[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Tue Oct 20 12:10:40 EDT 2009
changeset e5f3e5dfe317 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=e5f3e5dfe317
summary: support fetching and overriding the SRS
changeset 892246f18c76 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=892246f18c76
summary: merge
diffstat:
.hgignore | 11 +++++
CMakeLists.txt | 17 +++++++-
apps/las2las.c | 7 +++-
build/cmake/FindGDAL.cmake | 28 +++++++++++--
build/cmake/FindGeoTIFF.cmake | 78 ++++++++++++++++----------------------
build/cmake/FindSpatialIndex.cmake | 24 ++++++++++-
include/liblas/index/query.hpp | 46 ++++++++++++-----------
include/liblas/index/storage.hpp | 14 ++++---
python/scripts/oci2las.py | 61 ++++++++++++++++++++++++++++--
src/detail/reader.cpp | 13 +++++-
src/index/index.cpp | 1 +
src/index/query.cpp | 72 +++++++++++++++++-------------------
src/index/storage.cpp | 68 +++++++++++++++++++---------------
src/index/visitor.cpp | 18 +++++---
src/lasspatialreference.cpp | 10 +---
15 files changed, 294 insertions(+), 174 deletions(-)
diffs (truncated from 956 to 300 lines):
diff -r 2b2fa43686d7 -r 892246f18c76 .hgignore
--- a/.hgignore Mon Oct 19 14:42:01 2009 -0500
+++ b/.hgignore Tue Oct 20 11:07:50 2009 -0500
@@ -1,20 +1,29 @@
syntax: glob
.deps
.libs
*.dll
+*.embed.manifest
*.exe
*.exp
+*.idb
+*.ilk
+*.intermediate.manifest
*.la
*.lib
*.lo
+*.ncb
*.o
*.obj
+*.pdb
*.pyc
*.res
+*.suo
*.swp
*.bz2
*.gz
*.orig
+*.user
aclocal.m4
apps/las2las
apps/las2txt
@@ -51,3 +60,5 @@
CMakeCache.txt
cmake_install.cmake
src/liblas.a
+Debug
+Release
diff -r 2b2fa43686d7 -r 892246f18c76 CMakeLists.txt
--- a/CMakeLists.txt Mon Oct 19 14:42:01 2009 -0500
+++ b/CMakeLists.txt Tue Oct 20 11:07:50 2009 -0500
@@ -158,8 +158,18 @@
FIND_PACKAGE(GDAL 1.6.0)
IF(GDAL_FOUND)
- INCLUDE_DIRECTORIES(${GDAL_INCLUDE_DIR})
- ADD_DEFINITIONS(-DHAVE_GDAL=1)
+ # Confirm required API is available
+ INCLUDE(CheckFunctionExists)
+ SET(CMAKE_REQUIRED_LIBRARIES ${GDAL_LIBRARY})
+ CHECK_FUNCTION_EXISTS(OSRSetEquirectangular2 HAVE_OSRSETEQUIRECTANGULAR2)
+ IF(NOT HAVE_OSRSETEQUIRECTANGULAR2)
+ GDALSET(_FOUND) # Reset to NOT found for GDAL/OGR
+ MESSAGE(FATAL_ERROR "GDAL support requires GDAL 1.6.0 or newer.")
