[Liblas-commits] hg: Added install target of runtime components to CMake build co...
liblas-commits at liblas.org liblas-commits at liblas.org
Sun Sep 27 17:54:16 EDT 2009
changeset 97f58cc1660a in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=97f58cc1660a
summary: Added install target of runtime components to CMake build configuration
diffstat:
 CMakeLists.txt      |  58 ++++++++++++++++++++++++++++++++++++++++++++++++++++++----
 apps/CMakeLists.txt |  22 ++++++++++++++++++++--
 src/CMakeLists.txt  |  14 ++++++++++++++
 3 files changed, 88 insertions(+), 6 deletions(-)
diffs (174 lines):
diff -r 7979f84370b6 -r 97f58cc1660a CMakeLists.txt
--- a/CMakeLists.txt	Sun Sep 27 19:06:09 2009 +0100
+++ b/CMakeLists.txt	Sun Sep 27 22:54:07 2009 +0100
@@ -23,10 +23,13 @@
 # CMake settings
-CMAKE_MINIMUM_REQUIRED( VERSION 2.4.0 )
+CMAKE_MINIMUM_REQUIRED(VERSION 2.6.0)
 SET(CMAKE_COLOR_MAKEFILE ON)
+# Allow advanced users to generate Makefiles printing detailed commands
+MARK_AS_ADVANCED(CMAKE_VERBOSE_MAKEFILE)
 # Path to additional CMake modules
 SET(CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/build/cmake ${CMAKE_MODULE_PATH})
@@ -73,6 +76,9 @@
 # Search for dependencies
+# Boost C++ Libraries support - optional, default=OFF
+# TODO
 # zlib support - optional, default=OFF
 SET(WITH_ZLIB FALSE CACHE BOOL "Choose if zlib support should be built")
@@ -128,11 +134,55 @@
 # Oracle support - optional, default=OFF
 # TODO
-# Boost C++ Libraries support - optional, default=OFF
-# TODO
+# Installation settings
+IF(WIN32)
+    SET(DEFAULT_LIB_SUBDIR lib)
+    SET(DEFAULT_DATA_SUBDIR .)
+    SET(DEFAULT_INCLUDE_SUBDIR include)
+    IF (MSVC)
+        SET(DEFAULT_BIN_SUBDIR bin)
+    ELSE()
+        SET(DEFAULT_BIN_SUBDIR .)
+    ENDIF()
+ELSE()
+    # Common locatoins for Unix and Mac OS X
+    SET(DEFAULT_DATA_SUBDIR share/liblas)
+    SET(DEFAULT_INCLUDE_SUBDIR include/liblas)
+ENDIF()
+# Locations are changeable by user to customize layout of libLAS installation
+# (default values are platform-specific)
+SET(LIBLAS_BIN_SUBDIR ${DEFAULT_BIN_SUBDIR} CACHE STRING
+    "Subdirectory where executables will be installed")
+SET(LIBLAS_LIB_SUBDIR ${DEFAULT_LIB_SUBDIR} CACHE STRING
+    "Subdirectory where libraries will be installed")
+SET(LIBLAS_INCLUDE_SUBDIR ${DEFAULT_INCLUDE_SUBDIR} CACHE STRING
+    "Subdirectory where header files will be installed")
+SET(LIBLAS_DATA_SUBDIR ${DEFAULT_DATA_SUBDIR} CACHE STRING
+    "Subdirectory where data will be installed")
+# Mark *_SUBDIR variables as advanced and dedicated to use by power-users only.
+MARK_AS_ADVANCED(LIBLAS_BIN_SUBDIR LIBLAS_LIB_SUBDIR LIBLAS_INCLUDE_SUBDIR LIBLAS_DATA_SUBDIR)
+# Full paths for the installation
+SET(LIBLAS_BIN_DIR ${LIBLAS_BIN_SUBDIR})
+SET(LIBLAS_LIB_DIR ${LIBLAS_LIB_SUBDIR})
+SET(LIBLAS_INCLUDE_DIR ${LIBLAS_INCLUDE_SUBDIR})
+SET(LIBLAS_DATA_DIR ${LIBLAS_DATA_SUBDIR})
-# List of directories to process
+# Installation commands
+INSTALL(FILES AUTHORS ChangeLog COPYING INSTALL LICENSE.txt README
+    DESTINATION ${LIBLAS_DATA_DIR}/doc)
+# Processing of project directories
 ADD_SUBDIRECTORY(src)
diff -r 7979f84370b6 -r 97f58cc1660a apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Sun Sep 27 19:06:09 2009 +0100
+++ b/apps/CMakeLists.txt	Sun Sep 27 22:54:07 2009 +0100
@@ -5,17 +5,20 @@
 # Copyright (c) 2009 Mateusz Loskot <mateusz at loskot.net>
 INCLUDE_DIRECTORIES(
     ../include
     ../include/liblas/capi)
-# Standard utilities
+# Collect programs to build
 SET(LASINFO lasinfo)
+SET(LASMERGE lasmerge)
 SET(LAS2LAS las2las)
 SET(LAS2TXT las2txt)
 SET(TXT2LAS txt2las)
-SET(LASMERGE lasmerge)
 # Utilities depending on 3rd-pary libraries
 IF(GDAL_FOUND)
@@ -30,6 +33,13 @@
     SET(LAS2OCI las2oci)
 ENDIF()
+SET(LIBLAS_UTILITIES
+    ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
+    ${LAS2OGR} ${LASINDEX} ${LAS2OCI})
+# Configure build targets
 SET(APPS_CPP_DEPENDENCIES
     ${LIBLAS_LIB_NAME}
     ${GEOTIFF_LIBRARY}
@@ -89,3 +99,11 @@
     ADD_EXECUTABLE(${LAS2OCI} las2oci.cpp)
     TARGET_LINK_LIBRARIES(${LAS2CI} ${APPS_CPP_DEPENDENCIES})
 ENDIF(LAS2OCI)
+# Targets installation
+INSTALL(TARGETS ${LIBLAS_UTILITIES}
+    RUNTIME DESTINATION ${LIBLAS_BIN_DIR}
+    LIBRARY DESTINATION ${LIBLAS_LIB_DIR}
+    ARCHIVE DESTINATION ${LIBLAS_LIB_DIR})
diff -r 7979f84370b6 -r 97f58cc1660a src/CMakeLists.txt
--- a/src/CMakeLists.txt	Sun Sep 27 19:06:09 2009 +0100
+++ b/src/CMakeLists.txt	Sun Sep 27 22:54:07 2009 +0100
@@ -20,6 +20,9 @@
         index/storage.cpp)
 ENDIF()
+# Source files specification
 SET(LIBLAS_HEADERS_DIR ../include/liblas)
 SET(LIBLAS_HPP
@@ -107,6 +110,9 @@
 # Standard include directory of libLAS library
 INCLUDE_DIRECTORIES(../include)
+# Targets settings
 # Static libLAS C++ library
 ADD_LIBRARY(${LIBLAS_LIB_NAME} STATIC ${LIBLAS_SOURCES})
@@ -119,3 +125,11 @@
     ${GEOTIFF_LIBRARY}
 	${SPATIALINDEX_LIBRARY}
 	${ZLIB_LIBRARIES})
+INSTALL(TARGETS ${LIBLAS_LIB_NAME} ${LIBLAS_C_LIB_NAME}
More information about the Liblas-commits mailing list
