[Liblas-commits] r1285 - in trunk: . apps m4 src
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jun 8 21:52:14 EDT 2009
Author: hobu
Date: Fri May 22 13:09:21 2009
New Revision: 1285
URL: http://liblas.org/changeset/1285
add boost and zlib detection
Added:
   trunk/m4/ax_boost_base.m4
   trunk/m4/check_zlib.m4
   trunk/Makefile.am
   trunk/apps/Makefile.am
   trunk/configure.ac
   trunk/src/Makefile.am
Modified: trunk/Makefile.am
--- trunk/Makefile.am	(original)
+++ trunk/Makefile.am	Fri May 22 13:09:21 2009
@@ -1,5 +1,6 @@
 SUBDIRS = src apps include test
 if GDAL_IS_CONFIG
 GDAL_CPPFLAGS = @GDAL_INC@ -DHAVE_GDAL=1
 endif
@@ -8,7 +9,23 @@
 GEOTIFF_CPPFLAGS = @GEOTIFF_INC@ -DHAVE_LIBGEOTIFF=1
 endif
-AM_CPPFLAGS = $(GEOTIFF_CPPFLAGS) $(GDAL_CPPFLAGS) -I../include -I../include/detail
+if SPATIALINDEX_IS_CONFIG
+SPATIALINDEX_CPPFLAGS = @SPATIALINDEX_INC@/spatialindex @SPATIALINDEX_INC@ -DHAVE_SPATIALINDEX=1
+endif
+if OCI_IS_CONFIG
+OCI_CPPFLAGS = @ORACLE_OCI_CFLAGS@ -DHAVE_ORACLE=1
+endif
+if ZLIB_IS_CONFIG
+ZLIB_CPPFLAGS = @ZLIB_INC@ -DHAVE_ZLIB=1
+endif
+if BOOST_IS_CONFIG
+BOOST_FLAGS = @BOOST_CPPFLAGS@ -DHAVE_BOOST_API=1
+endif
+AM_CPPFLAGS = -I../include/liblas/capi -I../include $(GEOTIFF_CPPFLAGS) $(GDAL_CPPFLAGS) $(SPATIALINDEX_CPPFLAGS) $(OCI_CPPFLAGS) $(ZLIB_CPPFLAGS) $(BOOST_FLAGS)
 EXTRA_DIST = \
Modified: trunk/apps/Makefile.am
--- trunk/apps/Makefile.am	(original)
+++ trunk/apps/Makefile.am	Fri May 22 13:09:21 2009
@@ -14,7 +14,15 @@
 endif
-AM_CPPFLAGS = -I../include/liblas/capi -I../include $(GEOTIFF_CPPFLAGS) $(GDAL_CPPFLAGS) $(SPATIALINDEX_CPPFLAGS) $(OCI_CPPFLAGS)
+if ZLIB_IS_CONFIG
+endif
+if BOOST_IS_CONFIG
+endif
 lasinfo_SOURCES = lasinfo.c lascommon.c
 las2las_SOURCES = las2las.c lascommon.c
Modified: trunk/configure.ac
--- trunk/configure.ac	(original)
+++ trunk/configure.ac	Fri May 22 13:09:21 2009
@@ -249,9 +249,9 @@
 AC_SUBST([SPATIALINDEX_PREFIX])
 AM_CONDITIONAL([SPATIALINDEX_IS_CONFIG], [test ! x$SPATIALINDEX_CONFIG = xno])
-dnl Oracle Checks
+dnl #########################################################################
+dnl Determine Oracle Support
 ORACLE_OCI_REQ_VERSION="9.0.2"
 HAVE_ORACLE_OCI="no"
@@ -263,6 +263,28 @@
 fi
+dnl Determine Zlib Support
+CHECK_ZLIB()
+AM_CONDITIONAL([ZLIB_IS_CONFIG], [test ! x$HAVE_LIBZ = xno])
+dnl Determine Boost support
+AX_BOOST_BASE()
+AM_CONDITIONAL([BOOST_IS_CONFIG], [test ! x$HAVE_BOOST = xno])
+if test "${HAVE_BOOST}" == "" ; then
+    HAVE_BOOST="yes"
+    LIBS="$BOOST_LDFLAGS $LIBS"
+fi
 dnl Determine other features of compiler
@@ -335,6 +357,21 @@
     fi
 fi
+LOC_MSG([  zlib support.............: ${HAVE_LIBZ}])
+if test "${HAVE_LIBZ}" != "no" ; then
+    LOC_MSG([   - lz....................: ${HAVE_LIBZ}])
+    if test -n "${ZLIB_INC}" ; then
+        LOC_MSG([   - INCLUDE directories...: ${ZLIB_INC}])
+    fi
+fi
+LOC_MSG([  Boost support............: ${HAVE_BOOST}])
+if test "${HAVE_BOOST}" != "no" ; then
+    LOC_MSG([   - lboost................: ${HAVE_BOOST}])
+    if test -n "${BOOST_CPPFLAGS}" ; then