+ ELSE()
+ INCLUDE_DIRECTORIES(${GDAL_INCLUDE_DIR})
+ ADD_DEFINITIONS(-DHAVE_GDAL=1)
+ ENDIF()
ENDIF()
ENDIF()
@@ -171,6 +181,9 @@
IF(SPATIALINDEX_FOUND)
INCLUDE_DIRECTORIES(${SPATIALINDEX_INCLUDE_DIR})
+ IF (IS_DIRECTORY ${SPATIALINDEX_INCLUDE_DIR}/spatialindex)
+ INCLUDE_DIRECTORIES(${SPATIALINDEX_INCLUDE_DIR}/spatialindex)
+ ENDIF()
ADD_DEFINITIONS(-DHAVE_SPATIALINDEX=1)
ENDIF()
ENDIF()
diff -r 2b2fa43686d7 -r 892246f18c76 apps/las2las.c
--- a/apps/las2las.c Mon Oct 19 14:42:01 2009 -0500
+++ b/apps/las2las.c Tue Oct 20 11:07:50 2009 -0500
@@ -19,6 +19,11 @@
#include <stdlib.h>
#include <string.h>
+#ifdef _WIN32
+#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
+#else
+#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
+#endif
LASPointSummary* SummarizePoints(LASReaderH reader);
void print_point_summary(FILE *file, LASPointSummary* summary, LASHeaderH header);
@@ -354,7 +359,7 @@
i++;
- if (!strncasecmp(argv[i], "min", 3)) {
+ if (!compare_no_case(argv[i], "min", 3)) {
use_min_offset = TRUE;
do_set_offset = TRUE;
} else
diff -r 2b2fa43686d7 -r 892246f18c76 build/cmake/FindGDAL.cmake
--- a/build/cmake/FindGDAL.cmake Mon Oct 19 14:42:01 2009 -0500
+++ b/build/cmake/FindGDAL.cmake Tue Oct 20 11:07:50 2009 -0500
@@ -14,11 +14,21 @@
MESSAGE(STATUS "Searching for GDAL ${GDAL_FIND_VERSION}+ library")
+MESSAGE(STATUS " NOTE: Required version is not checked - to be implemented")
SET(GDAL_NAMES gdal)
IF(WIN32)
+ SET(OSGEO4W_IMPORT_LIBRARY gdal_i)
+ IF(DEFINED ENV{OSGEO4W_ROOT})
+ SET(OSGEO4W_ROOT_DIR $ENV{OSGEO4W_ROOT})
+ MESSAGE(STATUS "Trying OSGeo4W using environment variable OSGEO4W_ROOT=$ENV{OSGEO4W_ROOT}")
+ ELSE()
+ SET(OSGEO4W_ROOT_DIR c:/OSGeo4W)
+ MESSAGE(STATUS "Trying OSGeo4W using default location OSGEO4W_ROOT=${OSGEO4W_ROOT_DIR}")
+ ENDIF()
IF(MINGW)
FIND_PATH(GDAL_INCLUDE_DIR
gdal.h
@@ -26,7 +36,8 @@
PATHS
/usr/local/include
/usr/include
- c:/msys/local/include)
+ c:/msys/local/include
+ ${OSGEO4W_ROOT_DIR}/include)
FIND_LIBRARY(GDAL_LIBRARY
NAMES ${GDAL_NAMES}
@@ -34,21 +45,28 @@
PATHS
/usr/local/lib
/usr/lib
- c:/msys/local/lib)
+ c:/msys/local/lib
+ ${OSGEO4W_ROOT_DIR}/lib)
ENDIF(MINGW)
IF(MSVC)
- SET(GDAL_INCLUDE_DIR "$ENV{LIB_DIR}/include/gdal" CACHE STRING INTERNAL)
+ FIND_PATH(GDAL_INCLUDE_DIR
+ NAMES gdal.h
+ PATH_PREFIXES gdal gdal-1.6
+ PATHS
+ "$ENV{LIB_DIR}/include/gdal"
- SET(GDAL_NAMES ${GDAL_NAMES} gdal_I)
+ SET(GDAL_NAMES ${OSGEO4W_IMPORT_LIBRARY} ${GDAL_NAMES})
NAMES ${GDAL_NAMES}
PATHS
"$ENV{LIB_DIR}/lib"
/usr/lib
+ c:/msys/local/lib
IF(GDAL_LIBRARY)
SET(GDAL_LIBRARY;odbc32;odbccp32 CACHE STRING INTERNAL)
diff -r 2b2fa43686d7 -r 892246f18c76 build/cmake/FindGeoTIFF.cmake
--- a/build/cmake/FindGeoTIFF.cmake Mon Oct 19 14:42:01 2009 -0500
+++ b/build/cmake/FindGeoTIFF.cmake Tue Oct 20 11:07:50 2009 -0500
@@ -1,16 +1,18 @@
# CMake module to search for GeoTIFF library
# On success, the macro sets the following variables:
# GEOTIFF_FOUND = if the library found
-# GEOTIFF_LIBRARY = full path to the library
+# GEOTIFF_LIBRARIES = full path to the library
# GEOTIFF_INCLUDE_DIR = where to find the library headers
-# On Unix, macro sets also:
-# GEOTIFF_VERSION_STRING = human-readable string containing version of the library
+# also defined, but not for general use are
+# GEOTIFF_LIBRARY, where to find the PROJ.4 library.
