[Liblas-commits] r1299 - in trunk: . m4
liblas-commits at liblas.org
Thu Jun 18 22:47:17 EDT 2009
Author: hobu
Date: Thu Jun 18 22:47:16 2009
New Revision: 1299
URL: http://liblas.org/changeset/1299
make boost optional and fix the logic so it works correctly
trunk/configure.ac
trunk/m4/ax_boost_base.m4
Modified: trunk/configure.ac
--- trunk/configure.ac (original)
+++ trunk/configure.ac Thu Jun 18 22:47:16 2009
@@ -278,7 +278,8 @@
AX_BOOST_BASE()
AM_CONDITIONAL([BOOST_IS_CONFIG], [test ! x$HAVE_BOOST = xno])
-if test "${HAVE_BOOST}" == "" ; then
+echo ${HAVE_BOOST}
+if test "${HAVE_BOOST}" == "yes" ; then
HAVE_BOOST="yes"
LIBS="$BOOST_LDFLAGS -lboost_iostreams $LIBS"
fi
Modified: trunk/m4/ax_boost_base.m4
--- trunk/m4/ax_boost_base.m4 (original)
+++ trunk/m4/ax_boost_base.m4 Thu Jun 18 22:47:16 2009
@@ -21,7 +21,7 @@
# And sets:
-# HAVE_BOOST
+# HAVE_BOOST_API
# LICENSE
@@ -34,7 +34,7 @@
AC_DEFUN([AX_BOOST_BASE],
AC_ARG_WITH([boost],
- AS_HELP_STRING([--with-boost@<:@=DIR@:>@], [use boost (default is yes) - it is possible to specify the root directory for boost (optional)]),
+ AS_HELP_STRING([--with-boost@<:@=DIR@:>@], [use boost (default is no) - it is possible to specify the root directory for boost (optional)]),
if test "$withval" = "no"; then
want_boost="no"
@@ -43,10 +43,10 @@
ac_boost_path=""
else
want_boost="yes"
- ac_boost_path="$withval"
+ ac_boost_path="$withval"
fi
- [want_boost="yes"])
+ [want_boost="no"])
AC_ARG_WITH([boost-libdir],
@@ -209,7 +209,9 @@
else
AC_SUBST(BOOST_CPPFLAGS)
AC_SUBST(BOOST_LDFLAGS)
- AC_DEFINE(HAVE_BOOST,,[define if the Boost library is available])
+ HAVE_BOOST="yes"
+ AC_SUBST(HAVE_BOOST)
+ AC_DEFINE(HAVE_BOOST_API,,[define if the Boost library is available])
fi
CPPFLAGS="$CPPFLAGS_SAVED"
More information about the Liblas-commits
