[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Sat Oct 17 16:12:21 EDT 2009
changeset 91747508c092 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=91747508c092
summary: make precision be 8
changeset a71021111af6 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=a71021111af6
summary: add --precision parameter
diffstat:
apps/las2las.c | 7 +++++++
apps/las2oci.cpp | 33 +++++++++++++++++++++++----------
2 files changed, 30 insertions(+), 10 deletions(-)
diffs (138 lines):
diff -r 68e5fc349075 -r a71021111af6 apps/las2las.c
--- a/apps/las2las.c Wed Oct 14 14:46:03 2009 -0500
+++ b/apps/las2las.c Sat Oct 17 15:09:23 2009 -0500
@@ -30,6 +30,8 @@
#define LAS_FORMAT_11 1
#define LAS_FORMAT_12 2
void usage()
fprintf(stderr,"----------------------------------------------------------\n");
@@ -69,6 +71,11 @@
fprintf(stderr," las2las --input in.las --last_only --eliminate_intensity_below 2000 --stdout > out.las\n");
fprintf(stderr,"\n");
+ fprintf(stderr,"Reproject the data (requires GDAL support):\n");
+ fprintf(stderr," las2las -v in.las output.las -xyz_offset 0 0 0 "
+ "-t_srs EPSG:4326 --xyz_scale 0.0000001 0.0000001 0.0000001"
+ "-s_srs EPSG:26915\n");
+ fprintf(stderr,"\n");
fprintf(stderr, "\nFor more information, see the full documentation for las2las at:\n"
" http://liblas.org/browser/trunk/doc/las2las.txt\n");
diff -r 68e5fc349075 -r a71021111af6 apps/las2oci.cpp
--- a/apps/las2oci.cpp Wed Oct 14 14:46:03 2009 -0500
+++ b/apps/las2oci.cpp Sat Oct 17 15:09:23 2009 -0500
@@ -298,7 +298,7 @@
return true;
-bool InsertBlock(OWConnection* connection, const LASQueryResult& result, int srid, LASReader* reader, const char* tableName)
+bool InsertBlock(OWConnection* connection, const LASQueryResult& result, int srid, LASReader* reader, const char* tableName, long precision)
ostringstream oss;
@@ -308,7 +308,7 @@
ostringstream oss_geom;
oss_geom.setf(std::ios_base::fixed, std::ios_base::floatfield);
- oss_geom.precision(2);
+ oss_geom.precision(precision);
oss_geom << "mdsys.sdo_geometry(3008,"<<srid<<", null,"
"mdsys.sdo_elem_info_array(1,1007,3),"
"mdsys.sdo_ordinate_array("<< b->getLow(0) <<","<<
@@ -374,7 +374,7 @@
-bool CreateSDOEntry(OWConnection* connection, const char* tableName, LASQuery* query, int srid)
+bool CreateSDOEntry(OWConnection* connection, const char* tableName, LASQuery* query, long srid, long precision)
ostringstream oss;
OWStatement* statement = 0;
@@ -382,7 +382,7 @@
oss.setf(std::ios_base::fixed, std::ios_base::floatfield);
- oss.precision(2);
+ oss.precision(precision);
// code = """
// INSERT INTO user_sdo_geom_metadata VALUES (
@@ -460,13 +460,14 @@
const char* aux_values,
int nDimension,
int srid,
- int blk_capacity)
+ int blk_capacity,
+ long precision)
ostringstream oss;
- oss.precision(2);
std::string blkTableName_l = std::string(blkTableName);
std::string blkTableName_u = std::string(blkTableName_l);
@@ -540,7 +541,10 @@
fprintf(stderr,"--srid: (-s) \n");
fprintf(stderr,"--pre-sql: (-prs) \"CREATE TABLE BASE (id number, cloud mdsys.sdo_pc)\" \n");
fprintf(stderr,"--post-sql: (-prs) \"UPDATE TABLE BASE SET ID=1\" \n");
+ fprintf(stderr,"--aux-columns: \"id,description\" \n");
+ fprintf(stderr,"--aux-values: \"0,'A description'\" \n");
+ fprintf(stderr,"--precision: 8\n");
fprintf(stderr,"las2oci -i output.las lidar/lidar at oraclemachine/instance \n"
"--block-table-name hobu_blocks --base-table-name hobu_base\n"
"--cloud-column-name PC --srid 4327 -d\n");
@@ -592,6 +596,7 @@
liblas::uint32_t nCapacity = 10000;
double dFillFactor = 0.99;
int srid = 4327;
+ long precision = 8;
for (int i = 1; i < argc; i++)
@@ -691,6 +696,13 @@
i++;
aux_values = std::string(argv[i]);
+ else if ( strcmp(argv[i],"--precision") == 0 ||
+ strcmp(argv[i],"-p") == 0
+ i++;
+ precision = atoi(argv[i]);
else if (input.empty())
input = std::string(argv[i]);
@@ -817,11 +829,11 @@
LASReader* reader2 = new LASReader(*istrm2);
for (i=results.begin(); i!=results.end(); i++)
- bool inserted = InsertBlock(con, *i, srid, reader2, table_name.c_str());
+ bool inserted = InsertBlock(con, *i, srid, reader2, table_name.c_str(), precision);
if (!bUseExistingBlockTable) {
- CreateSDOEntry(con, table_name.c_str(), query, srid );
+ CreateSDOEntry(con, table_name.c_str(), query, srid , precision);
CreateBlockIndex(con, table_name.c_str());
@@ -834,7 +846,8 @@
aux_values.c_str(),
3, // we're assuming 3d for now
srid,
- nCapacity);
+ nCapacity,
+ precision);
if (!post_sql.empty()) {
More information about the Liblas-commits
