[Liblas-commits] hg: [cmake] Added check for required new API in
GDAL - OSRSetEqu...
liblas-commits at liblas.org
Mon Oct 19 18:26:13 EDT 2009
changeset c321708ea2e5 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=c321708ea2e5
summary: [cmake] Added check for required new API in GDAL - OSRSetEquirectangular2 function.
diffstat:
CMakeLists.txt | 14 ++++++++++++--
1 files changed, 12 insertions(+), 2 deletions(-)
diffs (24 lines):
diff -r 219d4c382d12 -r c321708ea2e5 CMakeLists.txt
--- a/CMakeLists.txt Mon Oct 19 22:37:15 2009 +0100
+++ b/CMakeLists.txt Mon Oct 19 23:25:56 2009 +0100
@@ -158,8 +158,18 @@
FIND_PACKAGE(GDAL 1.6.0)
IF(GDAL_FOUND)
- INCLUDE_DIRECTORIES(${GDAL_INCLUDE_DIR})
- ADD_DEFINITIONS(-DHAVE_GDAL=1)
+ # Confirm required API is available
+ INCLUDE(CheckFunctionExists)
+ SET(CMAKE_REQUIRED_LIBRARIES ${GDAL_LIBRARY})
+ CHECK_FUNCTION_EXISTS(OSRSetEquirectangular2 HAVE_OSRSETEQUIRECTANGULAR2)
+ IF(NOT HAVE_OSRSETEQUIRECTANGULAR2)
+ GDALSET(_FOUND) # Reset to NOT found for GDAL/OGR
+ MESSAGE(FATAL_ERROR "GDAL support requires GDAL 1.6.0 or newer.")
+ ELSE()
+ INCLUDE_DIRECTORIES(${GDAL_INCLUDE_DIR})
+ ADD_DEFINITIONS(-DHAVE_GDAL=1)
+ ENDIF()
ENDIF()
ENDIF()
More information about the Liblas-commits
