[Liblas-commits] hg: Fixed consistent use of integral types in storate.hpp|cpp an...
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Oct 19 18:49:28 EDT 2009
changeset 845f0ec7b4c3 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=845f0ec7b4c3
summary: Fixed consistent use of integral types in storate.hpp|cpp and lasspatialreference.cpp
diffstat:
 include/liblas/index/storage.hpp |  14 ++++---
 src/index/storage.cpp            |  63 ++++++++++++++++++-------------
 src/lasspatialreference.cpp      |  10 +---
 3 files changed, 47 insertions(+), 40 deletions(-)
diffs (220 lines):
diff -r c321708ea2e5 -r 845f0ec7b4c3 include/liblas/index/storage.hpp
--- a/include/liblas/index/storage.hpp	Mon Oct 19 23:25:56 2009 +0100
+++ b/include/liblas/index/storage.hpp	Mon Oct 19 23:49:14 2009 +0100
@@ -70,8 +70,8 @@
     virtual ~VLRStorageManager();
-    virtual void loadByteArray(const SpatialIndex::id_type id, ::uint32_t& len, uint8_t** data);
-    virtual void storeByteArray(SpatialIndex::id_type& id, const ::uint32_t len, const uint8_t* const data);
+    virtual void loadByteArray(const SpatialIndex::id_type id, std::size_t& len, uint8_t** data);
+    virtual void storeByteArray(SpatialIndex::id_type& id, const std::size_t len, const uint8_t* const data);
     virtual void deleteByteArray(const SpatialIndex::id_type id);
     LASVariableRecord* getVLR() const;
@@ -80,7 +80,7 @@
     LASVariableRecord m_data;
     LASVariableRecord m_ids;
     // class Entry
     // public:
@@ -96,10 +96,12 @@
     //     ~Entry() { delete[] m_pData; }
     // }; // Entry
-    LASVariableRecord* makeVLR(const size_t len, const uint8_t* data);
-    // std::vector<Entry*> m_buffer;
-    std::vector<LASVariableRecord*> m_vlrbuffer;
+    typedef std::vector<LASVariableRecord*> vlrbuffer_t;
+    vlrbuffer_t m_vlrbuffer;
     std::stack<SpatialIndex::id_type> m_emptyPages;
+    LASVariableRecord* makeVLR(const std::size_t len, const uint8_t* data);
 }; // MemoryStorageManager
diff -r c321708ea2e5 -r 845f0ec7b4c3 src/index/storage.cpp
--- a/src/index/storage.cpp	Mon Oct 19 23:25:56 2009 +0100
+++ b/src/index/storage.cpp	Mon Oct 19 23:49:14 2009 +0100
@@ -73,40 +73,40 @@
 VLRStorageManager::~VLRStorageManager()
-    // uint32_t vlrsize=0;
-    for (std::vector<LASVariableRecord*>::iterator vit = m_vlrbuffer.begin(); vit != m_vlrbuffer.end(); vit++) {
-        // vlrsize = vlrsize+(*vit)->GetRecordLength();
+    for (vlrbuffer_t::iterator vit = m_vlrbuffer.begin(); vit != m_vlrbuffer.end(); ++vit)
         delete *vit;
-void VLRStorageManager::loadByteArray(const SpatialIndex::id_type id, ::uint32_t& len, uint8_t** data)
+void VLRStorageManager::loadByteArray(const SpatialIndex::id_type id, std::size_t& len, uint8_t** data)
-    LASVariableRecord* v;
+    LASVariableRecord* v = 0;
     try
-        v = m_vlrbuffer.at(id);
+        v = m_vlrbuffer.at(static_cast<vlrbuffer_t::size_type>(id));
         if (v == 0) throw SpatialIndex::InvalidPageException(id);
     catch (std::out_of_range)
+    assert(0 != v);
-    len = v->GetRecordLength();
+    len = static_cast<std::size_t>(v->GetRecordLength());
     *data = new uint8_t[len];
-    memcpy(*data, (uint8_t*)&(v->GetData()[0]), len);
+    std::vector<uint8_t> const& vlrdata = v->GetData();