+        LOC_MSG([   - INCLUDE directories...: ${BOOST_CPPFLAGS}])
+    fi
+fi
 LOC_MSG()
 LOC_MSG([  LIBS.....................: ${LIBS}])
 LOC_MSG()
Added: trunk/m4/ax_boost_base.m4
--- (empty file)
+++ trunk/m4/ax_boost_base.m4	Fri May 22 13:09:21 2009
@@ -0,0 +1,219 @@
+#          http://www.nongnu.org/autoconf-archive/ax_boost_base.html
+# SYNOPSIS
+#   AX_BOOST_BASE([MINIMUM-VERSION])
+# DESCRIPTION
+#   Test for the Boost C++ libraries of a particular version (or newer)
+#   If no path to the installed boost library is given the macro searchs
+#   under /usr, /usr/local, /opt and /opt/local and evaluates the
+#   $BOOST_ROOT environment variable. Further documentation is available at
+#   <http://randspringer.de/boost/index.html>.
+#   This macro calls:
+#     AC_SUBST(BOOST_CPPFLAGS) / AC_SUBST(BOOST_LDFLAGS)
+#   And sets:
+#     HAVE_BOOST
+# LICENSE
+#   Copyright (c) 2008 Thomas Porschberg <thomas at randspringer.de>
+#   Copying and distribution of this file, with or without modification, are
+#   permitted in any medium without royalty provided the copyright notice
+#   and this notice are preserved.
+AC_DEFUN([AX_BOOST_BASE],
+AC_ARG_WITH([boost],
+	AS_HELP_STRING([--with-boost@<:@=DIR@:>@], [use boost (default is yes) - it is possible to specify the root directory for boost (optional)]),
+    if test "$withval" = "no"; then
+		want_boost="no"
+    elif test "$withval" = "yes"; then
+        want_boost="yes"
+        ac_boost_path=""
+    else
+	    want_boost="yes"
+        ac_boost_path="$withval"
+	fi
+    [want_boost="yes"])
+AC_ARG_WITH([boost-libdir],
+        AS_HELP_STRING([--with-boost-libdir=LIB_DIR],
+        [Force given directory for boost libraries. Note that this will overwrite library path detection, so use this parameter only if default library detection fails and you know exactly where your boost libraries are located.]),
+        if test -d $withval
+        then
+                ac_boost_lib_path="$withval"
+        else
+                AC_MSG_ERROR(--with-boost-libdir expected directory name)
+        fi
+        [ac_boost_lib_path=""]
+if test "x$want_boost" = "xyes"; then
+	boost_lib_version_req=ifelse([$1], ,1.20.0,$1)
+	boost_lib_version_req_shorten=`expr $boost_lib_version_req : '\([[0-9]]*\.[[0-9]]*\)'`
+	boost_lib_version_req_major=`expr $boost_lib_version_req : '\([[0-9]]*\)'`
+	boost_lib_version_req_minor=`expr $boost_lib_version_req : '[[0-9]]*\.\([[0-9]]*\)'`
+	boost_lib_version_req_sub_minor=`expr $boost_lib_version_req : '[[0-9]]*\.[[0-9]]*\.\([[0-9]]*\)'`
+	if test "x$boost_lib_version_req_sub_minor" = "x" ; then
+		boost_lib_version_req_sub_minor="0"
+    	fi
+	WANT_BOOST_VERSION=`expr $boost_lib_version_req_major \* 100000 \+  $boost_lib_version_req_minor \* 100 \+ $boost_lib_version_req_sub_minor`
+	AC_MSG_CHECKING(for boostlib >= $boost_lib_version_req)
+	succeeded=no
+	dnl first we check the system location for boost libraries
+	dnl this location ist chosen if boost libraries are installed with the --layout=system option
+	dnl or if you install boost with RPM
