[Liblas-commits] hg: use blk_id instead of obj_id
liblas-commits at liblas.org
Wed Oct 21 16:55:20 EDT 2009
changeset 21a88d859fb2 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=21a88d859fb2
summary: use blk_id instead of obj_id
diffstat:
apps/las2oci.cpp | 5 +++--
1 files changed, 3 insertions(+), 2 deletions(-)
diffs (22 lines):
diff -r 892246f18c76 -r 21a88d859fb2 apps/las2oci.cpp
--- a/apps/las2oci.cpp Tue Oct 20 11:07:50 2009 -0500
+++ b/apps/las2oci.cpp Wed Oct 21 15:52:29 2009 -0500
@@ -317,7 +317,7 @@
b->getHigh(0) <<","<<
b->getHigh(1) <<","<<
b->getHigh(2)<<"))";
- oss << "INSERT INTO "<< tableName << "(OBJ_ID, NUM_POINTS, BLK_EXTENT, POINTS) VALUES ( "
+ oss << "INSERT INTO "<< tableName << "(BLK_ID, NUM_POINTS, BLK_EXTENT, POINTS) VALUES ( "
<< result.GetID() <<"," << num_points << ", " << oss_geom.str() <<", EMPTY_BLOB())";
OWStatement* statement = 0;
@@ -331,7 +331,8 @@
delete statement; statement = 0;
oss.str("");
- oss << "SELECT POINTS FROM " << tableName << " WHERE OBJ_ID=" << result.GetID() << " FOR UPDATE";
+ // FIXME (BLK_ID *and* OBJ_ID must be used as part of the query.)
+ oss << "SELECT POINTS FROM " << tableName << " WHERE BLK_ID=" << result.GetID() << " FOR UPDATE";
// we only expect one blob to come back
OCILobLocator** locator =(OCILobLocator**) VSIMalloc( sizeof(OCILobLocator*) * 1 );
More information about the Liblas-commits
