[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Apr 1 23:20:00 EDT 2010
changeset 762733fd6827 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=762733fd6827
summary: update for new defaults
changeset 08abc5afc573 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=08abc5afc573
summary: add more docs
changeset 9d6ed479de3d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9d6ed479de3d
summary: fix up 1.0 pad byte accounting for the append case
diffstat:
 doc/python/classes.txt       |   6 ++-
 doc/python/tutorial.txt      |   2 +-
 include/liblas/lasheader.hpp |   1 +
 python/liblas/file.py        |  58 ++++++++++++++++++++++++++++++--
 python/tests/File.txt        |  76 ++++++++++++++++++++++++++++++++++++++-----
 python/tests/Format.txt      |   6 ++-
 python/tests/VLR.txt         |   5 +-
 src/detail/writer/header.cpp |  13 ++++++-
 src/detail/writer/point.cpp  |   1 -
 src/detail/writer/writer.cpp |   1 -
 src/lasheader.cpp            |  36 +++++++++-----------
 11 files changed, 159 insertions(+), 46 deletions(-)
diffs (truncated from 455 to 300 lines):
diff -r 59eba98aa75c -r 9d6ed479de3d doc/python/classes.txt
--- a/doc/python/classes.txt	Thu Apr 01 14:14:47 2010 -0500
+++ b/doc/python/classes.txt	Thu Apr 01 22:14:13 2010 -0500
@@ -1,12 +1,14 @@
 .. _class_documentation:
-  libLAS Python Class Documentation
+  Python Class Documentation
 .. autoclass:: liblas.point.Point
     :members: x, y, z, time, scan_angle, scan_direction, scan_flags, flightline_edge, number_of_returns, return_number
+.. autoclass:: liblas.file.File
+    :members: __init__, close, header, read, write, __iter__, __getitem__
 # .. doxygenclass:: liblas::Color
 #    :project: class
diff -r 59eba98aa75c -r 9d6ed479de3d doc/python/tutorial.txt
--- a/doc/python/tutorial.txt	Thu Apr 01 14:14:47 2010 -0500
+++ b/doc/python/tutorial.txt	Thu Apr 01 22:14:13 2010 -0500
@@ -1,7 +1,7 @@
 .. _python_tutorial:
-libLAS Python Tutorial
+Python Tutorial
 This basic tutorial explains how to use libLAS to read and write
diff -r 59eba98aa75c -r 9d6ed479de3d include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp	Thu Apr 01 14:14:47 2010 -0500
+++ b/include/liblas/lasheader.hpp	Thu Apr 01 22:14:13 2010 -0500
@@ -348,6 +348,7 @@
     void Init();
     void ClearGeoKeyVLRs();
+    void UpdatePointFormat();
     // Private data members
diff -r 59eba98aa75c -r 9d6ed479de3d python/liblas/file.py
--- a/python/liblas/file.py	Thu Apr 01 14:14:47 2010 -0500
+++ b/python/liblas/file.py	Thu Apr 01 22:14:13 2010 -0500
@@ -52,7 +52,21 @@
 class File(object):
     def __init__(self, filename, header=None, mode='r', in_srs = None, out_srs = None):
+        """Instantiate a file object to represent an LAS file.  Valid modes are \
+           "r" for read, "w" for write, and "w+" for append.  Setting in_srs will override \
+           the file's header SRS, and setting an out_srs will allow the points to be \
+           reprojected on-the-fly to the out_srs coordinate system as they are read/written.
+        To open a file in write mode, you must provide a liblas.header.Header instance
+        which will be immediately written to the file.  If you provide a header instance
+        in read mode, the values of that header will be used in place of those in the
+        actual file.
+        >>> from liblas import file
+        >>> f = file.File('file.las',mode='r')
+        >>> for p in f:
+        ...     print 'X,Y,Z: ', p.x, p.y, p.z
         self.filename = os.path.abspath(filename)
         self._header = header
         self.handle = None
@@ -74,6 +88,8 @@
         self.open()
     def open(self):
+        """Open the file for processing, called by __init__
         if self._mode == 'r' or self._mode =='rb':
             if not self._header:
@@ -121,6 +137,8 @@
         self.close()
     def close(self):
+        """Closes the LAS file
         if self.mode == 0 :
             core.las.LASReader_Destroy(self.handle)
             files['read'].remove(self.filename)
@@ -164,7 +182,8 @@
         """Returns the liblas.header.Header for the file"""
         return self._header
     def set_header(self, header):
+        """Sets the liblas.header.Header for the file.  If the file is in \
+        append mode, the header will be overwritten in the file."""