+	if test "$ac_boost_path" != ""; then
+		BOOST_LDFLAGS="-L$ac_boost_path/lib"
+		BOOST_CPPFLAGS="-I$ac_boost_path/include"
+	else
+		for ac_boost_path_tmp in /usr /usr/local /opt /opt/local ; do
+			if test -d "$ac_boost_path_tmp/include/boost" && test -r "$ac_boost_path_tmp/include/boost"; then
+				BOOST_LDFLAGS="-L$ac_boost_path_tmp/lib"
+				BOOST_CPPFLAGS="-I$ac_boost_path_tmp/include"
+				break;
+			fi
+		done
+	fi
+    dnl overwrite ld flags if we have required special directory with
+    dnl --with-boost-libdir parameter
+    if test "$ac_boost_lib_path" != ""; then
+       BOOST_LDFLAGS="-L$ac_boost_lib_path"
+    fi
+	CPPFLAGS_SAVED="$CPPFLAGS"
+	CPPFLAGS="$CPPFLAGS $BOOST_CPPFLAGS"
+	export CPPFLAGS
+	LDFLAGS_SAVED="$LDFLAGS"
+	LDFLAGS="$LDFLAGS $BOOST_LDFLAGS"
+	export LDFLAGS
+	AC_LANG_PUSH(C++)
+     	AC_COMPILE_IFELSE([AC_LANG_PROGRAM([[
+	@%:@include <boost/version.hpp>
+	#if BOOST_VERSION >= $WANT_BOOST_VERSION
+	// Everything is okay
+	#else
+	#  error Boost version is too old
+	#endif
+        AC_MSG_RESULT(yes)
+	succeeded=yes
+	found_system=yes
+	AC_LANG_POP([C++])
+	dnl if we found no boost with system layout we search for boost libraries
+	dnl built and installed without the --layout=system option or for a staged(not installed) version
+	if test "x$succeeded" != "xyes"; then
+		_version=0
+			if test -d "$ac_boost_path" && test -r "$ac_boost_path"; then
+				for i in `ls -d $ac_boost_path/include/boost-* 2>/dev/null`; do
+					_version_tmp=`echo $i | sed "s#$ac_boost_path##" | sed 's/\/include\/boost-//' | sed 's/_/./'`
+					V_CHECK=`expr $_version_tmp \> $_version`
+					if test "$V_CHECK" = "1" ; then
+						_version=$_version_tmp
+					fi
+					VERSION_UNDERSCORE=`echo $_version | sed 's/\./_/'`
+					BOOST_CPPFLAGS="-I$ac_boost_path/include/boost-$VERSION_UNDERSCORE"
+				done
+			fi
+		else
+			for ac_boost_path in /usr /usr/local /opt /opt/local ; do
+	               					best_path=$ac_boost_path
+						fi
+					done
+				fi
+			done
+			BOOST_CPPFLAGS="-I$best_path/include/boost-$VERSION_UNDERSCORE"
+            if test "$ac_boost_lib_path" = ""
+            then
+               BOOST_LDFLAGS="-L$best_path/lib"
+            fi
+	    		if test "x$BOOST_ROOT" != "x"; then
+				if test -d "$BOOST_ROOT" && test -r "$BOOST_ROOT" && test -d "$BOOST_ROOT/stage/lib" && test -r "$BOOST_ROOT/stage/lib"; then
+					version_dir=`expr //$BOOST_ROOT : '.*/\(.*\)'`
+					stage_version=`echo $version_dir | sed 's/boost_//' | sed 's/_/./g'`
+			        	stage_version_shorten=`expr $stage_version : '\([[0-9]]*\.[[0-9]]*\)'`
+					V_CHECK=`expr $stage_version_shorten \>\= $_version`
+                    if test "$V_CHECK" = "1" -a "$ac_boost_lib_path" = "" ; then
+						AC_MSG_NOTICE(We will use a staged boost library from $BOOST_ROOT)
+						BOOST_CPPFLAGS="-I$BOOST_ROOT"
+						BOOST_LDFLAGS="-L$BOOST_ROOT/stage/lib"
+					fi
+				fi
+	    		fi
+		fi
+		export CPPFLAGS
+		export LDFLAGS
+		AC_LANG_PUSH(C++)
+		#else
+		#endif
+		succeeded=yes
+		found_system=yes
+	fi
+	if test "$succeeded" != "yes" ; then
