[Liblas-commits] hg: [cmake] Added requirement of GeoTIFF support
if GDAL support...
liblas-commits at liblas.org
Sun Sep 27 14:06:20 EDT 2009
changeset 7979f84370b6 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=7979f84370b6
summary: [cmake] Added requirement of GeoTIFF support if GDAL support was selected.
diffstat:
CMakeLists.txt | 28 ++++++++++++++++------------
1 files changed, 16 insertions(+), 12 deletions(-)
diffs (45 lines):
diff -r 66d3d9cf0e8c -r 7979f84370b6 CMakeLists.txt
--- a/CMakeLists.txt Sun Sep 27 18:03:55 2009 +0100
+++ b/CMakeLists.txt Sun Sep 27 19:06:09 2009 +0100
@@ -85,18 +85,6 @@
ENDIF()
ENDIF()
-# GDAL/OGR support - optional, default=OFF
-SET(WITH_GDAL FALSE CACHE BOOL "Choose if GDAL support should be built")
-IF(WITH_GDAL)
- FIND_PACKAGE(GDAL 1.6.0)
- IF(GDAL_FOUND)
- INCLUDE_DIRECTORIES(${GDAL_INCLUDE_DIR})
- ADD_DEFINITIONS(-DHAVE_GDAL=1)
- ENDIF()
-ENDIF()
# GeoTIFF support - optional, default=OFF
SET(WITH_GEOTIFF FALSE CACHE BOOL "Choose if GeoTIFF support should be built")
@@ -109,6 +97,22 @@
ENDIF()
ENDIF()
+# GDAL/OGR support - optional, default=OFF
+SET(WITH_GDAL FALSE CACHE BOOL "Choose if GDAL support should be built")
+IF(WITH_GDAL)
+ IF (NOT GEOTIFF_FOUND)
+ MESSAGE(FATAL_ERROR "GDAL support requires GeoTIFF library which was not selected")
+ ENDIF()
+ FIND_PACKAGE(GDAL 1.6.0)
+ IF(GDAL_FOUND)
+ INCLUDE_DIRECTORIES(${GDAL_INCLUDE_DIR})
+ ADD_DEFINITIONS(-DHAVE_GDAL=1)
+ ENDIF()
+ENDIF()
# Spatial Index support - optional, default=OFF
SET(WITH_SPATIALINDEX FALSE CACHE BOOL "Choose if GeoTIFF support should be built")
More information about the Liblas-commits
