[Liblas-commits] hg: aux-columns and aux-values entries into point
cloud table
liblas-commits at liblas.org
Wed Oct 14 15:48:46 EDT 2009
changeset 68e5fc349075 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=68e5fc349075
summary: aux-columns and aux-values entries into point cloud table
diffstat:
apps/las2oci.cpp | 39 ++++++++++++++++++++++++++++++++++++---
1 files changed, 36 insertions(+), 3 deletions(-)
diffs (94 lines):
diff -r 5a13b5fc940a -r 68e5fc349075 apps/las2oci.cpp
--- a/apps/las2oci.cpp Wed Oct 14 12:46:35 2009 -0500
+++ b/apps/las2oci.cpp Wed Oct 14 14:46:03 2009 -0500
@@ -456,6 +456,8 @@
const char* blkTableName,
const char* pcTableName,
const char* cloudColumnName,
+ const char* aux_columns,
+ const char* aux_values,
int nDimension,
int srid,
int blk_capacity)
@@ -474,10 +476,23 @@
std::string cloudColumnName_l = std::string(cloudColumnName);
std::string cloudColumnName_u = std::string(cloudColumnName_l);
+ std::string aux_columns_l = std::string(aux_columns);
+ std::string aux_columns_u = std::string(aux_columns);
+ std::string aux_values_l = std::string(aux_values);
std::transform(blkTableName_l.begin(), blkTableName_l.end(), blkTableName_u.begin(), static_cast < int(*)(int) > (toupper));
std::transform(pcTableName_l.begin(), pcTableName_l.end(), pcTableName_u.begin(), static_cast < int(*)(int) > (toupper));
std::transform(cloudColumnName_l.begin(), cloudColumnName_l.end(), cloudColumnName_u.begin(), static_cast < int(*)(int) > (toupper));
+ std::transform(aux_columns_l.begin(), aux_columns_l.end(), aux_columns_u.begin(), static_cast < int(*)(int) > (toupper));
+ ostringstream columns;
+ ostringstream values;
+ columns << cloudColumnName_u << "," << aux_columns_u;
+ values << "pc," << aux_values_l;
oss << "declare\n"
@@ -503,7 +518,7 @@
" null);\n"
" -- Insert the Point Cloud object into the \"base\" table.\n"
-" insert into "<< pcTableName_u<<" ("<<cloudColumnName_u<<") values (pc);\n"
+" insert into "<< pcTableName_u<<" ("<<columns.str()<<") values ("<<values.str()<<");\n"
"end;\n";
statement = Run(connection, oss);
@@ -569,6 +584,8 @@
std::string pre_sql("");
std::string post_sql("");
+ std::string aux_columns("");
+ std::string aux_values("");
bool bUseExistingBlockTable = false;
bool bDropTable = false;
@@ -660,6 +677,20 @@
i++;
post_sql = std::string(argv[i]);
+ else if ( strcmp(argv[i],"--aux-columns") == 0 ||
+ strcmp(argv[i],"-ac") == 0
+ i++;
+ aux_columns = std::string(argv[i]);
+ else if ( strcmp(argv[i],"--aux-values") == 0 ||
+ strcmp(argv[i],"-av") == 0
+ i++;
+ aux_values = std::string(argv[i]);
else if (input.empty())
input = std::string(argv[i]);
@@ -799,6 +830,8 @@
table_name.c_str(),
base_table_name.c_str(),
point_cloud_name.c_str(),
+ aux_columns.c_str(),
+ aux_values.c_str(),
3, // we're assuming 3d for now
srid,
nCapacity);
@@ -808,7 +841,7 @@
std::cout << "running post-sql ..." << std::endl;
ostringstream oss;
- oss << pre_sql;
+ oss << post_sql;
OWStatement* statement = 0;
statement = Run(con, oss);
if (statement != 0) {
More information about the Liblas-commits
