[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Mon Apr 5 11:52:55 EDT 2010
changeset 5cd168bdd44c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5cd168bdd44c
summary: reset the error state of the stream if we're eof
changeset db534a58c501 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=db534a58c501
summary: clean up leftover from last commit
diffstat:
include/liblas/iterator.hpp | 12 +-
include/liblas/laserror.hpp | 8 +-
src/detail/reader/header.cpp | 7 +-
src/las_c_api.cpp | 10 +-
src/laserror.cpp | 6 +-
test/unit/common.cpp | 30 +-
test/unit/common.hpp | 16 +-
test/unit/lasclassification_test.cpp | 76 ++++----
test/unit/laserror_test.cpp | 12 +-
test/unit/lasheader_test.cpp | 56 +++---
test/unit/laspoint_test.cpp | 52 +++---
test/unit/lasreader_iterator_test.cpp | 16 +-
test/unit/lasreader_test.cpp | 22 +-
test/unit/lasspatialreference_test.cpp | 252 +--------------------------------
test/unit/lasvariablerecord_test.cpp | 22 +-
test/unit/laswriter_test.cpp | 40 ++--
16 files changed, 197 insertions(+), 440 deletions(-)
diffs (truncated from 1690 to 300 lines):
diff -r 9d6ed479de3d -r db534a58c501 include/liblas/iterator.hpp
--- a/include/liblas/iterator.hpp Thu Apr 01 22:14:13 2010 -0500
+++ b/include/liblas/iterator.hpp Mon Apr 05 10:46:57 2010 -0500
@@ -72,7 +72,7 @@
/// Initializes iterator pointing to beginning of LAS file sequence.
/// No ownership transfer of reader object occurs.
- reader_iterator(liblas::LASReader& reader)
+ reader_iterator(liblas::Reader& reader)
: m_reader(&reader)
assert(0 != m_reader);
@@ -129,7 +129,7 @@
- liblas::LASReader* m_reader;
+ liblas::Reader* m_reader;
/// Equality operator implemented in terms of reader_iterator::equal
@@ -164,7 +164,7 @@
/// Initialize iterator with given writer.
/// The writer position is not changed.
/// No ownership transfer of writer object occurs.
- writer_iterator(liblas::LASWriter& writer)
+ writer_iterator(liblas::Writer& writer)
: m_writer(&writer)
assert(0 != m_writer);
@@ -205,16 +205,16 @@
private:
- liblas::LASWriter* m_writer;
+ liblas::Writer* m_writer;
// Declare specializations for user's convenience
/// Public specialization of LASReader input iterator for liblas::LASPoint type.
-typedef reader_iterator<LASPoint> lasreader_iterator;
+typedef reader_iterator<Point> lasreader_iterator;
/// Public specialization of LASWriter output iterator for liblas::LASPoint type.
-typedef writer_iterator<LASPoint> laswriter_iterator;
+typedef writer_iterator<Point> laswriter_iterator;
} // namespace liblas
diff -r 9d6ed479de3d -r db534a58c501 include/liblas/laserror.hpp
--- a/include/liblas/laserror.hpp Thu Apr 01 22:14:13 2010 -0500
+++ b/include/liblas/laserror.hpp Mon Apr 05 10:46:57 2010 -0500
@@ -54,21 +54,21 @@
/// This class describes details of error condition occured in
/// libLAS core. All errors are stacked by C API layer, so it's
/// possible to track problem down to its source.
-class LASError
+class Error
public:
/// Custom constructor.
/// This is the main and the only tool to initialize error instance.
- LASError(int code, std::string const& message, std::string const& method);
+ Error(int code, std::string const& message, std::string const& method);
/// Copy constructor.
/// Error objects are copyable.
- LASError(LASError const& other);
+ Error(Error const& other);
/// Assignment operator.
/// Error objects are assignable.
- LASError& operator=(LASError const& rhs);
+ Error& operator=(Error const& rhs);
// TODO - mloskot: What about replacing string return by copy with const char* ?