+		if test "$_version" = "0" ; then
+			AC_MSG_ERROR([[We could not detect the boost libraries (version $boost_lib_version_req_shorten or higher). If you have a staged boost library (still not installed) please specify \$BOOST_ROOT in your environment and do not give a PATH to --with-boost option.  If you are sure you have boost installed, then check your version number looking in <boost/version.hpp>. See http://randspringer.de/boost for more documentation.]])
+		else
+			AC_MSG_NOTICE([Your boost libraries seems to old (version $_version).])
+		fi
+	else
+		AC_SUBST(BOOST_CPPFLAGS)
+		AC_SUBST(BOOST_LDFLAGS)
+		AC_DEFINE(HAVE_BOOST,,[define if the Boost library is available])
+	fi
+        CPPFLAGS="$CPPFLAGS_SAVED"
+       	LDFLAGS="$LDFLAGS_SAVED"
+fi
Added: trunk/m4/check_zlib.m4
--- (empty file)
+++ trunk/m4/check_zlib.m4	Fri May 22 13:09:21 2009
@@ -0,0 +1,129 @@
+#           http://www.nongnu.org/autoconf-archive/check_zlib.html
+# SYNOPSIS
+#   CHECK_ZLIB()
+# DESCRIPTION
+#   This macro searches for an installed zlib library. If nothing was
+#   specified when calling configure, it searches first in /usr/local and
+#   then in /usr. If the --with-zlib=DIR is specified, it will try to find
+#   it in DIR/include/zlib.h and DIR/lib/libz.a. If --without-zlib is
+#   specified, the library is not searched at all.
+#   If either the header file (zlib.h) or the library (libz) is not found,
+#   the configuration exits on error, asking for a valid zlib installation
+#   directory or --without-zlib.
+#   The macro defines the symbol HAVE_LIBZ if the library is found. You
+#   should use autoheader to include a definition for this symbol in a
+#   config.h file. Sample usage in a C/C++ source is as follows:
+#     #ifdef HAVE_LIBZ
+#     #include <zlib.h>
+#     #endif /* HAVE_LIBZ */
+# LICENSE
+#   Copyright (c) 2008 Loic Dachary <loic at senga.org>
+#   This program is free software; you can redistribute it and/or modify it
+#   under the terms of the GNU General Public License as published by the
+#   Free Software Foundation; either version 2 of the License, or (at your
+#   option) any later version.
+#   This program is distributed in the hope that it will be useful, but
+#   WITHOUT ANY WARRANTY; without even the implied warranty of
+#   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General
+#   Public License for more details.
+#   You should have received a copy of the GNU General Public License along
+#   with this program. If not, see <http://www.gnu.org/licenses/>.
+#   As a special exception, the respective Autoconf Macro's copyright owner
+#   gives unlimited permission to copy, distribute and modify the configure
+#   scripts that are the output of Autoconf when processing the Macro. You
+#   need not follow the terms of the GNU General Public License when using
+#   or distributing such scripts, even though portions of the text of the
+#   Macro appear in them. The GNU General Public License (GPL) does govern
+#   all other use of the material that constitutes the Autoconf Macro.
