[Liblas-commits] r1300 - in trunk: . apps include src
liblas-commits at liblas.org
Mon Jun 29 21:15:33 EDT 2009
Author: hobu
Date: Mon Jun 29 21:15:32 2009
New Revision: 1300
URL: http://liblas.org/changeset/1300
fix redefinition of HAVE_BOOST_API
trunk/Makefile.am
trunk/apps/Makefile.am
trunk/apps/lasindex.cpp
trunk/configure.ac
trunk/include/Makefile.am
trunk/src/Makefile.am
Modified: trunk/Makefile.am
--- trunk/Makefile.am (original)
+++ trunk/Makefile.am Mon Jun 29 21:15:32 2009
@@ -22,7 +22,7 @@
endif
if BOOST_IS_CONFIG
-BOOST_FLAGS = @BOOST_CPPFLAGS@ -DHAVE_BOOST_API=1
+BOOST_FLAGS = @BOOST_CPPFLAGS@ -DHAVE_BOOST=1
endif
AM_CPPFLAGS = -I../include/liblas/capi -I../include $(GEOTIFF_CPPFLAGS) $(GDAL_CPPFLAGS) $(SPATIALINDEX_CPPFLAGS) $(OCI_CPPFLAGS) $(ZLIB_CPPFLAGS) $(BOOST_FLAGS)
Modified: trunk/apps/Makefile.am
--- trunk/apps/Makefile.am (original)
+++ trunk/apps/Makefile.am Mon Jun 29 21:15:32 2009
@@ -19,7 +19,7 @@
endif
if BOOST_IS_CONFIG
endif
Modified: trunk/apps/lasindex.cpp
--- trunk/apps/lasindex.cpp (original)
+++ trunk/apps/lasindex.cpp Mon Jun 29 21:15:32 2009
@@ -9,7 +9,7 @@
#include <liblas/lasvariablerecord.hpp>
#include <liblas/index/index.hpp>
-#ifdef HAVE_BOOST_API
+#ifdef HAVE_BOOST
#include <boost/iostreams/filter/zlib.hpp>
#include <boost/iostreams/filtering_streambuf.hpp>
#include <boost/iostreams/filtering_stream.hpp>
@@ -185,7 +185,12 @@
std::string s = e.what();
std::cout << "error querying index value" << s <<std::endl; exit(1);
+ std::cout << "hits: ";
+ for (int i=0;i<ids->size();i++) {
+ std::cout << ids->at(i) <<",";
+ std::cout << std::endl;
// if (ids != 0) delete ids;
// if (idx != 0) delete idx;
@@ -206,6 +211,7 @@
LASVariableRecord *vlr = idx->GetVLR();
std::string data("some junkdsfasdfasdfqwerasdfasdfasdfasdfasdfweradsfasdfasdfasdfasdfasdqwerasdfasdfasdfasdfqwerasdfasdfv");
+ // std::string data(vlr->GetData());
std::cout << "uncompressed size " << data.size() << std::endl;
io::copy(boost::make_iterator_range(data),ofilter);
Modified: trunk/configure.ac
--- trunk/configure.ac (original)
+++ trunk/configure.ac Mon Jun 29 21:15:32 2009
@@ -281,7 +281,7 @@
echo ${HAVE_BOOST}
if test "${HAVE_BOOST}" == "yes" ; then
HAVE_BOOST="yes"
- LIBS="$BOOST_LDFLAGS -lboost_iostreams $LIBS"
+ LIBS="$BOOST_LDFLAGS -lboost_iostreams-gcc40-mt $LIBS"
fi
Modified: trunk/include/Makefile.am
--- trunk/include/Makefile.am (original)
+++ trunk/include/Makefile.am Mon Jun 29 21:15:32 2009
@@ -37,4 +37,5 @@
liblas/index/datastream.hpp \
liblas/index/index.hpp \
liblas/index/storage.hpp \
+ liblas/index/query.hpp \
liblas/index/visitor.hpp
\ No newline at end of file
Modified: trunk/src/Makefile.am
--- trunk/src/Makefile.am (original)
+++ trunk/src/Makefile.am Mon Jun 29 21:15:32 2009
@@ -22,7 +22,7 @@
endif
if BOOST_IS_CONFIG
endif
@@ -59,6 +59,7 @@
liblas_la_SOURCES += index/index.cpp \
index/datastream.cpp \
index/visitor.cpp \
+ index/query.cpp \
index/storage.cpp
More information about the Liblas-commits
