[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Oct 13 14:49:05 EDT 2009
changeset c95a65fbd674 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=c95a65fbd674
summary: add start of las_summary python example
changeset d64cffc97cf6 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=d64cffc97cf6
summary: get the file lists
changeset 8daffe9742d1 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=8daffe9742d1
summary: don't try to read off the end if we're reading a file that is only header
diffstat:
 apps/las2oci.cpp               |   20 ++++++
 python/examples/las_summary.py |  117 +++++++++++++++++++++++++++++++++++++++
 src/detail/reader.cpp          |   17 ++++-
 3 files changed, 150 insertions(+), 4 deletions(-)
diffs (182 lines):
diff -r ad18d8e2a303 -r 8daffe9742d1 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Sun Oct 11 22:28:16 2009 +0100
+++ b/apps/las2oci.cpp	Tue Oct 13 13:46:24 2009 -0500
@@ -763,3 +763,23 @@
+// select t.x, t.y, t.id from (
+// select
+//  sdo_pc_pkg.to_geometry(
+//                     a.points,   -- point LOB
+//                     a.num_points, -- # of points in the LOB
+//                     2,  -- total dimensionality
+//                     8265 -- SRID
+//                     ) shape from line_27006_reproj a
+//      )c ,  TABLE(SDO_UTIL.GETVERTICES(c.shape)) t
+// select sdo_pc_pkg.to_geometry(
+//                     8265 -- SRID
+//                     where rownum < 10
\ No newline at end of file
diff -r ad18d8e2a303 -r 8daffe9742d1 python/examples/las_summary.py
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/python/examples/las_summary.py	Tue Oct 13 13:46:24 2009 -0500
@@ -0,0 +1,117 @@
+#!/usr/bin/env python
+from liblas import file as lasfile
+from liblas import header
+import glob
+import os, sys
+class Summary(object):
+    def construct_parser(self):
+        from optparse import OptionParser, OptionGroup
+        usage = "usage: %prog [options] arg"
+        parser = OptionParser(usage)
+        g = OptionGroup(parser, "Base options", "Basic Translation Options")
+        g.add_option("-i", "--input", dest="input",
+                          help="Input directory", metavar="INPUT")
+        g.add_option("-o", "--output", dest='output',
+                          help="ReSTructured text file to write for output", metavar="OUTPUT")
+        g.add_option("-r", "--recursive",
+                          action="store_true", dest="recursive",
+                          help="recurse down the directory")
+        g.add_option("-u", "--url", dest='url',
+                          help="URL to base for links to files", metavar="URL")
+        g.add_option("-q", "--quiet",
+                          action="store_false", dest="verbose", default=False,
+                          help="Don't say what we're doing on stdout")
+        parser.add_option_group(g)
+        if self.opts:
+            g = OptionGroup(parser, "Special Options", "Special options")
+            for o in self.opts:
+                g.add_option(o)
+        parser.set_defaults(verbose=True, recursive=False)
+        self.parser = parser
+    def __init__(self, arguments, options=None):
+        self.input = None
+        self.output = None
+        self.opts = options
+        self.construct_parser()
+        self.options, self.args = self.parser.parse_args(args=arguments)
+        if self.args:
+            self.options.input = self.args[0]
+        if not self.options.output:
+            try:
+                self.options.output = self.args[1]
+            except IndexError:
+                self.options.output = 'output.txt'
+        print self.options, self.args
+    def list_files(self):
+        def get_files(path):
+            output = []
+            fn = path+"/*.LAS"
+            output = glob.glob(fn)
+            fn = path+"/*.las"
+            output.extend(glob.glob(fn))
+            return output
+        if self.options.input:
+            self.options.input = os.path.abspath(self.options.input)
+            if not os.path.isdir(self.options.input):
+                raise self.parser.error("Inputted path '%s' was not a directory" % self.options.input)
+        else:
+            raise self.parser.error("No input directory was specified")
+        if self.options.recursive:
+            directories = {}
+            for root, dirs, files in os.walk(self.options.input):
+                directories[root] = root
+                for d in dirs:
+                    directories[os.path.join(root, d)] = os.path.join(root, d)
+            self.files = []
+            for d in directories:
+                print d
+                files = get_files(d)
+                print files
+                if files:
+                    self.files.extend(files)
+        else:
+            get_files(self.options.input)
+        print self.files
+    def process(self):
+        self.list_files()
+        return None
+def main():
+    import optparse
+    options = []
+#     o = optparse.make_option("-r", "--remainder", dest="remainder",
+#                          type="choice",default='end',
+#                           help="""what to do with the remainder -- place it at the beginning,
+# place it at the end, or evenly distribute it across the segment""",
+#                           choices=['end','begin','uniform'])
+#     options.append(o)
+    d = Summary(sys.argv[1:], options=options)
+    d.process()
+if __name__=='__main__':
+    main()
diff -r ad18d8e2a303 -r 8daffe9742d1 src/detail/reader.cpp
--- a/src/detail/reader.cpp	Sun Oct 11 22:28:16 2009 +0100
+++ b/src/detail/reader.cpp	Tue Oct 13 13:46:24 2009 -0500
@@ -283,15 +283,24 @@
     uint8_t pad2 = 0x0;
     std::streamsize const current_pos = m_ifs.tellg();
-    detail::read_n(pad1, m_ifs, sizeof(uint8_t));
-    detail::read_n(pad2, m_ifs, sizeof(uint8_t));
+    // If our little test reads off the end, we'll try to put the
+    // borken dishes back up in the cabinet
+    try {
+        detail::read_n(pad1, m_ifs, sizeof(uint8_t));
+        detail::read_n(pad2, m_ifs, sizeof(uint8_t));
+    } catch (std::out_of_range& e) {
+        m_ifs.seekg(current_pos, std::ios::beg);
+        return false;
+    } catch (std::runtime_error& e) {
+        return false;
     LIBLAS_SWAP_BYTES(pad1);
     LIBLAS_SWAP_BYTES(pad2);
     // Put the stream back where we found it
-    m_ifs.seekg(current_pos, std::ios::beg);
     // FIXME: we have to worry about swapping issues
     // but some people write the pad bytes backwards
More information about the Liblas-commits mailing list