+#   This special exception to the GPL applies to versions of the Autoconf
+#   Macro released by the Autoconf Archive. When you make and distribute a
+#   modified version of the Autoconf Macro, you may extend this special
+#   exception to the GPL to apply to your modified version as well.
+AC_DEFUN([CHECK_ZLIB],
+# Handle user hints
+[AC_MSG_CHECKING(if zlib is wanted)
+AC_ARG_WITH(zlib,
+[  --with-zlib=DIR root directory path of zlib installation [defaults to
+                    /usr/local or /usr if not found in /usr/local]
+  --without-zlib to disable zlib usage completely],
+[if test "$withval" != no ; then
+  if test -d "$withval"
+  then
+    ZLIB_HOME="$withval"
+  else
+    AC_MSG_WARN([Sorry, $withval does not exist, checking usual places])
+  fi
+else
+  AC_MSG_RESULT(no)
+fi])
+ZLIB_HOME=/usr/local
+if test ! -f "${ZLIB_HOME}/include/zlib.h"
+then
+        ZLIB_HOME=/usr
+fi
+# Locate zlib, if wanted
+HAVE_LIBZ="no"
+if test -n "${ZLIB_HOME}"
+then
+        ZLIB_OLD_LDFLAGS=$LDFLAGS
+        ZLIB_OLD_CPPFLAGS=$LDFLAGS
+        LDFLAGS="$LDFLAGS -L${ZLIB_HOME}/lib"
+        CPPFLAGS="$CPPFLAGS -I${ZLIB_HOME}/include"
+        AC_LANG_SAVE
+        AC_LANG_C
+        AC_CHECK_LIB(z, inflateEnd, [zlib_cv_libz=yes], [zlib_cv_libz=no])
+        AC_CHECK_HEADER(zlib.h, [zlib_cv_zlib_h=yes], [zlib_cv_zlib_h=no])
+        AC_LANG_RESTORE
+        if test "$zlib_cv_libz" = "yes" -a "$zlib_cv_zlib_h" = "yes"
+        then
+                # If both library and header were found, use them
+                AC_CHECK_LIB(z, inflateEnd)
+                AC_MSG_CHECKING(zlib in ${ZLIB_HOME})
+                ZLIB_INC="-I${ZLIB_HOME}/include"
+                AC_SUBST([ZLIB_INC])
+                ZLIB_LIB="-L${ZLIB_HOME}/lib -z"
+                AC_SUBST([ZLIB_LIB])
+                HAVE_LIBZ="yes"
+                AC_SUBST([HAVE_LIBZ])
+                AC_MSG_RESULT(ok)
+        else
+                # If either header or library was not found, revert and bomb
+                LDFLAGS="$ZLIB_OLD_LDFLAGS"
+                CPPFLAGS="$ZLIB_OLD_CPPFLAGS"
+                AC_MSG_RESULT(failed)
+                AC_MSG_ERROR(either specify a valid zlib installation with --with-zlib=DIR or disable zlib usage with --without-zlib)
+        fi
+fi
Modified: trunk/src/Makefile.am
--- trunk/src/Makefile.am	(original)
+++ trunk/src/Makefile.am	Fri May 22 13:09:21 2009
@@ -13,7 +13,19 @@
 endif
-AM_CPPFLAGS = -I../include -I../include/detail $(GEOTIFF_CPPFLAGS) $(GDAL_CPPFLAGS) $(SPATIALINDEX_CPPFLAGS)
+if OCI_IS_CONFIG
+endif
+if ZLIB_IS_CONFIG
+endif
+if BOOST_IS_CONFIG
+endif
 lib_LTLIBRARIES = liblas.la
@@ -51,4 +63,8 @@
 endif
+if ZLIB_IS_CONFIG
+endif
 liblas_la_LDFLAGS = -version-info 1:0:0
More information about the Liblas-commits mailing list