// char const* GetMethod() const { return m_method.c_str(); }, etc.
diff -r 9d6ed479de3d -r db534a58c501 src/detail/reader/header.cpp
--- a/src/detail/reader/header.cpp Thu Apr 01 22:14:13 2010 -0500
+++ b/src/detail/reader/header.cpp Mon Apr 05 10:46:57 2010 -0500
@@ -215,6 +215,7 @@
// offset is actually 2 bytes back. We need to set the dataoffset
// appropriately in those cases anyway.
m_ifs.seekg(m_header.GetDataOffset());
if (HasLAS10PadSignature()) {
std::streamsize const current_pos = m_ifs.tellg();
@@ -232,6 +233,10 @@
// really what is wrong, but there's no real way to know that unless
// you go start mucking around in the bytes with hexdump or od
+ // If we're eof, we need to reset the state
+ if (m_ifs.eof())
+ m_ifs.clear();
// Seek to the beginning
m_ifs.seekg(0, std::ios::beg);
std::ios::pos_type beginning = m_ifs.tellg();
@@ -240,7 +245,7 @@
m_ifs.seekg(0, std::ios::end);
std::ios::pos_type end = m_ifs.tellg();
std::ios::off_type size = end - beginning;
// Figure out how many points we have
std::ios::off_type count = (end - static_cast<std::ios::off_type>(m_header.GetDataOffset())) /
static_cast<std::ios::off_type>(m_header.GetDataRecordLength());
diff -r 9d6ed479de3d -r db534a58c501 src/las_c_api.cpp
--- a/src/las_c_api.cpp Thu Apr 01 22:14:13 2010 -0500
+++ b/src/las_c_api.cpp Mon Apr 05 10:46:57 2010 -0500
@@ -132,7 +132,7 @@
} LASErrorEnum;
-static std::stack<LASError > errors;
+static std::stack<liblas::Error > errors;
#ifdef _MSC_VER
# pragma warning(disable: 4127) // warning C4127: conditional expression is constant
@@ -184,7 +184,7 @@
if (errors.empty())
return 0;
else {
- LASError err = errors.top();
+ liblas::Error err = errors.top();
return err.GetCode();
@@ -193,7 +193,7 @@
if (errors.empty())
return NULL;
else {
return strdup(err.GetMessage().c_str());
@@ -202,13 +202,13 @@
if (errors.empty())
return NULL;
else {
return strdup(err.GetMethod().c_str());
LAS_DLL void LASError_PushError(int code, const char *message, const char *method) {
- LASError err = LASError(code, std::string(message), std::string(method));
+ liblas::Error err = liblas::Error(code, std::string(message), std::string(method));
errors.push(err);
diff -r 9d6ed479de3d -r db534a58c501 src/laserror.cpp
--- a/src/laserror.cpp Thu Apr 01 22:14:13 2010 -0500
+++ b/src/laserror.cpp Mon Apr 05 10:46:57 2010 -0500
@@ -47,21 +47,21 @@
namespace liblas
-LASError::LASError(int code, std::string const& message, std::string const& method) :
+Error::Error(int code, std::string const& message, std::string const& method) :
m_code(code),
m_message(message),
m_method(method)
-LASError::LASError(LASError const& other) :
+Error::Error(Error const& other) :
m_code(other.m_code),
m_message(other.m_message),
m_method(other.m_method)
-LASError& LASError::operator=(LASError const& rhs)
+Error& Error::operator=(Error const& rhs)
if (&rhs != this)
diff -r 9d6ed479de3d -r db534a58c501 test/unit/common.cpp
--- a/test/unit/common.cpp Thu Apr 01 22:14:13 2010 -0500
+++ b/test/unit/common.cpp Mon Apr 05 10:46:57 2010 -0500
@@ -14,12 +14,12 @@
namespace tut
-void test_default_header(liblas::LASHeader const& h)
+void test_default_header(liblas::Header const& h)
- using liblas::LASHeader;
+ using liblas::Header;
ensure_equals("wrong default file signature",