# Copyright (c) 2009 Mateusz Loskot <mateusz at loskot.net>
+# Module source: http://github.com/mloskot/workshop/tree/master/cmake/
# Redistribution and use is allowed according to the terms of the BSD license.
# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
@@ -18,54 +20,40 @@
MESSAGE(STATUS "Searching for GeoTIFF ${GeoTIFF_FIND_VERSION}+ library")
-SET(GEOTIFF_NAMES geotiff)
+IF(GEOTIFF_INCLUDE_DIR)
+ # Already in cache, be silent
+ SET(GEOTIFF_FIND_QUIETLY TRUE)
+ENDIF()
IF(WIN32)
+ SET(OSGEO4W_IMPORT_LIBRARY geotiff_i)
+ ELSE()
+ ENDIF()
+ENDIF()
+FIND_PATH(GEOTIFF_INCLUDE_DIR
+ geotiff.h
+ PATH_PREFIXES geotiff
+ PATHS
- IF(MINGW)
- FIND_PATH(GEOTIFF_INCLUDE_DIR
- geotiff.h
- PATH_PREFIXES geotiff
- PATHS
- /usr/local/include
- /usr/include
+SET(GEOTIFF_NAMES ${OSGEO4W_IMPORT_LIBRARY} geotiff)
- FIND_LIBRARY(GEOTIFF_LIBRARY
- NAMES ${GEOTIFF_NAMES}
- PATHS
- /usr/local/lib
- /usr/lib
- ENDIF(MINGW)
+FIND_LIBRARY(GEOTIFF_LIBRARY
+ NAMES ${GEOTIFF_NAMES}
+ PATHS
- IF(MSVC)
- SET(GEOTIFF_INCLUDE_DIR "$ENV{LIB_DIR}/include" CACHE STRING INTERNAL)
- SET(GEOTIFF_NAMES ${GEOTIFF_NAMES} geotiff_i)
- FIND_LIBRARY(GEOTIFF_LIBRARY NAMES
- PATHS
- "$ENV{LIB_DIR}/lib"
- /usr/lib
- ENDIF(MSVC)
-ELSEIF(UNIX)
- FIND_PATH(GEOTIFF_INCLUDE_DIR geotiff.h PATH_PREFIXES geotiff)
- FIND_LIBRARY(GEOTIFF_LIBRARY NAMES ${GEOTIFF_NAMES})
-ELSE()
- MESSAGE("FindGeoTIFF.cmake: unrecognized or unsupported operating system (use Unix or Windows)")
+IF(GEOTIFF_FOUND)
+ SET(GEOTIFF_LIBRARIES ${GEOTIFF_LIBRARY})
ENDIF()
-# Handle the QUIETLY and REQUIRED arguments and set SPATIALINDEX_FOUND to TRUE
+# Handle the QUIETLY and REQUIRED arguments and set GEOTIFF_FOUND to TRUE
# if all listed variables are TRUE
INCLUDE(FindPackageHandleStandardArgs)
FIND_PACKAGE_HANDLE_STANDARD_ARGS(GEOTIFF DEFAULT_MSG GEOTIFF_LIBRARY GEOTIFF_INCLUDE_DIR)
-# TODO: Do we want to mark these as advanced? --mloskot
-# http://www.cmake.org/cmake/help/cmake2.6docs.html#command:mark_as_advanced
-#MARK_AS_ADVANCED(GEOTIFF_LIBRARY GEOTIFF_INCLUDE_DIR)
diff -r 2b2fa43686d7 -r 892246f18c76 build/cmake/FindSpatialIndex.cmake
--- a/build/cmake/FindSpatialIndex.cmake Mon Oct 19 14:42:01 2009 -0500
+++ b/build/cmake/FindSpatialIndex.cmake Tue Oct 20 11:07:50 2009 -0500
@@ -20,10 +20,28 @@
SET(SPATIALINDEX_FIND_QUIETLY TRUE)
ENDIF()
-FIND_PATH(SPATIALINDEX_INCLUDE_DIR NAMES RTree.h PATH_PREFIXES spatialindex)
+IF(WIN32)
+ SET(OSGEO4W_IMPORT_LIBRARY spatialindex_i)
+ ELSE()
+ ENDIF()
+ENDIF()
-SET(SPATIALINDEX_NAMES spatialindex)
-FIND_LIBRARY(SPATIALINDEX_LIBRARY NAMES ${SPATIALINDEX_NAMES} )
+FIND_PATH(SPATIALINDEX_INCLUDE_DIR
+ NAMES RTree.h
+ PATH_PREFIXES spatialindex
+ PATHS
More information about the Liblas-commits