+    std::memcpy(*data, &vlrdata[0], len);
-void VLRStorageManager::storeByteArray(SpatialIndex::id_type& id, const ::uint32_t len, const uint8_t* const data)
+void VLRStorageManager::storeByteArray(SpatialIndex::id_type& id, const std::size_t len, const uint8_t* const data)
     if (id == SpatialIndex::StorageManager::NewPage)
-        LASVariableRecord* v = makeVLR(len,data);
+        LASVariableRecord* v = makeVLR(len, data);
+        assert(0 != v);
         if (m_emptyPages.empty())
@@ -115,58 +115,67 @@
         else
-            id = m_emptyPages.top(); m_emptyPages.pop();
-            m_vlrbuffer[id] = v;
+            id = m_emptyPages.top();
+            m_emptyPages.pop();
+            m_vlrbuffer[static_cast<vlrbuffer_t::size_type>(id)] = v;
     else
-        LASVariableRecord* v_old;
+        LASVariableRecord* v_old = 0;
         try
-            v_old = m_vlrbuffer.at(id);
-            if (v_old == 0) throw SpatialIndex::InvalidPageException(id);
+            v_old = m_vlrbuffer.at(static_cast<vlrbuffer_t::size_type>(id));
+            if (v_old == 0)
+                throw SpatialIndex::InvalidPageException(id);
+        assert(0 != v);
         delete v_old;
 void VLRStorageManager::deleteByteArray(const SpatialIndex::id_type id)
     try
-        if (v == 0) throw SpatialIndex::InvalidPageException(id);
+        if (v == 0)
-    m_vlrbuffer[id] = 0;
+    m_vlrbuffer[static_cast<vlrbuffer_t::size_type>(id)] = 0;
     m_emptyPages.push(id);
     delete v;
-LASVariableRecord* VLRStorageManager::makeVLR(const size_t len, const uint8_t* data)
+LASVariableRecord* VLRStorageManager::makeVLR(const std::size_t len, const uint8_t* data)
     LASVariableRecord* v = new LASVariableRecord();
-    v->SetRecordLength(len);
+    v->SetRecordLength(static_cast<uint16_t>(len));
     v->SetUserId("liblas.org");
     v->SetRecordId(2112);
-    std::vector<uint8_t> d;
-    for (size_t i=0;i<len;i++){d.push_back(data[i]);}
+    typedef std::vector<uint8_t> data_t;
+    data_t d;
+    for (data_t::size_type i = 0; i < len; ++i)
+        d.push_back(data[i]);
     v->SetData(d);
     return v;
diff -r c321708ea2e5 -r 845f0ec7b4c3 src/lasspatialreference.cpp
--- a/src/lasspatialreference.cpp	Mon Oct 19 23:25:56 2009 +0100
+++ b/src/lasspatialreference.cpp	Mon Oct 19 23:49:14 2009 +0100
@@ -197,8 +197,7 @@
         std::vector<uint8_t> data;
         // Shorts are 2 bytes in length
-        uint16_t length = 2*kcount;
+        uint16_t length = 2 * static_cast<uint16_t>(kcount);
         record.SetRecordLength(length);
         // Copy the data into the data vector
@@ -227,7 +226,7 @@
         // Doubles are 8 bytes in length
-        uint16_t length = 8*dcount;
+        uint16_t length = 8 * static_cast<uint16_t>(dcount);
@@ -272,18 +271,15 @@
                                       "than r1531 (libgeotiff 1.2.6)");
-         uint16_t length = acount;
+         uint16_t length = static_cast<uint16_t>(acount);
          for (i=0; i<acount;i++)
              avalue = adata[i];
              uint8_t* v =  reinterpret_cast<uint8_t*>(&avalue);
              data.push_back(v[0]);
          record.SetData(data);
          m_vlrs.push_back(record);
More information about the Liblas-commits mailing list
