex(LASIndex const& other)
- std::cout << "Index copy called" << std::endl;
-LASIndex::~LASIndex()
- std::cout << "~LASIndex called" << std::endl;
- if (m_rtree != 0)
- delete m_rtree;
- if (m_buffer != 0)
- delete m_buffer;
- if (m_storage != 0)
- delete m_storage;
LASIndex& LASIndex::operator=(LASIndex const& rhs)
@@ -302,11 +316,15 @@
max[1] = p.GetY();
max[2] = p.GetZ();
- try{
+ if (m_Initialized = false)
+ throw std::runtime_error("Spatial index has not been initialized");
+ try {
m_rtree->insertData(0, 0, SpatialIndex::Region(min, max, 3), id);
- std::cout << "error inserting index value" << s <<std::endl; exit(1);
+ std::ostringstream os;
+ os << "Spatial Index Error: " << e.what();
+ throw std::runtime_error(os.str());
@@ -322,18 +340,26 @@
max[0] = maxx;
max[1] = maxy;
max[2] = maxz;
- std::cout.setf(std::ios_base::fixed);
- // std::cout << "minx: " << min[0] << " miny: "<<min[1] << " maxx: " <<max[0] << " maxy: " << max[1] << " minz: " << min[2] << " maxz: " << max[2] <<std::endl;
- if (min[0] > max[0] || min[1] > max[1]) {std::cout << "epic fail!" << std::endl;};
+ // std::cout.setf(std::ios_base::fixed);
+ // std::cout << "Query bounds" << SpatialIndex::Region(min, max, 3) << std::endl;
std::vector<uint32_t>* vect = new std::vector<uint32_t>;
LASVisitor* visitor = new LASVisitor(vect);
- const SpatialIndex::Region *region = new SpatialIndex::Region(min, max, 3);
- // std::cout << *region << std::endl;
- m_rtree->intersectsWithQuery(*region, *visitor);
- // std::cout << index() <<std::endl;
+ try {
+ m_rtree->intersectsWithQuery(SpatialIndex::Region(min, max, 3), *visitor);
+ } catch (Tools::Exception& e) {
+ delete visitor;
+ delete visitor;
return vect;
@@ -441,18 +467,18 @@
-LASDataStream::LASDataStream(LASReader *reader) : m_reader(reader), m_pNext(0), m_id(0)
+LASIndexDataStream::LASIndexDataStream(LASReader *reader) : m_reader(reader), m_pNext(0), m_id(0)
- bool read = readPoint();
- if (read)
- m_id = 0;
+ m_id = 0;
+ readPoint();
- std::cout<<"Initiating LASDataStream... read=" << read <<std::endl;
+LASIndexDataStream::~LASIndexDataStream()
+ if (m_pNext != 0) delete m_pNext;
-bool LASDataStream::readPoint()
+bool LASIndexDataStream::readPoint()
double min[3], max[3];
@@ -479,7 +505,7 @@
-SpatialIndex::IData* LASDataStream::getNext()
+SpatialIndex::IData* LASIndexDataStream::getNext()
if (m_pNext == 0) return 0;
@@ -490,20 +516,20 @@
return ret;
-bool LASDataStream::hasNext() throw (Tools::NotSupportedException)
+bool LASIndexDataStream::hasNext() throw (Tools::NotSupportedException)
- // std::cout << "LASDataStream::hasNext called ..." << std::endl;
+ // std::cout << "LASIndexDataStream::hasNext called ..." << std::endl;
return (m_pNext != 0);
-size_t LASDataStream::size() throw (Tools::NotSupportedException)
+size_t LASIndexDataStream::size() throw (Tools::NotSupportedException)
throw Tools::NotSupportedException("Operation not supported.");
-void LASDataStream::rewind() throw (Tools::NotSupportedException)
+void LASIndexDataStream::rewind() throw (Tools::NotSupportedException)
- // std::cout << "LASDataStream::rewind called..." << std::endl;
+ // std::cout << "LASIndexDataStream::rewind called..." << std::endl;
if (m_pNext != 0)
More information about the Liblas-commits