         # append mode
         if mode == 2:
             core.las.LASWriter_Destroy(self.handle)
@@ -172,13 +191,24 @@
             return True
         raise core.LASException("The header can only be set after file creation for files in append mode")
-    header = property(get_header)
+    doc = """Get or set the file's liblas.header.Header  If the file is in \
+    header = property(get_header, set_header, None, doc)
-    def read(self, location):
+    def read(self, index):
+        """Reads the point at the given index"""
         if self.mode == 0:
-            return point.Point(handle=core.las.LASReader_GetPointAt(self.handle, location), copy=True)
+            return point.Point(handle=core.las.LASReader_GetPointAt(self.handle, index), copy=True)
     def __iter__(self):
+        """Iterator support (read mode only)
+          >>> points = []
+          >>> for i in f:
+          ...   points.append(i)
+          ...   print i # doctest: +ELLIPSIS
+          <liblas.point.Point object at ...>
         if self.mode == 0:
             self.at_end = False
             p = core.las.LASReader_GetNextPoint(self.handle)
@@ -191,10 +221,28 @@
                 self.close()
                 self.open()
+    def __getitem__(self, index):
+        """Index and slicing support (implemented using read())"""
+        try:
+            index.stop
+        except AttributeError:
+            return self.read(index)
+        output = []
+        if index.step:
+            step = index.step
+        else:
+            step = 1
+        for i in range(index.start, index.stop, step):
+            output.append(self.read(i))
+        return output
     def __len__(self):
+        """Returns the number of points in the file according to the header"""
         return self.header.point_records_count
     def write(self, pt):
+        """Writes the point to the file if it is append or write mode."""
         if not isinstance(pt, point.Point):
             raise core.LASException('cannot write %s, it must be of type liblas.point.Point' % pt)
         if self.mode == 1 or self.mode == 2:
diff -r 59eba98aa75c -r 9d6ed479de3d python/tests/File.txt
--- a/python/tests/File.txt	Thu Apr 01 14:14:47 2010 -0500
+++ b/python/tests/File.txt	Thu Apr 01 22:14:13 2010 -0500
@@ -7,7 +7,7 @@
   8L
-  >>> header = f.header
+  >>> h = f.header
   >>> p = f.read(0)
   >>> p.x, p.y, p.z
   (630262.30000000005, 4834500.0, 51.530000000000001)
@@ -36,6 +36,13 @@
+  >>> f[0]
+  >>> out = f[0:3]
+  >>> len(out)
+  3
   >>> len(points)
   8
@@ -69,10 +76,10 @@
   >>> del f
-  >>> f = file.File('junk.las', mode="w", header=header)
-  >>> sum(header.offset)
+  >>> f = file.File('junk.las', mode="w", header=h)
+  >>> sum(h.offset)
   0.0
-  >>> header.min
+  >>> h.min
   [630262.30000000005, 4834500.0, 50.899999999999999]
   >>> for i in points:
@@ -87,7 +94,7 @@
   >>> f.header
   >>> del f
-  >>> f = file.File('junk.las', mode='w+', header=header)
+  >>> f = file.File('junk.las', mode='w+', header=h)
   >>> for i in points:
   ...    f.write(i)
@@ -118,12 +125,11 @@
   >>> del f3
-The header's offset will change +=2 because of the 1.0
-requirement to write pad bytes at the end of the header
   >>> f = file.File('junk2.las')
   >>> f.header.data_offset
-  1026L
+  1024L
   >>> points = []
   >>> for i in f:
@@ -193,13 +199,63 @@
   630323.57
   630320.95
   630280.89
+The header's offset will change +=2 if there isn't enough room in the
+header after you subtract the VLRs
+  >>> from liblas import header
+  >>> h2 = header.Header()
+  >>> h2.data_offset = 227
+  >>> h2.minor_version = 0
+  >>> f4 = file.File('junk4.las',mode='w',header=h2)
+  >>> f4.header.data_offset
+  227L
+  >>> for i in points:
+  ...    f4.write(i)
+  >>> f4.close()
+  >>> del f4
+  >>> f = file.File('junk4.las')
+  >>> f.header.data_offset
+  229L
+  >>> points = []
+  >>> for i in f:
+  >>> for g in points:
+  ...   print round(g.x, 6)
+  630262.3
+  630282.45
+  630300.07
+  630346.82
+  630327.57
+  630323.57
+  630320.95
+  630280.89
   >>> import os
   >>> os.remove('junk.las')
   >>> os.remove('junk2.las')
   >>> os.remove('junk3.las')
+  >>> os.remove('junk4.las')
   >>> import liblas.core
   >>> liblas.core.las.LASWriter_Destroy(f.handle)
   >>> print 'destroyed once'
diff -r 59eba98aa75c -r 9d6ed479de3d python/tests/Format.txt
--- a/python/tests/Format.txt	Thu Apr 01 14:14:47 2010 -0500
+++ b/python/tests/Format.txt	Thu Apr 01 22:14:13 2010 -0500
@@ -9,7 +9,7 @@
   >>> f = h.format
   >>> f.major, f.minor
-  (1, 0)
+  (1, 2)
   >>> f.size
   28L
@@ -29,7 +29,9 @@
   >>> f.major
   1
More information about the Liblas-commits mailing list