- h.GetFileSignature(), LASHeader::FileSignature);
+ h.GetFileSignature(), Header::FileSignature);
ensure_equals("wrong default file source id",
h.GetFileSourceId(), 0);
@@ -36,9 +36,9 @@
h.GetVersionMinor(), 2);
ensure_equals("wrong default system id",
- h.GetSystemId(), LASHeader::SystemIdentifier);
+ h.GetSystemId(), Header::SystemIdentifier);
ensure_equals("wrong default software id",
- h.GetSoftwareId(), LASHeader::SoftwareIdentifier);
+ h.GetSoftwareId(), Header::SoftwareIdentifier);
// TODO: Fix me to use todays day # and year
// ensure_equals("wrong default creation day-of-year",
@@ -81,7 +81,7 @@
ensure_equals("wrong default max Z", h.GetMaxZ(), double(0));
-void test_default_point(liblas::LASPoint const& p)
+void test_default_point(liblas::Point const& p)
ensure_equals("wrong default X coordinate",
p.GetX(), double(0));
@@ -100,7 +100,7 @@
ensure_equals("wrong defualt edge of flight line",
p.GetFlightLineEdge(), 0);
ensure_equals("wrong defualt classification",
- p.GetClassification(), liblas::LASClassification::bitset_type());
+ p.GetClassification(), liblas::Classification::bitset_type());
ensure_equals("wrong defualt scan angle rank",
p.GetScanAngleRank(), 0);
ensure_equals("wrong defualt file marker/user data value",
@@ -120,9 +120,9 @@
ensure("invalid defualt point record", p.IsValid());
-void test_file10_header(liblas::LASHeader const& h)
+void test_file10_header(liblas::Header const& h)
- ensure_equals(h.GetFileSignature(), liblas::LASHeader::FileSignature);
+ ensure_equals(h.GetFileSignature(), liblas::Header::FileSignature);
ensure_equals(h.GetFileSourceId(), 0);
ensure_equals(h.GetReserved(), 0);
@@ -156,13 +156,13 @@
ensure_equals(h.GetMaxZ(), double(55.26));
-void test_file10_point1(liblas::LASPoint const& p)
+void test_file10_point1(liblas::Point const& p)
ensure_distance(p.GetX(), double(630262.30), 0.0001);
ensure_distance(p.GetY(), double(4834500), 0.0001);
ensure_distance(p.GetZ(), double(51.53), 0.0001);
ensure_equals(p.GetIntensity(), 670);
- ensure_equals(p.GetClassification(), liblas::LASClassification::bitset_type(1));
+ ensure_equals(p.GetClassification(), liblas::Classification::bitset_type(1));
ensure_equals(p.GetScanAngleRank(), 0);
ensure_equals(p.GetUserData(), 3);
ensure_equals(p.GetPointSourceID(), 0);
@@ -170,13 +170,13 @@
ensure_distance(p.GetTime(), double(413665.23360000004), 0.0001);
-void test_file10_point2(liblas::LASPoint const& p)
+void test_file10_point2(liblas::Point const& p)
ensure_distance(p.GetX(), double(630282.45), 0.0001);
ensure_distance(p.GetZ(), double(51.63), 0.0001);
ensure_equals(p.GetIntensity(), 350);
@@ -184,13 +184,13 @@
ensure_distance(p.GetTime(), double(413665.52880000003), 0.0001);
-void test_file10_point4(liblas::LASPoint const& p)
+void test_file10_point4(liblas::Point const& p)
ensure_distance(p.GetX(), double(630346.83), 0.0001);
ensure_distance(p.GetZ(), double(50.90), 0.0001);
ensure_equals(p.GetIntensity(), 150);
ensure_equals(p.GetUserData(), 4);
diff -r 9d6ed479de3d -r db534a58c501 test/unit/common.hpp
--- a/test/unit/common.hpp Thu Apr 01 22:14:13 2010 -0500
+++ b/test/unit/common.hpp Mon Apr 05 10:46:57 2010 -0500
@@ -21,7 +21,7 @@
: x(x), y(y), t(tolerance)
More information about the Liblas-commits
