[Liblas-commits] hg: use 3d instead of 2d for block and index extents
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Oct 13 15:16:38 EDT 2009
changeset d327b4670729 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=d327b4670729
summary: use 3d instead of 2d for block and index extents
diffstat:
 apps/las2oci.cpp |  12 +++++++++---
 1 files changed, 9 insertions(+), 3 deletions(-)
diffs (30 lines):
diff -r 8daffe9742d1 -r d327b4670729 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Tue Oct 13 13:46:24 2009 -0500
+++ b/apps/las2oci.cpp	Tue Oct 13 14:13:59 2009 -0500
@@ -309,9 +309,14 @@
     oss_geom.setf(std::ios_base::fixed, std::ios_base::floatfield);
     oss_geom.precision(2);
-    oss_geom << "mdsys.sdo_geometry(2003,"<<srid<<", null,"
+    oss_geom << "mdsys.sdo_geometry(3008,"<<srid<<", null,"
               "mdsys.sdo_elem_info_array(1,1003,3),"
-              "mdsys.sdo_ordinate_array("<< b->getLow(0) <<","<<b->getLow(1)<<","<<b->getHigh(0) <<","<<b->getHigh(1)<<"))";
+              "mdsys.sdo_ordinate_array("<< b->getLow(0) <<","<<
+                                            b->getLow(1) <<","<<
+                                            b->getLow(2) <<","<<
+                                            b->getHigh(0) <<","<<
+                                            b->getHigh(1) <<","<<
+                                            b->getHigh(2)<<"))";
     oss << "INSERT INTO "<< tableName << "(OBJ_ID, NUM_POINTS, BLK_EXTENT, POINTS) VALUES ( "
                          << result.GetID() <<"," << num_points << ", " << oss_geom.str() <<", EMPTY_BLOB())";
@@ -391,7 +396,8 @@
     oss <<  "INSERT INTO user_sdo_geom_metadata VALUES ('" << tableName <<
             "','blk_extent', MDSYS.SDO_DIM_ARRAY("
             "MDSYS.SDO_DIM_ELEMENT('X', "<< query->bounds.getLow(0) <<","<< query->bounds.getHigh(0)<<",0.05),"
-            "MDSYS.SDO_DIM_ELEMENT('Y', "<< query->bounds.getLow(1) <<","<< query->bounds.getHigh(1)<<",0.05)),"
+            "MDSYS.SDO_DIM_ELEMENT('Y', "<< query->bounds.getLow(1) <<","<< query->bounds.getHigh(1)<<",0.05),"
+            "MDSYS.SDO_DIM_ELEMENT('Z', "<< query->bounds.getLow(2) <<","<< query->bounds.getHigh(2)<<",0.05)),"
             << srid << ")";
     statement = Run(connection, oss);
     if (statement != 0) delete statement; else return false;
More information about the Liblas-commits mailing list
